Easily Achieving 125 PSI - My Approach/Experience
Quoted: 6972 Post(s)
Liked 10,969 Times
Quoted: 3514 Post(s)
Liked 2,927 Times
Considering that 123 psi is printed right on the side of the tire, I would hardly call it "ridiculous". By the time I top them off again, they're usually around 95-100 psi.
The OP was asking which pumps can handle that pressure, not whether anyone approves of his choice of tire or tire pressure.
Quoted: 1083 Post(s)
Liked 687 Times
Resistance is futile: How tire pressure and width affect rolling resistance
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
The bicycle in question is a Reynolds 531 frame, ridden only on smooth roads. There's no such thing as a harsh ride with this bike. Regarding rolling resistance, there are more variables to consider but in general, higher is better. (Smaller contact patch). Here's an interesting article, among many others. Again though, when you're talking about rolling resistance there are a lot of variables including width of the tire, the tire construction itself, and of course the smoothness of the road surface.
If you think the size of the contact patch is what determines rolling resistance, you'd better rage hard against the dying of the tubed clincher, because tubeless (especially hookless) doesn't support skinny high-pressure setups very well...
Liked 2,927 Times
Anyway, that’s why I bought a second pair of Veloflexes when I could. Probably should get some more latex tubes.
Liked 10,969 Times
Using roller data from Al Morrison and on-road data from Tom Anhalt, you can see a clear breakpoint in the graph where rolling resistance appears to increase sharply (around 115psi – and note that this was a relatively smooth road). Rougher roads result in a breakpoint at significantly lower pressures.
The graph below shows how much worse things get with rough pavement (the red line) – with the fastest setup at a low 60psi.
If you're running 120psi or more, you're almost certainly losing on the balance sheet.
Got any more articles that refute your own argument?
Liked 2,927 Times
Apparently you've not read the article; here are a couple quotes:
Quoted: 2486 Post(s)
Liked 2,956 Times
If people aren't literally participating in races, it obviously doesn't matter if they're losing a bit of speed by using inordinately high pressure for the conditions they encounter. Rock-hard tires can be fun to ride.
Likes For Trakhak:
Quoted: 1820 Post(s)
Liked 1,696 Times
Or not if they ride the roads that I do. Where I live wider tires at much lower pressure are not only more comfortable, they are also faster. Baltimore does not have the same climate we have here where winter temperatures can vary 25 or more degrees centigrade in the space of 4-5 hours in the winter
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
No, one of my missions in life is trying to eliminate stupidity.
Liked 2,956 Times
"All the professional musicians I've played with brought their pro game to every song, whatever it was. All the mediocre musicians have been bitterly vehement about the many songs they regard as beneath them to play."
The first reply I received, in its entirety:
"You don't know me!"
Liked 2,927 Times
Better start by looking in the mirror.
I know lots of cyclists have the reputation of being absolute a-holes. Heck, I can be one myself sometimes. But man, the a-hole-ness just oozes out of you like pus from an open sore.
You are a bitter, bitter person.
senior member
I used a compressor for the longest time, but finally last year bought one of these. It easily hits 125 PSI, which is what I run in my Continental GP5000 700x25C. The double-sided flip lock works very well, and it works equally as well on my Schrader and Presta wheels. No adapters or any fiddling around at all. I never turn the compressor on any more - this is just so much quicker and easier. The positive reviews are accurate - this is a great pump at a very reasonable price. Highly recommended.
Topeak Joe Blow Sport III High Pressure Floor Pump
Liked 687 Times
I bought mine from Amazon, the link I shared. I agree a compressor is always good to have. I just find myself not using it for bicycles any more. By the time I turn on the compressor and it comes up to pressure, not to mention threading adapters onto the valve stems to fit the chuck, I can top off tires on two bicycles and be on the road. It's just quicker and easier and I wish I had bought this pump years ago. I actually top off my tires more frequently now because it's so much less involved.
senior member
Likes For blinky:
Quoted: 1401 Post(s)
Liked 1,886 Times
also inflate our car tires with it ; quick - efficient - accurate
also use DeWalt battery powered impact guns (instead of pneumatic) - small / compact model weighs around 3.5 lbs and can remove almost any bolt / wheel lug nuts; larger model still relatively small / compact at around 6 lbs and has great power (700/1200 ft lbs)
I'm sure there are a number of other available portable inflators - Milwaukee etc - if you already have the batteries a compatible portable inflator could be a nice addition
We also have a smaller portable Worx inflator - but have not used it yet
senior member
most times I use a DeWalt battery powered portable inflator instead of a compressor or floor pump
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
I swear this is worse than an oil thread on my Ducati forum.
Likes For Rdmonster69:
Bikes: lots
Liked 2,932 Times
I may be an a-hole but I'm not bitter at all. You're on an online forum. You can post whatever you want about tire pressure and I'm able to post my opinion about how stupid I may think it is. Get over it.
Likes For cxwrench:
Liked 2,927 Times
Fine. Then it's my opinion that you're a bitter, bitter person, who probably doesn't even ride a bike. Deal with it.
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
It's not my opinion but fact that the OP was soliciting comments and advice on how to achieve these super high pressures. If the gist of the thread was "what do you think of the pressures I am running, do you rhink this is a good pressure etc " then by all means, tell him its dumb and ridiculous and yadda yadda yadda.
He didn't ask
This being bike forums many people subtly or not so subtly imply he is an idiot and everyone proceeds to bag on his pressures and approach to achieving them.
I used to run 120 psi on my 23mm tires all the time. That's what the tire called for and if I ran 80 or 90 psi I got hella pinch flats. I run 80 or less on my Domane because that's what it called for. When I check pressure on my sport bike I do what the sidewall says unless experience says go a pound or two in either direction.
Kindly offering advice and stating your case is the way to behave. Being that this is the internet means I can be a ****** is no way to go through life.
He didn't ask
Liked 1,886 Times
I legit LOL'd on this comment. My thoughts on PSI ? Meh ....run what ya want if it suits you. The OP was asking about pumps that would get his tires pumped up to high pressure easily...not if people approved of his PSI choices. FWIW I run close to 100 on m clinchers or else I start getting flats. I run about 70ish or whatever my thumb test tells me is OK on my 32c tubeless.
Liked 1,886 Times
He didn't ask
He didn't ask
book it - gonna happen
maybe if the roads are relatively smooth / no potholes / lips / railroad track crossings ... might be able to get away with it
don't try this at home.
Quoted: 974 Post(s)
Liked 512 Times
Back on topic:
My older Park Tool PFP-3 is easy to pump to 100 psi (I run 72 front, 80 rear on my 28mm tires. Fast and comfortable too.) It's noticeably easier to push down the handle above 50 psi than some of the other rider's pumps that I've used. And I've seen small riders really struggle with their floor pump, not enough weight pressing down on the handle, I guess.
Just like mini pumps to carry on rides, the barrel diameter helps determine how easy it is to get high pressures. Narrow = lower volume = easier high pressures.
