#1801
Quoted: 7350 Post(s)
Liked 2,476 Times
For months, I thought I would need a frame repair person to help me with my frame. It's a 1971 Raleigh Super Course, originally a 10-speed (2x5). I ran a 3x6 drivetrain by shoving the back wheel in. It's time to upgrade to an 8-speed drivetrain, so I have a pair of wheels ready to go. I couldn't get the rear wheel in (130mm) even spreading the dropouts temporarily. It appeared that the small cogs didn't want to go in because the round chain stay came so far back. I spoke to two frame repair folks. One said he might figure something out. The other said he would braze in longer dropouts.
I decided to see what would happen if I just spread the frame permanently. Maybe the wheel would go in easily. And it does now. I can now proceed with the build, and I just saved myself a hundred bucks or so.
This time, I use RJ the Bike Guy's threaded rod method rather than the 2x4 method. It was easy. I haven't checked for symmetry yet, but it looks good to my eye so far.
When man invented the bicycle he reached the peak of his attainments. Elizabeth West, US author
#1802
Quoted: 1136 Post(s)
Liked 650 Times
@noglider I've used the threaded rod method to respace rear and front dropouts a few times now. Has worked every time. The self-centering aspect definitely makes it better than the 2x4 method.
#1803
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Like this one? Such as on this Raleigh Sprite?
. . . . . and I must have gone thru 400 pictures (including every variation of the above that was made for their chopper bikes) to find the above.
If it took that to find a picture, you can imagine what finding the real thing is like. The part that hurts is I got my Sprite with the right one (the three speed side) already broken, then found a replacement. Which I set up and used for about a year, only to bump it sideways and snap it getting off the bike. I'd always read that the biggest weakness to the S5 hub was the shift levers, and I wholeheartedly agree. The indents on the right side are weak, the plastic is brittle, and the entire action of the levers suck. But it is the correct part. I still have the broken off piece, and one of these days will glue it back to the stub, and just let the lever sit there for looks while doing the shifting with a regular AW handle bar shifter.
Syke
No one in this world, so far as I know and I have searched the records for years, and employed agents to help me has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.
H.L. Mencken, (1926)
Syke
#1804
Quoted: 4513 Post(s)
Liked 6,388 Times
I've only seen Blue and Brewster green like this, can't be too picky very few of these to be had and I love this Green one so I'm good.
There was probably no hope at the show, they seem to have zero love for road bikes.
#1805
Quoted: 1372 Post(s)
Liked 1,752 Times
Been back at the cottage for a few days, now. Got everything opened up, heating up and fitted with working indoor plumbing (a real bonus in Canada). With that in mind, I decided to start raking leaves today, but said to heck with it, deciding to build up a set of wheels for my Legnano Grand Premio...
Since the first build, the bike has been fitted with 27" Ambrosia rims laced to Campy High Fange hubs...
And today, the Leggy got a set of 700c hoops...
Tomorrow, with luck, a NOS Legnano cottered crank will be installed, followed by fitting the chain and a saddle replacement with a NOS Brooks. Then, take it out for a test ride.
#1806
Quoted: 221 Post(s)
Liked 237 Times
With that problem taken care of, the bike still has two issues: The short term is a desperate search for a S-A bracket small enough in diameter to clamp tightly to the left rear stay and allow me to use the left side over/under drive lever. I've tried shimming the slightly too large clamp I have and it only works for one shift. Maybe.
This is the part I'm looking for.
Sturmey-Archer rear stay cable clamp.
It's pretty much your standard S-A clamp that holds down one end of the cable casing while allowing the cable to proceed thru to the hub - with one exception: The size. The rear stay on the Sprite mikes out at 1/2" and anything in a proper S-A clamp that I've already found is too big in diameter to clamp down. I've tried shimming under the clamp to get it to tighten, but the shim invariably moves on the first pull of the lever.
Anyone who has one of these available, let me know.
ADDENDUM: Of course, twenty minutes after posting this, I do one of my periodic eBay searches and find it! Well, the seller is claiming the correct size, so I ordered and will supposedly have it by Friday. We'll see. I've been disappointed before.
Syke
Syke
#1807
Quoted: 221 Post(s)
Liked 237 Times
There is something so absolutely gorgeous about those bikes, the color combination, the chrome lugs, and now going back to the proper cottered crank. Now, if you could only find a set of the original branded fenders . . . . .
Syke
Syke
#1808
Liked 1,752 Times
The set is tucked away, in the rafters of my man cave...
#1809
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
(In response to post # 1822 from noglider Tom):
That's the method I use. Right now I have a Raleigh Wyoming in the workstand, on which I've installed a 9-speed Deore drivetrain with a single chainring up front. I took it out to 130mm with the same threaded rod setup.
I found that I needed to stretch it to about 145mm, leave it sit like that overnight, and then realign the dropouts with the correct Park FFG tools. This worked fine for mounting the wheel, but I had to readjust the derailleur hanger a bit to get it to shift properly.
I'll write more about it when it's finished, and post some before/after photos.
USMC 1981-1991 Semper Fi!
#1810
Quoted: 221 Post(s)
Liked 237 Times
Finally got around to the final spring project in the stable: Complete teardown and rebuild of my 1969 Magneet touring bikes, plus a desperately needed upgrade on the brakes. I've been putting it off repeatedly since last fall, but at the 14 years, 5200 mile point I figured I'm finally due.
Big change here is replacing the the Weinmann centerpull front/Synchro side pull rear combination with a pair of Mafac Racer center pulls. And, despite my hatred of "safety levers", I actually went that route for a change. Primarily because the Mafac levers are the only dual lever setups that are effective. I do like having the ability to move my hands on the bars in multiple positions, and the Mafac safety levers will actually work on a panic situations almost as well as the main levers.
On to another 5200 miles.
Syke
Syke
#1812
Liked 2,476 Times
You don't have to leave it overnight. Steel is not like wood. Once you bend it, the bend is permanent.
#1813
Liked 650 Times
This is primarily aimed at eom as I found out its a heck of a lot more difficult to post a picture to a private message, but if anyone else out there has a lead, it will be appreciated:
#1814
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
#1815
Quoted: 221 Post(s)
Liked 237 Times
That's not a S-A part, it looks like a cable end part for the rear stay on a derailleur bike (holds the piece of cable casing just before the rear derailleur). It might, if I don't find the actual part.
Syke
Syke
#1816
Quoted: 221 Post(s)
Liked 237 Times
Only the British . . . . .
Syke
Syke
#1817
Liked 1,752 Times
This morning, I drove into the city to pay for this Torpado and Atala...
When I got home, I took another step in the evolution of my Grand Premio...
It took a bit of doing to get the Simplex rings in place but the NOS bottom bracket was a smooth bolt in and good to go...
This is drive train and transmission #3 and I do hope that it is the last one needed...
The older worn a bit saddle was replaced today with this lovely NOS Brooks that I bought a year, or so, ago and not knowing where it was going to be used. Now I know...
The Legnano is to be this summer's rider, however; I am not sure that my old legs have what it takes to be comfortable with the gearing...
#1818
Quoted: 1199 Post(s)
Liked 1,355 Times
Torelli Cicle de Vince just got sakae world champ bars and NOS 6207 I've been storing for this occasion.
Gios Torino got old style logo cinelli bars and SR levers
#1819
Quoted: 76 Post(s)
Liked 19 Times
Most of the morning was spent trying to figure out why the ST6400 shifter I had picked up wasn't working. Pretty sure that there is C shaped spring that is broken.
This afternoon I replaced brake pads on the Prelude and my Finest and also couple of bikes that we are getting rid of.
Peeled some stickers and cleaned up a couple of rims for the Prelude.
I also spray painted a rigid fork for a Cannondale M400 That I'm putting together.
#1820
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
Working on selling my '91 Cannondale SR800. The very probable buyer for it missed out on another '91 Cannondale (that I was originally selling), and I told him I had a frameset that I could build up if he wanted. Gave him a solid price on what I could built to, and he was/is game. He'll get a lot of beautiful bike for the money, and I'll make $10-20 on the whole endeavor while pocketing invaluable experience. Win-win. I love crafting bikes, man. This SR800 is going to be a stunner!
#1821
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
I wanted a couple more millimeters clearance under the front caliper to feel comfortable with 32s on this bike. The caliper was the pinch point. A washer, Dremel and hand file got me a wedge, a few degrees, and a few mm. I'm pleased.
#1822
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
"Converted" my Raleigh Pro MKI to 700c tubulars and lost 1.5 pounds overall weight! Had just enough reach with the Weinmann center-pull brakes to hit the rims dead center. Will add a pic after today's shakedown ride.
Pic, as promised. The "shakedown" ride was at just over one mile in progress when I heard a soft "ping." Sure enough, one of the rear spokes had snapped. Merde.
#1823
Liked 6,388 Times
Brilliant! Seems like the inverse could get you some more reach where clearance isn't a problem.
#1824
Quoted: 1143 Post(s)
Liked 1,753 Times
I managed to find an Italian wheelset for the Club Fuji. They are Nisi Mixer 28 spoke on Miche "Superfast" hubs. The Mixer rims were a most difficult tire mounting, I had to tire jack the Continental tires on both sets of beads, I did it! Those are the new, "pain in the ass" king Ambrosio Elite now seem simple and easy. I also installed a Campy BB with a Suntour crankset, with Suntour Cyclone 7000 pedals.
#1825
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
This doesn't qualify as wrenching but it's a wrenching story (ahem). For my Bianchi Alloro restoration I wasn't thrilled with the selection of Alloro badges . Plus I was not getting any love from Velocals or Cyclomondo not even a email back . Calling around town I finally found this place called Sing-a-rama the owner was a total jerk but the guy doing the art work was cool . Anyhow here is the outcome . Oh by the way alloro is Italian for laurel .
IMG_0336 by mark westi, on Flickr
