3x drivetrain on road bike
#151
Quoted: 3241 Post(s)
Liked 2,512 Times
#152
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
Funny thing is, with my 10 and 11 speed bikes, I've occasionally found myself all the way in 'Biggie Bigs', because the range is so wide on a single chainring with a big cassette.
#153
Liked 2,512 Times
2 weekends ago I swapped out the middle 40/42 ring to a 36T as I always do for this ride. Talk about gear choices between the rings and the cassette. It got hot! I didn't go onto the granny until that short steep one around the 70 mile mark. Glad I had it after that. Really struggled to finish in the heat.
https://ridewithgps.com/routes/29030456
#154
Liked 11,912 Times
Likes For genejockey:
#155
Quoted: 3953 Post(s)
Liked 7,302 Times
#156
Liked 7,302 Times
#157
Quoted: 2333 Post(s)
Liked 2,097 Times
Haha, what?!?! 10sp isnt modern? Tiagra is on carbon road bikes that cost $2500-2600 from major brands. Its on $1800 alloy frames. There is hydraulic braking, thru axles, carbon frames...but 10sp isnt modern?
10sp is not cutting edge. 10sp is not leading tech. But 10sp is very much modern and current.
This is a classic time to use the Inigo Montoya meme. "You keep using that word..."
https://www.specialized.com/us/en/ro...=293288-184477 $2600
https://www.specialized.com/us/en/ta...=293448-175300 $2500
https://www.cannondale.com/en-us/bik...-carbon-tiagra $2625
10 Speed Mechanical is so....Y2K
Modern is electronic. Better yet would be an AP that shifts for you.
#158
Liked 2,512 Times
The race director bumped into Floyd Landis at a ride down in the Carolinas, I think. He hooked her up. Check out the swag each rider got. Sweet!
#159
Liked 2,512 Times
I'm sure it can. Not every rider is a 140 climber, though. I'm certainly not. About all I see there are long cage RDs and big clusters, at least from the riders that aren't 1st timers.
#160
Liked 11,912 Times
Climbing in the heat and humidity of late-spring Virginia? What's not to like?
#161
Quoted: 4415 Post(s)
Liked 4,867 Times
Why would I want to? All I care about is less front shifting (because it sucks) and enough rear cogs to make the gaps sensible for the range I need. 2x12 works well in both those respects. Certainly better than any 3x7. As discussed with @Carbonfiberboy 3x9 or 3x10 will always offer either more range or closer gaps between gears, but at the cost of more front shifting.
Now if your priority is to minimise the number of shifts across the range regardless of whether they are front or rear shifts then I guess we have completely different priorities. As it happens I could probably shift right across the cassette under power faster and smoother than you could make 2 clunky shifts across your 3 chainrings. Rear shifting is pretty sublime on a modern 12-speed (mechanical or electronic) while front shifting is pretty much as it was 20+ years ago i.e. slow and clunky due to the inherent limitations. This is why engineers are working on feasible hub gears to replace front shifting - because they know it sucks. The other approach is a 1x which is ideal on a mountain bike, but the range and gaps remain a sticking point for road use.
When you said that 3x10 gave no real advantage over 3x9, you inadvertently stumbled across the reason why triples are now virtually extinct with 12-speed drivetrains. 2x12 is enough gears for almost everyone and most people appreciate less front shifting.
#162
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
As I said before, what I hated about the 10-speed compacts was all the endless mechanical shifting of the rear just trying to find a usable gear - and back onto my wheel they'd come. That rather put me off doubles. The big 12 speed cassettes solve that.
With the triple, to accelerate from a steep hill onto a gentle descent for instance, it's 2 shifts up in back, then one in front and two down in back simultaneously, then up through the middle ring for 7 shifts, then to the big ring and two down in back simultaneously. I just hit both shifters at the same time - it's automatic now. It's not so bad and all close jumps. Coming into a hill, I spin 100 and hit the shifter(s) every time it drops to 90 until I'm in my final gear and at my climbing cadence.
I remember when we took our tandem on our first tour, near the end of the 70 mile first day, my right wrist was toast. That's a long cable. I just wasn't in shape yet. I don't it notice anymore. My left wrist never gets tired as I do comparatively little front shifting. Riding the tandem in moderate rollers, I keep it in the big ring all the way down to the 3rd largest cog of our large cassette, then I shift to the middle if I have to. Tandems are good at converting kinetic energy into potential energy.
Results matter
Results matter
#163
Liked 2,512 Times
#164
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Again though you are confusing the term 'modern' with the term 'leading edge.
After a response, I see you are either being intentionally obtuse to just troll or you genuinely aren't able to understand what some simple terms mean. Either way, it isnt worth continuing.
#166
Liked 7,302 Times
#167
Liked 4,867 Times
Those are very good points. It hadn't occurred to me that the main use of 12-speed cassettes would be to make the total range wider rather than to make the gaps narrower. Now you're kinda riding like we used to with half-step. You mostly just shift the back. What you need now is electronic fine tuning so you hit the button and the whole drivetrain shifts itself to go up or down 1/2 step. Then you'd be getting some serious close range gearing in that 10-25 mph most-used range. Those servo RDs do slam the chain onto the next cog right quickly. Not as nicely as half-step though. I wonder if that would work.
https://www.gear-calculator.com/?GR=...28,33&UF2=2161
I've also experimented with auto-compensating shifts on the electronic setup i.e. when shifting the front, rear auto-shifts up/down 1 or 2 cogs to reduce the gap. But it caught me out a few times when getting hard on the power before the shift was complete, making that horrible crunch! So I switched that function off, so it just makes a front shift only. Rear shifting alone is as good as instant and I have it programmed to make double rear shifts if I hold the selector down.
Likes For PeteHski:
#168
Liked 11,912 Times
No, everyone has to do what I prefer to do. Don't complain to me, those are just the rules.
#169
Liked 4,867 Times
Yep, we can agree on this. Modern electronic drivetrains have simply made rear shifting so quick and effortless that you don't care how many rear shifts you are making. But unfortunately the front is still a bit of a let down in comparison, so better if you can avoid it more often.
Likes For PeteHski:
#170
Liked 7,302 Times
#171
Liked 4,867 Times
I agree. But in relative terms front shifting is still night and day less efficient than rear shifting. Being pragmatic about it I am very happy with modern 2x road drivetrains (they've come a very long way since I started riding 40 something years ago), but if I was looking for a significant improvement it would be something to replace the FD and multiple chainrings. I would love to try the Classified Powershift hub for example.
#173
Liked 7,302 Times
#174
Liked 2,097 Times
10sp Shimano wasn't 2003. And it was the most until '13.
Campy introduced 10 speed in the year 2000 or Y2K as I wrote. Shimano was not far behind.
I am not being obtuse or a troll. 10 speed is old. Not modern. Sorry if you do not like what I wrote but calling me a troll is weak.
#175
Liked 2,097 Times
Compact cranks did not just appear with gravel and 11 speed cassettes.
I had a 46/32 on my 5 speed freewheel touring bike in the 70's and early 80's eventually putting a triple on it. I used to see compacts all the time in France and England when touring there.
Depending on the 3 ring tooth range, it can be very hard to find a FD that shifts well. On recumbent with a triple, I was shifting something like 56-44-28, and all the new little itty bitty cages could not handle that well. A big ole Shimano Deore did it just fine.
