Totally Tubular
#2476
Quoted: 4806 Post(s)
Liked 3,931 Times
Good observation! The lump is actually a spot where the tread is separating from the casing. The casing is is holding up great which is why I want to get many more miles on this set. I've only flatted once on the road with this set, put on my butyl spare training tire, but once home I used the Stans and remounted the tire. Works like a charm. (well two months later I needed to refresh the sealant).
So shoe goo is the way to go? I was just thinking vulcanizing cement like in the patch kit. Thanks!
#2477
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I got a cut on the tread of this tire. And it's opening up when I scrape the tire with my thumb. So I'm sure it will load up with debris as I ride. So my thought was to remove the tire and glue down the tread then remount it so it rolls in the opposite direction. Is there anything wrong with this approach? It's on its third season but this bike is not my regular ride. Thanks
I strongly suspect that the casing here is suffering an outer-ply failure, which is why the casing bulges on each side, but in different locations coinciding with the diagonal path of the outer ply's cords.
#2478
After double checking I'm pretty sure the casing is still good. The tread has become separated near the slice but that occurred before the slice. Though I ride at 89 psi I pumped it up to 115 with no signs of bulging. Tire is a Challenge Strada 28x24. Thanks for noticing.
#2479
Bikes: many
Quoted: 1444 Post(s)
Liked 1,394 Times
Tread separation is a known problem with Challenge tires (tubular and clincher). It would seem they've yet to solve it, though one never knows how old a tire is. It's not like they have a "use by" date stamped on them.
#2480
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
Storing Spare Tubs
I guess I seldom have new tubs hanging around, but just now I have 2 new Sprinters on spare GL330s inflated to 50psi.
How long do people store sewups this way, or once stretched do they fold them and put them back in the box. I’m inclined to leave them on the stretching rims indefinitely, periodically checking pressure.
#2481
Quoted: 1951 Post(s)
Liked 2,013 Times
When I take them off the rims, they go back to pre-stretched condition. Especially Sprinters. Luv that Sprinter-330 combo..
#2482
Quoted: 167 Post(s)
Liked 92 Times
I guess I was wondering what the detriment of the basement environment and always being partially inflated would be on the tires as opposed to being put back in their box. Inflating them and hanging them, I have shown myself that they hold air.
#2483
I have a spare, unlaced Ambrosio rim, so I always have a brand new Conti mounted on it. Inflated. Never looses air.
#2484
Liked 3,931 Times
I made a rack that holds tires in an oval like a long skinny auto racing track. Roughly 33 1/2" by 7". Holds about 20 tires. I put a gap in the center so you can drop a middle tire into the gap and easily work it past the rest to get it off and leave the rest undisturbed. Tires aren't "stretched" but do have all wrinkles and creases pulled out. Hanging in the garage out of any sunlight. My guess is that tires stored there should last until the rubber fails from ozone. (Plenty of powered shop tools but no house-hold motors or pumps. No engines of any sort,)
Now I just have to start building some more wheels to put them on. I'd like to have two pairs available per bike. GP4 and GEL330 or older Arc en Ciel. Biggest tire (or 28c+) that the bike can handle and a sweet and fast lighter tire. Sadly, one bike is stalled because that bike needs a rim with a deep sidewall. I picked up several Mavic CXP30s but the seller has misplaced the special washers they need for the spokes (and when Mavic announced the retirement of that rim, he bought all of Mavic's stock). So if anyone here has 64 or 96 or so of those washers lying around and generally getting in the way, I'll take them off their hands. (For the TiCycles fix gear of my avatar photo. I slide the wheel the entire length of the dropout to run from 12 to 14 teeth. Pad height relative to the rim changes a lot. Velocity Aeros have just enough depth to work. (No accident. The dropout angle was chosen so they would work.) GP4s and the like needn't even apply for the job.
I could cuss out the seller but he has done a lot for me. I knew what I was getting into and he added (at real cost but peanuts vs value) a pair of GEL330 wheels he built for his step daughter to take to the track nationals. Gorgeous gold Japanese track hub, double sided (I'd have to go out and look to recall the name but absolutely top of the line) built by a master wheel builder (him) with spokes tied and soldered perfectly. They've been ridden but never seen either pavement or a brake shoe. I'll be desecrating them taking them on the road, but I'll also be riding them in honor of a woman I consider a warrior and almost a sister. I've both watched and heard from her step dad how hard she worked to return to top form after nasty crashes. (I've been there.) She's retired from racing, the velodrome has been sold and will be ripped up. Her step dad's retired. And her wheels will go on under someone who knows what they are and cares where they came from. I think the gods will approve. (I've got Corsa Speed 25cs to glue on. I think they'd approve of that also.)
#2485
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
Totally Tubular
New sew-up wheels and tires:
Vittoria Corsa Control sew-ups
I saw a pair of unused tubular wheels on ebay, at the bargain price of $109. Silly me. Long story short - both were dished wrong, pulled an eyelet on the rear Weinmann Carrera, and replaced it with a FiR ST120. The Vittoria Corsa Control Graphene 2.0 front 30mm measures at 29, and the rear 28mm measures at 26, which gives me 4 to 5mm of clearance instead of 2 to 3.
The Zeus hubs are really graceful looking, and I went ahead and bought a Regina Oro French threaded freewheel (!) to be able to ride them. It needs a spacer, which I have, and the day after tomorrow is supposed to be sunny...
Likes For Fredo76:
#2486
Bikes: HVZ Meteor 1979, HVZ Champion 1962, HVZ SS Moskva80 1981, Dürkopp 1936
Quoted: 41 Post(s)
Liked 350 Times
New Tufo S33 Pro-s for the upcoming season. Imo the best cheap tubulars out there.
Likes For geeteeiii:
#2487
Quoted: 2338 Post(s)
Liked 2,827 Times
Merlin has some good prices today
veloflex raven 28 mm $44 https://www.merlincycles.com/en-us/v...0c-200100.html
of course there is shipping at 25 bucks or so
#2488
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
squirtdad I've seen Rally's priced higher than those Veleflex Raven tubulars! That's a great deal.
Speaking of which--- I Know it's a RALLY. Is it Worth Regluing the Base Tape?
I was finally able to replace the broken spokes on my vintage Roval rear wheel. Thanks to seagrade I received replacements from New Zealand!
Of course I had to demount the Vittoria Rally to replace the spokes. When I got ready to remount the tire, I noticed the base tape separating from the tire casing. Upon closer inspection, I realized the tape was coming off the complete circumference of the tire on both sides. Interestingly, the center, over the seam, remains glued securely.
Is it worth regluing? If so, regular tubular glue or something different?
At the time, I set this Rally aside and mounted a new one I had and the wheels are ready to go back on my Lotus Super Pro Aero.
Bob
Bob
Likes For pastorbobnlnh:
#2489
#2490
The Wheezing Geezer
Quoted: 414 Post(s)
Liked 920 Times
In Olden Times, re-glueing base tape was a job for Barge. I would think it would be worth doing, even for just a spare. Not sure they sell Barge in small quantities anymore. I sure don't need a gallon...
Likes For Fredo76:
#2491
john903
Bikes: Curtlo, CHE cos'e,
Quoted: 27 Post(s)
Liked 36 Times
Use the Rally as a spare. Those Veloflex Ravens are fantastic tires. Buy 4 from Merlincycles to help make up for the shipping and enjoy really nice tubulars.
Imho of course, but really they are a world of difference. Oh is the freewheel spa open for business yet?
Have fun.
Have fun.
Likes For john903:
#2492
Freewheel Medic
Liked 2,196 Times
Have fun.
Have fun.
Yes, the Spa is open and accepting freewheels in need of rejuvenation!
Bob
Bob
#2493
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Same price for the last 9 months at least.
That's what I'm riding and they're fine so far.
#2494
Mounted my first tubulars yesterday! Merlin ships fast. Got covered in glue but went pretty well overall I think. Excited to try these out.
Likes For dukeofearl:
#2495
Quoted: 1608 Post(s)
Liked 2,216 Times
@pastorbobnlnh - Tire alert in FL will do just the base tape. You should use something stronger than typical tubular glue so the base tape doesn't get confused when you next remove the tire from the rim!
Likes For SJX426:
#2496
Freewheel Medic
Liked 2,196 Times
Bob
Bob
#2497
Liked 2,216 Times
#2498
Quoted: 1163 Post(s)
Liked 442 Times
Zeus hubs are definitely classy ! But I just wanted to give you props for a great vinyl record storage system !
#2499
Quoted: 189 Post(s)
Liked 473 Times
Does anyone have a source for narrow (14mm) tubular gluing tape? Everything I see is wider, but I think for vintage rims it needs to be no wider than 14mm. I’m looking for a shop size roll - for maybe 12 wheelsets.
#2500
Liked 3,931 Times
I never used it for base tape. Didn't know about it when I last used them. So, thanks! (That Barge - good stuff.)
