Endurance vs. Race Geometry
#101
Quoted: 4421 Post(s)
Liked 1,568 Times
A few questions, if you don't mind:
A couple more questions, again if you don't mind:
- When speaking about the Madone, are you referencing H1 or H2 geometry?
- Why do you consider the Addict to be a race, rather than endurance model? Let me quote the manufacturer's description: The all NEW SCOTT Addict 10 was redesigned from the ground up with those longer days in mind. With new geometry that is less focused on racing and more on enduring, [...] the Addict 10 will be your go to when you're looking to put the miles in.
- Where are you getting the Kestrel RT-1000 geometry from, and which size are you checking? In size L I see 185 mm head tube and a 555 mm top tube for a 1.56 stack to reach ratio - definitely not something I would call a short or low head tube.
- Why do you consider the Roubaix, a bike that defined the endurance subtype, to be a pro race bike? True, it is used for one race a year, but you'll hardly see any pro racers on the same geometry that's actually marketed to buyers.
- Don't you think that using the Cervélo in this discussion is a little disingenuous, considering the fact that it is an outlier that was intentionally designed in opposition to what other manufacturers are doing? See here: https://gerard.cc/2011/08/08/body-po...height-part-3/
The size large RT-1100 has a stack of 565 and a reach of 395 for a ratio of 1.43. That's from Kestrel:
Kestrel Bicycles | Road | RT 1100 Series - RT-1100 - SRAM RED eTap
I used Madone H2, not even H3. H1-H3 are all considered race bikes by Trek. They have a different model, the Domane, that provides a high end endurance.
If the Addict is no longer a race bike, then we'll take it off the list. Done.
I don't think Cervelo is "disingenuous" any more than the taller Madone is. These are some of the top pro racing bikes out there, have been produced for many years with this same geometry and they sell really well. How could a winning pro race bike that sells well be a bad example if fits like the Emonda?
It would be nice to be able to disqualify the Treks, Kestrels and Cervelos from the discussion to make some sort of different point about geometry, but the fact is that the Madone, Domane, Cervelos and RT-1100 ARE racing or endurance bikes, even if you don't wan them to be. And it really just takes one to break the "rule" before you say "that isn't a good rule."
Originally Posted by Racing Dan
What does it matter what manufactures call their frames. Its just marketing and Im betting you can find a number of "race" frames with upright geometry and likewise a number of "endurance" frames that are more racy than the next brands race models.
#103
Thanks for the responses.
For some reason I read the Kestrel model as RT-1000 in your posts. But yeah, there are some problems with the RT-1100 geometry too that are bugging me: Take a look at the top tube and head tube measurements for size L. I see 565 and 195 mm - just looking at the numbers, they seem to clash with the declared stack and reach measurements. I entered the provided numbers into the bikegeo.net calculator and it gives 598 and 388 mm for stack and reach (plus or minus a few mm for the fork axle-to-crown height guesstimation), for a ratio of 1.54. To achieve anything like the declared stack and reach measurements it would have to have the fork length of less than 340 mm, hardly likely for a 700c wheel bike.
Regarding the Madone, yes, I would say that using the H2 geometry in this discussion is just as disingenuous as using the Cervélo. It is a widely known and promoted fact that these geometries are primarily adapted for recreational and casual riders, to enable a more upright position than what pro racers would typically ride. The way that I see it, you want to use what was explicitly made to be an exception to the rule, as an argument there is no rule at all (though I would call it a strong and clear trend rather than a rule anyway).
Finally, it's interesting that you are so strict when it comes to the "rules" of race vs. endurance geometry regarding rider positioning, yet you are quite a bit more lax regarding handling. Take a look at that Kestrel RT-1100 in size L. I see 405 mm chainstay length, 988 mm wheelbase (another questionable measurement though; bikegeo.net calculates it as 993 mm), 69 mm BB drop, 73.5 degree seat tube, 73.2 degree head tube, 57 mm trail (or 55 mm, per Bicycle Trail Calculator | yojimg.net)... All the numbers point to an aggressive, sharp handling race bike, except for that unusually tall head tube which enables a more upright position. Shouldn't you argue then that there is no discernible distinction whatsoever between race and endurance bike geometries?
Amusingly enough, I have very little to disagree with in your response to Racing Dan.
#104
Liked 1,568 Times
Are the Emonda, Madone H2 or Cervelo race bikes or not? If not, are they endurance bikes? If neither, what category do you want to invent to put them in?
Because if someone asked me for an endurance bike recommendation, it sure wouldn't be a Cervelo R5.
Originally Posted by Kontact's first thread post
It is a fairly meaningless claim. Some "endurance" bikes have race geometry, but more headtube and some sort of softer ride. Some race bikes have the same, or even "relaxed" steering geometry.
The flip side is that no one is making race bikes with radically tight geometry any more. The minimum chainstay length is 408, while 399mm chainstays weren't unusual 10 years ago. The old Lemond bikes were pretty much described as "bikes for spending all day in the saddle", but today are considered to have very racy geometry.
All of this is so gray that the final product matters much more than the geometry, and we normally credit bike manufacturers with knowing what they are doing. So if Trek says that the Madone is a race bike and Kestrel says the RT-1100 is not, that's the end of the debate.
#105
Liked 1,568 Times
Just to add an additional wrinkle to the stack part of the discussion, one reason a real racer might buy an H2 Madone is that it is excellent geometry for those with short torsos and long legs. Tall head tubes allow those folks to emulate low race bikes because they have more seat post showing than the average rider. They get a much better fit than using a regular low race bike with short stem.
#106
Quoted: 1067 Post(s)
Liked 259 Times
#107
A proper bike fit (seat height, reach, bar height, etc) should be the same on either a race or endurance bike. With a taller head tube, an endurance bike may have less spacers under the stem if you need a more upright position; that would be the most visible difference. What you can't see if the feel - a race bike has tight geometry and can feel twitch when compared to an endurance. A race bike might (not always) have higher grade carbon and a stiffer feel for maximum power transfer. The difference is noticeable, but not extremely so. There will also be similar difference between manufactures, and for wheels. Personally, while I'm still racing masters I'll be on a race bike. But when I finally give it up, I'm sure I'll trade up for some comfortable Ti model with disc brakes & plenty of stability.
#108
Liked 1,568 Times
#109
Personally, no. The bar height and reach on my crit bike is identical to my road machine, and to my gravel bike. I've messed up my back before just changing bar height too much at one time. At least in my experience, consistency matters.
#110
Liked 1,568 Times
But I wouldn't want to have the same position otherwise and 10cm of extra bar stack with one bike.
Likes For Kontact:
#111
How about stepping away from charges of disingenuity and just deal with the reality?
"Strict" and "lax"? Have you read my posts?
The only thing that I am "strict" about is that you can't reliably label bikes between the two categories on geometry alone. If a manufacturer makes a bike with "race geometry" that rides like an endurance bike and they call it an endurance bike - it is an endurance bike. No amount of post-game analysis is going to make it not an endurance bike. And this has been going on in bike construction for many years before anyone coined the term "endurance".
See, you are contradicting yourself here. In one post you say Endurance bikes are primarily about steering and ride, not a different type of fit. In another (and thanks for pulling this quote, I did indeed miss it) you say Some race bikes have the same, or even "relaxed" steering geometry. Finally: And it really just takes one to break the "rule" before you say "that isn't a good rule."
Then you disregard manufacturer's own classification of their bike (Addict, Roubaix), you proclaim that a bike with a bike with 195 mm head tube for a 565 mm top tube has a low head tube (RT1100) and you use bikes that are known and promoted for being unusual (R3, H2 Madone/Emonda) all in order to deny a clear trend as if it was a mathematical theorem that can be disproven by a single counterexample.
I'm starting to think that you are just trying to win an argument here, rather than share information.
So, a few new questions, if you don't mind:
- From your quotes above, you seem to feel neither fit nor steering are reliable parameters for differentiation between race and endurance bikes. What exactly are race and endurance bike categories about then, in your opinion?
- When you describe a race geometry bike that rides like an endurance bike, what exactly do you mean by "race geometry" and what exactly do you mean by "rides like an endurance bike"?
- How would decide which bike to recommend if somebody was looking for an endurance bike? If I understood you correctly, you would exclude anything defined as a race bike by the manufacturer, but would you simply include anything defined as an endurance bike?
On a side note, [t]he minimum chainstay length is 408 - is this a typo?
Likes For Fiery:
#112
Liked 1,568 Times
You seem to think I'm trying to somehow redefine and re-assign bike categories, but that is not my intention at all. I simply disagree with those arguments in your posts that are factually wrong or disingenuous in my opinion.
On a side note, [t]he minimum chainstay length is 408 - is this a typo?*
I'll say that again, so it sinks in: Endurance bikes are not simply their geometry. And that's why I asked you what an Emonda, Madone H2 or R5 are if you think that they aren't race bikes because of their geometry - they are still race bikes. Because, again, geometry alone is a poor guide. We can only say what is typical about the geometry of either style but any geometry based definition is going to fail, as those models did for you.
Endurance bikes are those that feel and ride like endurance bikes. Geometry does not produce "ride". Ride qualities come from the way the bike absorbs vibration and transmits shock or energy. If a company puts out a low bike with a shortish wheelbase that has a soft ride, is easy to steer, and then calls it an Endurance bike, isn't it an Endurance bike? Just as Trek, Cervelo and others call bikes you don't want to talk about Racing bikes.
As for you nit picks, I already addressed putting the Roubaix and Addict in the wrong categories. Again, I missed their manufacturer categorization - which is what matters. Steering geometry doesn't define endurance. Fit geometry doesn't define endurance. The manufacturer defines what bikes are endurance and what are race.
One more time: Endurance or Racing bikes aren't defined purely by their geometry. They often have certain geometry characteristics, but not often enough to make a rule. The rule is what the manufacturer decides the bike is, defines what the bike is. No amount of objections on your part are going to turn an R5 with its tall head tube into an endurance bike.
*(Should have said 405mm. Extremely rare to see road bikes under that number any more.)
#113
Funny, I got a similar vibe from you posts - that you take descriptions suggested by other people and treat them as absolutes. After all, you are the one talking about rules here. Looking back, I see that you are actually fond of giving strong, absolute-sounding statements, and then backpedaling when called out for it. See this: There is nothing about racing bike geometry that prevents any owner from sitting in the same position as an endurance bike followed by this: I wasn't suggesting a rule that works on every bike - I was pointing out that a very large number of racing bikes do not force the rider to bend low - at all. And it is inconsistent phrasing that can make it hard to understand what exactly your position is when Endurance bikes are primarily about steering and ride and Steering geometry doesn't define endurance, yet Endurance bikes are those that feel and ride like endurance bikes even though actually The manufacturer defines what bikes are endurance and what are race. Could it just be that it's not my reading that's the main issue here?
Now, can we try to clarify this finally? Would it be a problem for you if we say that endurance bikes are commonly designed with a different fit in mind than race bikes? Will you object if we say that endurance bikes are often characterised by a higher stack-to-reach ratio than race bikes? Not suggesting a rule that works on every bike - just pointing out that a very large number of endurance bikes fit this description.
And you keep talking about some objections on my side about Cervélo R-series bikes. Sorry, I'll have to call you out on this now: where, when, and what about exactly did I object? Is me calling them outliers an objection?
Likes For Fiery:
#114
Quoted: 20810 Post(s)
Liked 9,456 Times
Hi! What's this thread about?
#115
Likes For athrowawaynic:
#116
Liked 1,568 Times
The practical application: If you are shopping for an endurance bike, are all the road bikes you encounter with tall head tubes endurance bikes? Emphatically; no. You will run into many H2s, Cervelos and others that would confound such a rule and put you on a bike that is not designed for long, comfortable rides. So it isn't a useful axiom. Which is why I spoke up.
I didn't object to "win" the thread. I agree that endurance bikes are, on average, taller than your average race bikes. But you can't buy an average, so we also have to deal with the discreet model bikes that are actually available, even the ones that don't fit our preconceptions. Buy an endurance RT-1100 because you are looking for an upright bike and you will be disappointed. You need to look at the geo chart.
#118
You are the newest person continuing the objections from when I disagreed that "race bikes are all low and aero and endurance bikes all make you sit upright". And I disagreed primarily because of the many race bikes with tall head tubes makes this an impractical rule.
Whom did you see claiming that all the road bikes you encounter with tall head tubes are endurance bikes? Was it in this thread? I may have missed it, but that definitely sounds like a very strange way to look at things when choosing bikes; normally I see advice that all endurance bikes you encounter will have a tall head tube, which actually is correct in most cases.
Nice that you actually do agree that most endurance bikes fit more upright than most race bikes, since your previous posts gave the opposite impression. It's a shame you are still using the RT-1100 as an example of an endurance bike with an aggressive fit, even though it most likely fits just like a typical endurance bike (and considerably more upright than either a Cervélo or a Trek H2) - you just have to look at the geo chart. Actually, that's an interesting question: which, if any, endurance bikes other than the Domane Classics/Team Edition provide a lower/longer fit that Cervélo and Trek H2, discounting geometry chart errors?
#119
Liked 1,568 Times
I stated quite clearly what I disagree with in your posts, more than once. You are free to re-read if you misunderstood the first few times.
Nor am I going to play a game with you where I provide examples and then you say "well, other than those perfectly valid examples or very common Trek bikes..." They are good examples. Done.
You can't judge a bike to be endurance or not purely by its head tube length. That's all.
#120
I have both an endurance bike and an aero/race bike. The endurance bike is a slightly more upright riding position than the race bike with a stack to reach ratio of 1.45 vs 1.35. Both are very comfortable rides and I can happily sit on both bikes all day. My longest ride was done on the race bike. My preferred bike is the race bike, but that's because I find it more fun to ride. However, the handling is very different on each of the bikes. My race bike is twitchy. When I first rode it, it took a bit of getting used to.
That's all I've got... I don't want to get involved in the willy waving contest
#121
Generally an endurance geometry will have a longer headtube, longer chain stays and more tire clearance for 28-32mm tires.
All this is dependant on the manufacture.
Obviously you could take an endurance frame and run 25mm tires and slam the stem and it would feel just like a pure race frame.
Also : whats the diference on angles between geometries? e.g. The seat stay- chain stay angle is bigger at race geometry?
Race geometry is better for uphills?
Where we can find more information?
Thx in advance !
bikecommuter13
Commuting
98
07-16-15 07:21 AM
rpeterson
Road Cycling
13
06-07-11 03:54 PM
