Addiction 2023.1
#5226
Quoted: 8281 Post(s)
Liked 9,053 Times
#5227
Quoted: 9653 Post(s)
Liked 6,365 Times
#5228
VFL For Life
Bikes: Velo Volmobile
Quoted: 28622 Post(s)
Liked 1,858 Times
#5229
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
#5230
Liked 9,053 Times
I wonder if Indy is watching this game?
#5231
Quoted: 3361 Post(s)
Liked 3,638 Times
#5232
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,531 Times
About an hour north of here, there was enough snow to have a fat bike race today.
#5233
Liked 8,927 Times
#5234
Mostly Harmless
Liked 4,531 Times
#5235
Quoted: 1279 Post(s)
Liked 1,393 Times
when i haven't had an extractor or the bolt was too small, i use a dremel with a small cutting bit to turn the rounded hex or phillips into a deeper flathead, and then unscrew. deeply unsatisfying...
VFL For Life
Liked 1,858 Times
#5237
Liked 9,053 Times
re: your stripped Allen bolt. I would consider grinding the end of an Easy-Out so that it has to be hammered into the bolt. This will allow the use of a much bigger Easy Out than if you drilled a hole in the bolt.
If only one of the bolts is stripped it might help to tighten the other bolt to remove some of the tension on the bad bolt.
You might get lucky trying a Torx bit.
Likes For big john:
#5238
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
#5239
Liked 9,053 Times
#5240
Mostly Harmless
Liked 4,531 Times
Likes For rjones28:
#5241
Liked 6,365 Times
#5242
Liked 1,393 Times
yeah, you only need access to the top to turn it into a flathead, if the fastener is big enough.
but if one doesn't have one of these, probably easier to obtain the correct extractor. i've just found extractors really hard to use on small bolts, whereas hex cap heads often has enough "meat" to operate on.
Liked 9,053 Times
I was thinking of grinding an extractor like this until it has to be hammered into the hex. Probably get a lot more torque on it than if you cut a slot in it and tried to use a flat head screwdriver.
Removing broken or stripped bolts is easy if they aren't tight or cross threaded or rusted.
#5244
Liked 9,053 Times
Likes For big john:
#5245
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
Thankfully I don't have any such cranks installed on personal bikes.
#5246
Bikes: everywhere
Liked 7,695 Times
#5247
Administrator
Quoted: 11971 Post(s)
Liked 6,655 Times
HA! Not one of those so called experts picked KC. HA! Not one.
#5248
VFL For Life
Liked 1,858 Times
#5249
Administrator
Liked 6,655 Times
#5250
Bikes: everywhere
Liked 7,695 Times
Likes For LesterOfPuppets:
