Thoughts/Experience with Handsome Cycles XOXO an X0-1 homage All-Rounder
#351
[QUOTE=jadmt;22870260]can I get a close up photo of your drop out? thanks[/QUOTE]
At least you got a head badge. Which drop out?
#352
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
either rear one or both rear ones. too bad on the head badge did you ask them to replace the badge or did you know it would just fall on deaf ears? I know these are not looked at as high end bikes but for me it was fair chunk of money. Oh well summer is coming and looking forward to doing some 100 milers on it. thanks
#353
I am the reason the frameset prices went down to 420 (419.99). Like I said before: I knew what I was getting into.
Handsome XOXO 49cm V.2 Drive side dropout
Historically, small frames lack metal badges due to headtube size. No biggie. When it comes to drop outs... out of the box you need to check and adjust them straight.
either rear one or both rear ones. too bad on the head badge did you ask them to replace the badge or did you know it would just fall on deaf ears? I know these are not looked at as high end bikes but for me it was fair chunk of money. Oh well summer is coming and looking forward to doing some 100 milers on it. thanks[/QUOTE]
Likes For Teamdarb:
#354
Quoted: 904 Post(s)
Liked 1,899 Times
thanks
#355
Anyone else notice the XOXO is no longer listed on their website? Not even by direct link.
#356
Quoted: 904 Post(s)
Liked 1,899 Times
If you go to their fb page some body posted yesterday that he was an initial buyer from the kickstart and still has received nothing. said he paid and nada. Also someone posted they initiated a legal complaint with mn ag office. Pretty poor way to run a business. I hope everyone that was screwed over gets made whole. I guess I was fortunate that even tho I have had quality issues I at least got mine. I wish I had done more research on them but when you pull up their webpage only see the good stuff.
Likes For streetsurfer:
Likes For jadmt:
#359
Quoted: 904 Post(s)
Liked 1,899 Times
I put the t-servs on and took a little ride. definitely feels more flickable with the 1.5's. on it. I did not plan on going so long and did not bring any fuel so last ten I kind of bonked.no stops once I started and even my bladder cooperated lol.
#360
Any clicky pen spring will work, but obviously a trip to the hardware store may result in stainless option. Also, the drop out screws goes the other way round. The reason will make it adjustible by hand tool less and keep it from backing out. Nice job. I will be going back down in tire width next puncture. The fenders will need a few spacers to keep the look clean. I been doing randonneuring events with mine since March. No one makes a front rack bag easily accessible when using a moustache handlebar. I ended up installing a Wald short basket for the time being.
Likes For Teamdarb:
Likes For jadmt:
#362
You can pick up longer screws at the hardware store too. They are just M3 x .5 in various lengths. Look in the machine screw section.
Example found at Home Depot
Likes For Teamdarb:
#363
Quoted: 904 Post(s)
Liked 1,899 Times
#364
I switch between the bars. The drops allow a better, dare I say, way to exploit a draft. I live on the road. Been traveling since 2011, so long distances are a norm whether it be off or on road, good and bad weather.
Likes For Teamdarb:
#365
Quoted: 904 Post(s)
Liked 1,899 Times
I spend all most all of my time on the ends of my mustache bars so I really probably would be better with drop bars. Heads up if you need tires and like the tservs thebikesmith on ebay has them for a set of two for $71 shipped.
#366
If you spend all your time on the ends of that bar, it would mean you probably ready for an upright bar, higher stack, or shorter stem. If you spent your time in the drop/curve of that bar then I would say yes to a drop bar or you have the right fit.
#367
Quoted: 904 Post(s)
Liked 1,899 Times
Likes For jadmt:
#368
Right. Now slowly think about what I wrote before. Better yet, take a ruler and measure to the end from the saddle and then from inside the drops to the saddle. The furthest point is the drops, not the ends.
#369
Quoted: 904 Post(s)
Liked 1,899 Times
correct, I am probably referring to the ends as the drops or just combining the terminology. I also use the hoods a fair amount.
#370
You have it right to call the ends drops. However, in this bar use case I view it as a flat bar with bar ends and aero extensions. The "drops" being bar ends and the ramp of the drops as the aero extension. That is on me with the rouge terms.
Likes For jadmt:
#372
Wow, the bees and gnats are going to love you.
I came up with a good/bad idea the other day in ordering some frame tubes. The 28.6 top tube on this 49cm frame is just dumb. I ordered a 25.4 (0.7-0.4-0.7 mm walls) top tube and thinner walled seat tube. I do think it would be more advantageous (sp) to just have the entire rear triangle redone in smaller diameter tubes. We shall see where this goes.
#373
Quoted: 904 Post(s)
Liked 1,899 Times
#374
Tubes are cheaper than frames. Zap! Zap! Done.
