Addiction 2022.2
#5176
Quoted: 3361 Post(s)
Liked 3,638 Times
Finally got a new phone today.
I’ve been using an original Google Pixel for years but the battery has absolutely tanked and will only last reliably maybe 2-3 hours.
So now I have an iPhone 13. Feels a bit awkward after using a Google device for so long but I’m slowly getting used to it.
Needs a camera test though:
#5177
VFL For Life
Bikes: Velo Volmobile
Quoted: 28634 Post(s)
Liked 1,858 Times
#5178
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
That's probably how it came off the guide to begin with. The simplest solutions are the most effective.
Here's another one. Rear derailluer in the biggest cog. Front in the smallest. Look at the gap between the inside front derailluer plate and the chain. Use the low trim screw to move the derailluer outwards until it solidly makes contact with the chain.(likely you will turn it in, right tighty) Make sure the shifter is in the low gear position (small ring). Loosen the pinch bolt for the cable. Just enough so that you can pull on it and it slides, but not enough that it comes out. With you right hand pull on the cable until the slack is out of it, and tighten the pinch bolt with your left hand. Once you get the bolt snug and the cablefree of slackness take the pinch bolt from snug to tight. NOW. Go back to the trim screw and loosen it a bit. The derailluer will move inboard away from the chain until the cable is holding the derailluer in place. Ideally you want the derailluer sitting on the trim screw with the cable tensioned lightly. It takes a little practice but I believe you can do it.
Just so you aren't confused there are 2 trim screws each one prevents the derailluer from going past a certain point. They are normally labeled. H, L or if you look at the parallelogram you can see them contact the stops when you move it from small to large and back.
So when you are done you just want enough clearance between the chain and inner plate so it doesn't rub when you pedal.
Good luck..........You got this!
#5179
Should Be More Popular
Quoted: 22606 Post(s)
Liked 8,929 Times
Western Carolina University? Kudos.
What kind of plant is that? I never got a plant upon graduating.
#5180
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#5181
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1412 Post(s)
Liked 971 Times
If it is anything like my cat, that belly is a trap. You go for the rub and suddenly get the full pounce, chomp and disembowel treatment.
vBulletin: snafu
Likes For gnome:
#5182
Liked 3,638 Times
Rest assured that the belly is rubbed at every opportunity.
Francis is very docile. It’s our little tabby that likes to draw blood.
Likes For abshipp:
#5183
Quoted: 20810 Post(s)
Liked 9,456 Times
This Mavs v Suns score is absurd.
Likes For WhyFi:
#5184
VFL For Life
Liked 1,858 Times
Tough night for LesterOfPuppets Suns.
#5185
So it is
Quoted: 11404 Post(s)
Liked 4,761 Times
Likes For LAJ:
#5186
Liked 3,638 Times
In bike related news I have new tires on the Holdsworth. I’ve had 28mm Gravelking slicks for the last ~2k miles with no punctures but the rear has gotten pretty squared off.
I went with Michelin Power Road in 28mm. I’m hoping for a bit better feel than the Gravelkings since they have a 120TPI casing. They sure feel nice in the hand.
Likes For abshipp:
#5187
Liked 9,456 Times
#5188
Quoted: 18424 Post(s)
Liked 15,582 Times
Likes For indyfabz:
#5189
Liked 3,638 Times
Great pic. I also had to bite the bullet. After getting hosed one more time with Verizon, I went with an unlimited plan with T-Mobile. Being "not a Yute" paid off, and I'm saving big money with that. They also basically swapped out the most crappy of crappy iPhone 11 for a 13, and the first thing I did was take pics. It's all so much better with the 13. I can also get 5g internet for 30 a month. I'm looking at that. Again, surviving long enough to race 60+ has its perks.
My last phone had such terrible battery life that i would need to turn it on airplane mode before any of my rides and even then it wouldn’t last for some longer ones. Forget about getting any interesting pictures either.
#5190
Liked 15,582 Times
I have a hard time turning off the Live Aid concert portion of “Bohemian Rhapsody.”
#5191
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12784 Post(s)
Liked 7,697 Times
On this day in history. May 19, 2019: Edwin Jackson becomes the first major league player to play for 14 teams.
#5192
Liked 3,638 Times
Likes For abshipp:
#5193
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
Today was rough. I ended up going down three times. The first time, I was riding back to my car from packet pickup, some guy wasn’t paying atttention coming around a bend and pushed me into a field. Said field had 3 foot deep potholes in it and I went over the bars. Crash two was on some stupid rooty rocky muddy single track that I would really only classify as dangerous. Lost traction and went down against some rocks- my right cleat got stuck and I twisted my knee all up. Crash three was pretty much the same, just an even worse segment that took out about ten people in my near vacinity.
My knee, shoulder and hip hurt so bad that the rest of the day was torture.
I had a ton of mechanicals and probably wasted about an hour dicking around with them. I’m really disappointed in the outcome, but it’s over at least
#5194
VFL For Life
Liked 1,858 Times
Likes For Velo Vol:
#5195
Quoted: 9656 Post(s)
Liked 6,366 Times
Seems the Suns are about to set in Phoenix.
Likes For Mojo31:
#5196
Fat n slow
Liked 2,085 Times
Likes For phrantic09:
#5197
So it is
Liked 4,761 Times
#5198
Quoted: 8287 Post(s)
Liked 9,064 Times
#5199
Liked 9,456 Times
#5200
VFL For Life
Liked 1,858 Times
