Birdy thread
#2126
The stoppers on my Ti Birdy from Pacific Cycles are the same as on the Birdy 3 but with a completely different adjustment, much longer out on the Ti Birdy.
There are two stoppers on the Birdy, one fo the fold of the rear arm, one for the seatpost, which stopper is screwed in all the way on your Birdy ?
On my Birdy 3, the one for the seatpost is screwed in all the way and has no adjusting nut, the one for the rear arm folding not and has an adjustment nut.
#2127
Quoted: 463 Post(s)
Liked 567 Times
Ok, this is the Litepro one I need which costs 5x the price of other Litepro adaptor lol. I guess anything Birdy costs extra.
#2128
Quoted: 463 Post(s)
Liked 567 Times
Example of straight on image:
GS on 53-406
Your GS RD looks like an pre-2017 Deore with a max cog capacity of 36t. Nowadays and since 2017 Deore GS has been able to span at least 42t.
#2130
Quoted: 463 Post(s)
Liked 567 Times
#2131
Quoted: 463 Post(s)
Liked 567 Times
Just wanted you to know how much things cost here closer to the manufacturer and how much you are getting price gouged over there in Europe. The part will, of course, be even cheaper in the PRC.
#2133
Quoted: 800 Post(s)
Liked 247 Times
What would be helpful is a straight-on image of the rear wheel and the RD so we could actually gauge ground clearance.
GS on 53-406
GS on 53-406
The stopper for the rear arm folding is circled in red in the picture below which also show the position of a Shimano Ultegra RD-R8000-GS derailleur on the Birdy with 50x355 tires in its worst case position (the cage is the closest to the ground on the cogs in the middle of the cassette, its higher on the biggest and smallest cogs, on your picture, the derailleur cage isn't in its worst case = closest to the ground position).
About the gearing, if you are satisfied with 52x11 as longest which is about 6.7m, you could as well use a 9-34 cassette with a 42t chainring that also gives about 6.7m as longest and gives about 1.7m on the biggest 34t sprocket what is the same as what you will have with the inner small 39t chainring of your double and a 32t cog.
#2134
XDR hubs and cassettes were/are not available locally and I can’t order them online due to the high costs. I don’t want to install things which are not readily available locally and have no warranty even though the price. And no replacements available locally if I’ll need to replace cassette or change it for any other confirmation. Shimano cassettes are always available in any configuration and cheap price. Same goes for my Brompton, all parts are always available locally.
So going the way you suggested with XDR hub/cassette is not feasible for me in my location.
#2135
Quoted: 800 Post(s)
Liked 247 Times
But you seem to buy many things on Aliexpress which is also not local availability, can't you buy those XDR parts in Asia like you do for parts coming from Aliexpress ?
Is SRAM not available in Turkey?
The problem with the current range of Shimano groupsets its that they have now several groupsets completely incompatible with each others: 12s MTB is totally incompatible with 12s road, 10s and 11s MTB for ebike (Linkglide) are totally incompatible with previous 10s and 11s MTB and with current 12s MTB and they now have new 11s and 12s Di2 MTB that only work with Shimano new Steps ebike motor !
They have also now 3 types of freewheels on their rear hubs, the old one, one for MTB 12s only, one for road 12s only.
For road, there is now in 12s only Di2 groupset but customers are waiting since many years for a MTB 12s Di2 solution, the newly announced 12s MTB Di2 isn't a solution, it works only in combination with 2 new Steps motor (previous EP8 motor isn't even upgradable to work with those groupsets).
I previously liked a lot the excellent Shimano groupset but the latest one are a mess !
#2136
Rear hub, cassette, chain are all bought locally, Shimano. Front derailleur will also be Shimano. Also locally. The only drivetrain thing I’ve ordered from China is double chainrings. $33.91 shipping and import tax included. And they will be available to order forever. And for this price I have absolutely no issues ordering them from China.
#2137
Jipe I get it now. You just don’t like Shimano. I’m sure you have your reasons. Here in Istanbul they have very good customer service, very, very wide service network, products availability, good prices and Shimano service center mechanics (mine is too) know what they are doing. So I see no reason why to look for alternatives.
I didn’t come across any official SRAM service centers or found they parts widely available. Only few things here and there probably imported by individual companies. I’m pretty sure they are not present here officially.
#2138
Quoted: 800 Post(s)
Liked 247 Times
I liked a lot previous Shimano drivetrains that work perfectly well and are very reliable but not the current ones like Di2 only road 12s which are incompatible with MTB 12s mechanical only which require the special microspline hub, Linkglide fully incompatible with Hyperglyde and Hyperglide+, new MTB Di2 that work only with a Steps motor...
And all these new drivetrains have a very limited choice of cassettes that aren't good for small wheels bikes.
#2139
Quoted: 463 Post(s)
Liked 567 Times
#2140
Quoted: 800 Post(s)
Liked 247 Times
The problem is that a cassette that starts with a smallest cog of 11t is not good for small wheel bikes, the gear inch it gives with a usual 52 or 53t chainring and 52/53x11 is too short and the big cogs above 42 are completely useless. Using very big 60t or more chainring is not a good solution because they aren't standard and do not fit on many folding bikes.
This is the reason why bike manufacturers like Moulton, Riese & Müller and others use special cassettes with a smallest cog of 10t or 9t.
Shimano has only one solution that accept a 10t cog, its the latest MTB 12s Hyperglide+ which is only compatible with Shimano microspline hub and only in 10-45 or 10-51 (or even bigger from third party).
Shimano had the Capreo drivetrain specially made for small wheels bike but its obsolete (cassette is max 9-28) and anyway discontinued from Shimano and n spare parts available anymore.
Therefore the choice of SRAM XD or XDR rear hub that accepts cassettes starting with a 9t cog, for which there are several cassettes options that fits very well for small wheel bikes with a wide enough gear inch range to avoid the need of a double chainring and that in 11s are compatible with SRAM, Shimano and even Campagnolo derailleurs.
The picture I put of my Birdy show such a solution : XDR rear hub, 11s 9-34t 378% range cassette and Ultegra RD-R8000-GS medium cage rear derailleur (and for a frame that accepts it, there is also a 9-39t cassette 11s for XD/XDR rear hub usuable with a Shimano GRX derailleur).
#2141
Quoted: 463 Post(s)
Liked 567 Times
#2142
Quoted: 800 Post(s)
Liked 247 Times
As I wrote, 52x11 on the Birdy is only 6.76m which is very short.
The Riese & Müller Birdy has 7.86-2.21m with a 9-32t cassette, a Brompton 6s with BWR 7.95-2.63m.
Neither the Birdy nor the Brompton are race bikes but nevertheless, their manufacturers judge that 7.86 and 7.95m are good for their bike. But maybe these manufacturers are incompetent ?
Shimano had Capreo with 9t smallest cog, SRAM introduced 10t cogs for both road and MTB on all their drivetrains but maybe Shimano and SRAM are incompetent too?
#2143
R&M Birdy’s 32t does 2.34m and not 2.21 according to my calculations. 6 speed Bromptons sold in Istanbul have 44t chainring as standard to provide shorter gears for climbing, so the Brompton 6 speed range I have is 2.33 to 7.05m. While I found 7.05m to be plenty for speed on my Brompton, 2.33m is still not short enough for me.
Hence I need shorter range and will be adding 39t chainring to Bridy which will provide 1.75m on 32t. Pretty awesome range I’d say, 1.75t to 6.49m.
I think discussing what bicycle manufacturers put on their bikes is pointless, users are free to modify their bikes to suit their needs. I bet this chainring wasn’t installed by R&M, yet rider felt such modification necessary to suit his needs.
#2144
Quoted: 800 Post(s)
Liked 247 Times
Its because like me, you changed the tires from 40mm wide to 50mm wide (Keuzotter gives also 2.21 for 52x32 with 40mm tires) and for this reason, I moved to a 50t chainring.
With the original 9-32 cassette and 42t chainring you can have 6.7-1.87, not so far from what is obtained with a double chainring.
#2145
With the original 9-32 cassette and 42t chainring you can have 6.7-187, not so far from what is obtained with a double chainring.
#2146
Perfect drivetrain for Birdy would probably be rear hub + belt. Belt for Birdy will be just perfect as it doesn’t have to go through the rear triangle. The biggest challenge would probably be how to figure out a tensioner for belt while folding. As far as I know belts are not supposed to be bend in the opposite direction.
#2147
Quoted: 800 Post(s)
Liked 247 Times
The benefit of the belt is limited, current belt last not as long as older ones.
And belt have a lower efficiency than a chain.
Last point, there are no small cogs for belt like for a chain which is a problem for a small wheel bike.
Tensionning is also a problem, not only for folding, but also because the distance between crankset and rear wheel axle changes when the rear suspension works.
For the hub, Rohloff is excellent and compatible with small wheel. That's what I have on my Brompton with 54x13 it gives about 1.5m-8.0m gear inch with 14% perfectly equal spaced speed. Rohloff also allow to switch speed while pedaling with power which isn't possible with other IGH and isn't too heavy (actually a non disc Rohloff with some small weight savings has the same weight as the Brompton 6s BWR).
I could take a Birdy with Rohloff but to minimize the weight, I preferred a derailleur that with my current setup 50t front 9-34t rear provides a enough range.
#2149
Riese & Müller mount a Shimano RD-T610-SGS derailleur on the Birdy which is OK because 36t is about the maximum possible on the Birdy 3.
there is also room between the wheel and the frame
but something still prevents it from going in further and I can’t find what it is. Not the chain tensioner.
#2150
