Addiction 2022.4
#2626
Should Be More Popular
Quoted: 22617 Post(s)
Liked 8,943 Times
#2627
Liked 8,943 Times
You might recall one of my cycling friends was a pilot until he retired a few years ago (he usually flew with his wife who was also a pilot). One of the other cyclists in our group travels for work, and one day was on a flight piloted by our friend. I don’t know if he got a tour of the cockpit though. I imagine this does not happen post 9/11.
#2628
Quoted: 10238 Post(s)
Liked 5,191 Times
You can come up to the cockpit during boarding, time permitting. I have kids almost every flight, I don’t think I have had an adult on their own come up to the cockpit for a peak. During flight, trying to see the cockpit. will get you a cool tour of a police car, or better.
#2629
Liked 5,191 Times
#2630
Liked 8,943 Times
#2631
Liked 5,191 Times
#2632
Liked 5,191 Times
While I was riding this morning, on the creakvelo, I started thinking about how I would change the shifting cables when the time comes. I have never done this before and the RD cable goes into the frame. I was thinking I could unfasten the cable from the rear derailer and shifter, pull the cable out of the housing, sliding fishing wire through the housing so it is sticking out of both sides. Then pull the cable housing out leaving the fishing line behind, slide the new housing over the fishing line, pull the fishing line out and then insert the new cable.
Im sure I could have youtubed, but this is what I came up with on todays ride. Sounds like it should work. Thoughts?
#2633
Klaatu..Verata..Necktie?
Quoted: 10463 Post(s)
Liked 11,961 Times
When I redid the housings a couple years back, I undid the cable at the brake, pulled the old housing out the back end, and slid the new housing through over the old cable. Easy-peasy.
#2634
Liked 5,191 Times
Does the cable go through the frame in regular housing? The Battaglin has the rear brake cable routed through the top tube. When I got the frame, it had no housing or cable. I slid a brake cable in, fished the end out at the other opening, and then slid the housing through from the other end. Then I pulled the brake cable out again while I set it up.
#2635
Liked 5,191 Times
When I put this new groupset on the Ritchey, can I use the old housing for brakes and shifting or should I replace everything?
#2636
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
And oof, grandmother is in the hospital after chest pains last night, took an X-ray and some blood but... no diagnosis today because they aren't running tests on a Sunday? Because apparently life and death can wait like bankers?
#2637
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3214 Post(s)
Liked 1,863 Times
It was a cold 50. Wore a thin base layer, thermal long sleeve jersey, tights and toe covers, light gloves, and a hat. Had my rain jacket in my back pocket, but decided not to use it even when it started to rain.
Daughter started throwing up so I cut the ride short. We have all had a cold now for like 2 weeks we can’t seem to shake. Fevers randomly but not often, ****** cough, and super congested.
#2638
Liked 1,863 Times
#2639
Quoted: 9656 Post(s)
Liked 6,366 Times
Or, my rec - replace it all with wireless electronic
#2640
Liked 1,863 Times
#2641
Liked 1,863 Times
I did the usual 22 miles this morning. Slower than normal due to lack of sufficient sleep last night. I go through phases where for a month or three it is nigh on impossible to get eight hours sleep, and then some switch gets flipped and I sleep like a baby for. eight or nine hours for a few months.
Hoping for a nap this afternoon
#2642
Mostly Harmless
Bikes: Have two wheels
Quoted: 13727 Post(s)
Liked 4,537 Times
#2643
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
#2644
Mostly Harmless
Liked 4,537 Times
Jagwire Black Housing Liner | Jenson USA
#2645
Mostly Harmless
Liked 4,537 Times
Likes For rjones28:
#2646
Mostly Harmless
Liked 4,537 Times
#2647
Mostly Harmless
Liked 4,537 Times
New groupset = new cables and housings. Always.
Likes For rjones28:
#2648
Liked 8,943 Times
#2649
Liked 8,943 Times
Maybe an aficionado of SlowTwitch like Bah Humbug knows more about this....just thinking out loud....
I think it's obvious to all of us that a more open/larger hip angle (ie slightly more upright position on the bike) gives a higher power output, but at the expense of more wind resistance, so less aero. That's why most of us get lower on descents and/or pulling at the front, and sit up more on climbs and/or when in a draft or going at a lower intensity.
So is there a more analytical way to find the right compromise/sweet spot for how low to bend at the hips??
I know TT/Triathletes have tried (and to a great extent, succeeded) to have their cake and eat it too, by changing the position on the bike to make the body more aero but keep the hip angle relatively open by rotating the whole body forward. I even see it's documented that cyclists will have a higher FTP and V02 max on their road bike than their TT bike, but of course the aero advantages of the TT bike should more than outweigh the modest improvement in power on a road bike.
So for a road cyclist, other than go by "feel," (which is what I do, and I suspect most of us do, consciously or not), I wonder if there is a better way to measure the tradeoff here and help find the optimal position for various riding situations? I am afraid the only way to know for sure is to use both a wind tunnel AND a power meter at the same time, and I expect that this information is both proprietary and may vary by rider.
Comments??
Comments??
#2650
Liked 6,366 Times
Ask ridabent?
Likes For Mojo31:
