Is This C&V Sacrilege?
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
Liked 11,914 Times
Have you determined that the fork which will be cut down is the same length as the original fork that would have came with the 23" frame?(other than the longer steerer tube) I have a Tange 1 frame that had the fork swtiched out before I owned it for a chrome Tange Prestige fork. It's an upgrade and rides good, but now the TT is slightly sloping.
EDIT: Both measure 14 13/16" from the tip of the dropout to the lower bearing seat.
Quoted: 604 Post(s)
Liked 1,064 Times
Sacrilege no, great plan to get what you want. Late 80s Circuit is so worth it!
Tim
Tim
Likes For tkamd73:
Quoted: 3241 Post(s)
Liked 2,512 Times
Liked 2,512 Times
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 279 Post(s)
Liked 955 Times
@genejockey you know I'm not the right guy to talk you into anything but "buy as many bikes as it takes to build the one you want". Looking forward to seeing the new build
Likes For SwimmerMike:
Liked 11,914 Times
Likes For genejockey:
Liked 11,914 Times
I contacted Dale Saso, who said, "Sure, bring it on by," so I guess I'll strip the 22" bike this weekend!
Quoted: 968 Post(s)
Liked 1,631 Times
80mm-220mm-30°
Also note that as we age we get less flexible in handle bar positioning. 2cm difference would be intolerable for me personally...
Liked 11,914 Times
Ha... So funny... Stud, it's a Franken Bike not a "Restoration". You know this! The bike looks fantastic and it appears to have that presence that insures a very nice ride. Get that Goose Neck Quil Stem and ride on...
80mm-220mm-30°
80mm-220mm-30°
Quoted: 2338 Post(s)
Liked 2,827 Times
maybe time for a tall bike ?
Quoted: 968 Post(s)
Liked 1,631 Times
The Nitto Technomic stems might give you 2mm more height. Another possibility is a new replacement fork for the 23" frame.. Soma might have a threaded fork that would fit.
Quoted: 3514 Post(s)
Liked 2,927 Times
Please don't put an angled stem on it!
If you need something taller, and you're having the fork cut and threaded, just cut the steerer long, and use spacers between the headset cup and the locknut to get a bit of extra height!
Liked 11,914 Times
A tall bike, you say? Well, nce I strip the bits off the 22" frame, I'll have no bike at all.
I have a fork. I just need it cut and threaded, and I found a framebuilder who can do it.
The 1989 Circuit came with the Sante headset, which has a two piece cover, which is one of those things I want to keep. So, no extra spacers.
Liked 2,827 Times
Likes For squirtdad:
Quoted: 1163 Post(s)
Liked 442 Times
Hey genejockey - compliments on how clean your Shimano Sante component group is ! Those were 7 speed Uniglide indexed rear shifting, yes? Just curious about the state of tune on the RD indexing and if you are running a Sante 7 speed freewheel or a 7 speed Uniglide cassette hub?
Also, the Sante cranks with the smooth chainring bolt heads are one of my favorites. I bought a set of those Sante chainring bolt sets from eBay and went for a trick look on some Dura Ace 7410 cranks I was running. I loved the look but unfortunately I lost one of the bolts on a ride and came home with only 4 out of 5. Ever since then I do better with applying thick grease to my chainring bolts and torque-ing them down good.
Likes For masi61:
Liked 11,914 Times
Liked 11,914 Times
Yes, it's got 7 speed indexed shifting, which is beautifully crisp. It's got the full Sante kit, so that includes the 7 speed Ultraglide freehub, with the smaller diameter threaded end that takes a Dura Ace smallest cog. It came with 13-23 cassette, but I swapped out the 21 and 23 for 22 and 26, since I'm not as young as I used to be. Oh, and it's got the original 52/42 Biopace chainrings!
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,930 Times
Back in 2021, I bought a 1989 Schwinn Circuit. It is a 22" (55-56cm) frame. I bought it because I was fascinate by both the frame itself (Candyapple red, Columbus main tubes, with chrome Tange Aero stays and fork) and the groupset (Shimano's Sante). It came with all the original parts, except for ONE of the black rubber nubs that go into the pivot bolts on the single-pivot brakes. I normally ride larger frames, 57-59cm, so it took a long seatpost and a 130mm stem to make it fit. Mostly.
The thing is, the bars are about 2 m lower than any of my other bikes, and I found that after long rides on it, especially if I do much riding in the drops, I get some lower back pain.
SO, I found a 23" (58cm) frame on Ebay. Same year, same color, etc. But this time, in my size. No fork, though, and obviously the fork from the 22" frame wouldn't fit. SO, I found a 24" 1988 Circuit frame and fork. That frame is a bit rough. Lots of rust spots on the top tube, etc. BUT the chrome fork will clean up nicely!
Here's my plan: Get the fork from the 24" cut down and threaded to fit the 23" frame, then swap all the components from the 22" frame onto the 23", recreating a completely authentic, but not original, 1989 Circuit in my size. And a really nice 22" frame.
This fork has been like this since ‘90 with no problems. A stem with a little rise helps too
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Liked 11,914 Times
Before anyone else says, "Why cut the steerer, just run a lot of spacers!", here's the Sante headset. On the right is the upper part, with the two-piece cover in place. It's a low stack height headset, and doesn't really work with a lot of spacers.
Bianchi Goddess
Liked 2,930 Times
I wouldn’t bother with it. I like Ritchey Logic HSs, they don’t cost too much and are very smooth and durable. Leave that Sante in the frame it is in to save the next owner some headaches.
Liked 11,914 Times
But then it wouldn't be an authentic 1989 Schwinn Circuit.
Bianchi Goddess
Liked 2,930 Times
Parts wear out.
According to Velobase that Sante’ HS has a 32.5mm stack height and a 105 is 33 something. If you take this out of a frame there is no other headset that will fit in it.
https://velobase.com/ViewComponent.a...=111&AbsPos=24
