Best grease for threading freewheel to hub?
I'd reach for the copper ease grease which is a conventional lithium soap with added copper particles normally, but freewheel to hub might involve tightening brass or bronze down onto aluminium, and the copper might cause the components to bind rather than separate freely. So I'd just use normal lithium grease. Or just oil.
Quoted: 569 Post(s)
Liked 596 Times
two wheels only
Galling is the problem to be avoided when screwing a steel threaded freewheel onto an aluminum hub and anti-seize compound is the right stuff to use to prevent galling. I use a Permetex compound purchased from the local auto parts store. A small tube lasts just about forever.
Quoted: 4844 Post(s)
Liked 3,971 Times
If you use liberal amounts of marine grease (the stuff for boat trailer hubs found at any auto parts store), removal will be a little tougher simply because the stuff is viscous, but nothing will change over your lifetime. I keep an open tub at my workbench to encourage its use.
I've been working on an early 80s tandem, and FINALLY got the freewheel off the Atom drum brake rear hub. Don't want to deal with that again, or pass that problem on to a future owner. I always grease the hub and freewheel before spinning them on, but haven't given much thought to the grease I use--whatever I've been using in bottom brackets. I'd be interested in hearing if there are any best practices out there that I am overlooking.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 540 Post(s)
Liked 1,034 Times
As stated above: Permatex Anti-seize. A 1 oz. tube doesn't cost much and will last a long time. I use it for freewheels on my bikes, spark plugs and lug nuts on my vehicles. I use an old toothbrush to make sure it goes into the threads.
https://www.permatex.com/products/lu...ubricant-1-oz/
Quoted: 569 Post(s)
Liked 596 Times
Not a bad thought that also occurred to me. I recall when our Shell lubricant distributor convinced us to move to the super high pressure greases for some applications in the plant, the new additives being divalent metal salts and salt being the last thing I wanted anywhere around my spiffy Dura Ace seat posts.
Quoted: 1866 Post(s)
Liked 665 Times
I use "Super Lube" grease. Not only do I have access to as much as I want, it works great on just about anything.
I own a design/manufacturing facility, and I have to specify down to the last "ingredient" what is used in one of our designs for military contracts. I was using Phil's to lubricate the steel on steel on an optical interface unit (because that is what I had on hand during the prototype/submission phase) so the initial shipment was spec'd for the stuff. The end user (US Army) was like "what is that?" so I then spec'd Super Lube. After years of Super Lube we have found that it is truly a fantastic product under real world conditions.
Grease is grease..................to a point.
