Crashed my bike. Need help figuring out what happened and how to regain confidence.
Old 09-06-20, 09:57 PM
alcjphil
alcjphil's Avatar
Quoted: 1820 Post(s)
Liked 1,696 Times in 976 Posts
If your front tire blows out, the last thing you should do is to apply the front brake.
alcjphil is offline
Old 09-07-20, 05:38 PM
InvertedMP
InvertedMP's Avatar
Bikes: 2021 Scott Addict RC 20
Quoted: 177 Post(s)
Liked 269 Times in 104 Posts
As said before, glad you are ok brotha! Go tubeless! Eliminate the variable of pinch flats, and carry a spare tube in case you need to get home in the event of a large flat. I do so many crazy things, but bombing down hills on a road bike still isn't one of them, I can't get past the pudge factor.
www.mp-aviation.com
InvertedMP is offline
Likes For InvertedMP:
Old 09-07-20, 06:21 PM
asgelle
Quoted: 1031 Post(s)
Liked 451 Times in 265 Posts
Originally Posted by InvertedMP
As said before, glad you are ok brotha! Go tubeless! Eliminate the variable of pinch flats, ...
There is no variable of pinch flats. Pinch flats are user error; either for running too low a tire pressure or too small a tire. And this wasn't a pinch flat.
asgelle is offline
Old 09-07-20, 06:51 PM
77Eric
Bikes: Cervelo R3
Quoted: 17 Post(s)
Liked 11 Times in 8 Posts
Sorry about your crash and glad you are OK.
I agree about possible installation error and not pinch flat but will offer up another scenario. If your brake pads are misaligned they can come into contact with the sidewall of your tire. This can be due to a poor brake adjustment and/or brake pad wear causing their alignment to change. I know your tires were quite fresh but those Conti sidewalks are pretty thin.
I had this happen to me twice this year before I figured out what was going on (not at high speed and I didn’t go down). I was using GP4000’s and ee brakes.
If you still have the tire I’d examine the sidewalls very closely (use the tube to find the blowout spot if you had your label aligned). Also inspect your brake pads. If they show a raised area on the upper/tire side of the pad they were misaligned. If that doesn’t get corrected the same thing will happen again...
77Eric is offline
Old 09-08-20, 07:11 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1098 Post(s)
Liked 559 Times in 446 Posts
Hit something large enough, like rocks on the road, or a deep enough pothole or pavement mismatch and a pinch flat may occur. It doesn't always mean that the tires are too small or pressure too low. Riding in the Colorado mountains, rocks on the road are my most common problem. It's hard to miss every one.
I've had two pinch flats in the last 9,000 miles and no other punctures. I weigh 135, and use 25mm tires with 80-85 psi.
DaveSSS is offline
Old 09-08-20, 07:43 AM
drewtk
Quoted: 38 Post(s)
Liked 46 Times in 31 Posts
Wow, glad to hear it wasn't worse, but it could have been a lot worse. Also glad to hear you're back on the horse and riding again. I can somewhat relate because one of my other hobbies is racing cars. I totaled my race car a few years ago, crashing into a concrete wall. I bought a replacement car but I was definitely tentative the first few times I drove it, and the first few races in it. But you slowly learn to trust your vehicle and yourself again.
On the tire pressure, try using Silca's online tire pressure calculator. I have found it to be pretty accurate. You do need know the actual width of your tires, not what's stated on the sidewall.
drewtk is offline
Old 09-08-20, 07:48 AM
asgelle
That's exactly what it means if you pinch flat. What else could it be?
Exactly, knowing you'll inevitably hit rocks and potholes means you either prepare with the appropriate tire size and pressure or take responsibility for your pinch flats.
asgelle is offline
Old 09-08-20, 07:59 AM
eduskator
eduskator's Avatar
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times in 440 Posts
I don't think you ''need'' to go Tubeless to avoid that. I think you were just really unlucky. Perhaps it is manufacturer default in the tube, maybe you hit something, maybe your tube was under-inflated... It could be lots of things.
Take the necessary time to recover, both physically and mentally, then get on that bike again & ride it like you stole it! If you don't trust the setup, perhaps it would be time for new tires, new rims or even both. Riding on a bike you don't trust is one of the worst thing you could do, so don't hesitate to replace components if it can help.
eduskator is offline
Old 09-08-20, 09:31 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1335 Post(s)
Liked 318 Times in 216 Posts
Either the tube was pinched between the bead and rim, installation error, or excessive heat from braking softened the rim or bead allowing the tube to slip out, rider error. Luck had nothing to do with it.
You dont know that, and you managed to completely ignored the point, - that "bad luck" if often the result of ppl running too fragile tyres and tubes (latex?), and carbon rims, that are prone to popping, get cuts, overheating etc. In essence setting them selves up for accidents that at first glance appear as just "bad luck".
Racing Dan is offline
Old 09-08-20, 09:38 AM
asgelle
Originally Posted by Racing Dan
You dont know that, ...
The fact that there was a loud noise means the tube burst outside the tire. There are only a few ways that can happen.
... and you managed to completely ignored the point, - that "bad luck" if [sic] often the result of ppl running too fragile tyres and tubes (latex?), and carbon rims, that are prone to popping, get cuts, overheating etc. In essence setting them selves up for accidents that at first glance appear as "bad luck".
In other words, it isn't bad luck at all but user error.
asgelle is offline
Old 09-08-20, 01:27 PM
SurferCyclist
Bikes: Canyon Endurace CF 9.0 Di2, Cannondale CaaD 8, Diamondback MTB(ancient)
Quoted: 36 Post(s)
Liked 67 Times in 22 Posts
There is when the rim tape extends into the spoke holes and causes a pinch flat. This happened to me recently. Maybe I should have changed the rim tape before this occurred(been on wheels a couple of years) but then again replacing rim tape not exactly top of list of things to check on bike as far I can see.
Also, everyone seems to think for sure it was a pinch flat. Maybe inner tube just failed because well, on occasion that happens too.
SurferCyclist is offline
Old 09-08-20, 01:34 PM
asgelle
Not everyone. I don't know how you could have read through this thread and think that. In any case, it wouldn't matter how many people are wrong, if there was a pop or bang, the tube was outside the tire and that's not a pinch flat.
asgelle is offline
Old 09-09-20, 06:10 PM
RedBullFiXX
RedBullFiXX's Avatar
Quoted: 73 Post(s)
Liked 41 Times in 33 Posts
Glad you are ok Erik
Had a similar incident recently, 25mph, tipped it into the corner and POP
Front flat, TL tire, Hookless rim (HUNT), Vittoria tire stayed on the rim, fully seated
Slid the rear to maintain control to the inside shoulder of rocks and boulders on the road down from Baldy Village
Not fun, saved it though
Just a slight nick on the rim, and frame
Changes the perspective of how much "Fun" do I want to have on decents
Cyclocross at speed !!!
RedBullFiXX is offline
Old 09-11-20, 11:19 AM
Rhondito
Rhondito's Avatar
Bikes: 2020 Giant Advanced Revolt 2; 2019 Cannondale Synapse; 2017 Cannondale Habit Lefty; 2010 Blue RD1 (retired)
Quoted: 20 Post(s)
Liked 26 Times in 16 Posts
(Pick up a pair of cycling gloves, pal.)
Glad your injuries weren't worse - that could've turned out nasty.
Rhondito is offline
Old 09-11-20, 02:15 PM
JayKay3000
JayKay3000's Avatar
Quoted: 46 Post(s)
Liked 78 Times in 50 Posts
Give yourself time. The physical and mental scars will gradually fade as you slowly rebuild your confidence on hills. In 3 to 4 months you'll be back to normal.
JayKay3000 is offline
Old 09-11-20, 07:25 PM
Rogerogeroge
Bikes: Trek Emonda SLR 9; Moots Routt YBB; Trek Fuel EX8+; LeMond Poprad
Quoted: 178 Post(s)
Liked 177 Times in 101 Posts
That isn't a friggin pinch flat! A pinch flat happens when the compression force is so great the tire and tube bottom out on the sides of the rim, resulting in small holes (not a slash) on each side of the tube, and it's often referred to as a snake bite.
OP: That's terrible luck, I know of a similar story personally. Best thing you could have done is use the rear brake hard and stay off the front brake. But to minimize these possibilities, this is where yearly maintenance pays off. Even if you don't have a flat all year, take off the tire and inspect the rim tape, make sure the spoke holes are covered. Also inspect the tire. When my tire wears out (which is the rear tire), I always put the new tire on the front and move the front tire to the rear. You always want the best tire on front. And again, periodically inspect your tires, tread and sidewall a few times each year. Really no need to periodically replace the tube - I've seen a few batches of bad tubes, so replacing a tube actually adds an element of risk. A new tube is really just as likely to fail (like a split seam in the tube, which you seemed to have) as an old tube. And I take it that wasn't your first ride on that setup, which pretty much rules out faulty installation. Not a pinch flat!
Rogerogeroge is offline
