C & V pet peeves!!
#151
Quoted: 3515 Post(s)
Liked 2,929 Times
More importantly, is the label on the drive side?
Likes For smd4:
#152
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Yes. It is a directional tire and I would almost definitely probably very likely for sure remove it for that. But I just wasn't in the mood to deflate a tire I just mounted to position the label with the stem. That would have been a waste of air and waste is a peeve of mine.
#153
Bikes: 1980 Dawes Super Galaxy + 1981 Lotus Classique + 1986 Bianchi Sport SX + 2005 Van Dessel Project WR + 2021 Zizzo Liberté
Quoted: 143 Post(s)
Liked 481 Times
Brilliant use of a trainer, I'll have to copy that.
So, as a very casual rider and wrencher I really shouldn't contribute here in the first place, and apologies if it's come up already (it's a long thread by now), but I hate bike computers. Even period-correct ones, no, especially period-correct ones, with the sensor wire coiled around the brake cable, looking like a CB radio microphone. Gawd that's ugly.
Likes For EVlove:
#154
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,009 Times
Likes For Pompiere:
#155
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
That's not always possible. I recently put a Continental TourRide (700x42) on my back wheel, and it drove me nuts for about 10 minutes, because it's definitely directional, with an arrow, but the label ends up on the NDS. 🤔
I finally said why worry, the tire's fine. 😁
#156
Quoted: 143 Post(s)
Liked 481 Times
I'm also not a fan of the computer wires, which is why I bought a basic Garmin. It's only a little bigger than a regular bike computer, but no wires or sensors to clutter things up. If you really want to keep the vintage look, you can hide it in a pocket and it still records your ride.
Likes For EVlove:
Likes For Schweinhund:
#158
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
I was trained to set bikes up the way Italian racers did. My boss was persnickety. So am I by nature, and I try to beat back that tendency.
A couple of years ago, I was setting up a bike for myself, and my intuition told me to rotate the bars back a bit. OK, a bit better. Then I tipped them back a bit more, and oh my goodness, I'm in heaven, why did it take me so long? It looks bad and feels good. I'm leaving it this way.
Likes For 52telecaster:
#159
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
Pet peeves? Hmmm...
sloping crowns --> clunky
most standard quill stems --> neuter weapon, and flexy
dead horizontal top tubes --> lack of clearance for the boys, and boring
friction (non-indexed) shifting --> hunting around for the right gear
shellacing handlebars --> hello, changing handlebars?
drop bar ends flat with ground --> puts brakes a mile out in front
some others, while I'm at it...
lug lining --> most lugs brazed poorly, so highlighting bad workmanship
tubulars --> hassle, $$$, getting rolled or welded to rim
steel --> it rusts
steel --> it rusts
#160
Quoted: 4513 Post(s)
Liked 6,391 Times
Rusty allen RD hanger bolts, the socket the wrench goes in.
We spend countless hours and $$$$$ turning these into works of art only to soil the outcome by leaving a rusty eyesore right there at an apex focal point.
Yes it can be a PITA to mitigate, yes I am guilty of it too but come on, at least squirt it with PB, circle back later and scrub it out with something and close the deal.
And while we're at it, screw the RDO screws all the way in or take them out of any and all bare frames, especially for shipping, again.
#161
The Huffmeister
Liked 3,561 Times
I wonder if a couple drops of evaporust w/ a piece of tape over those little allen bolt heads would do the trick. I have a few (dozen) I can experiment with.
#162
Liked 6,391 Times
I usually PB, scrub with brass or SS brush and strip with brake or carb clean then soak.
Some things seem to stain if it has to work to hard on the rust or results are lackluster if the rust is bad.
They have gel that stays put but it takes a long time to work.
#163
Likes For kommisar:
#164
Liked 2,929 Times
