Flying Tire Irons
Bikes: Columbine, Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 277 Post(s)
Liked 190 Times
Flying Tire Irons
Anyone have any secret handshakes on how to keep tire irons from growing wings and flying across the garage (other than changing tires in the kitchen) when you get to the last bit of tire to get inside the rim?
Cheers, Mike
Cheers, Mike
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 894 Post(s)
Liked 1,252 Times
Take two feet of parachute cord and tie it tightly around the rim and the tire to the left of that last bit that wont go on.
The use the levers to the right side of that last bit. No longer will the left side run away from you.
Barry
Barry
Likes For Barry2:
Quoted: 277 Post(s)
Liked 190 Times
Great - thanks!
Cheers, Mike
Cheers, Mike
Quoted: 277 Post(s)
Liked 190 Times
I've used that hook when taking a tire off, but I can't get my head around how to use it when putting a tire on......
Cheers, Mike
Cheers, Mike
Quoted: 3663 Post(s)
Liked 3,105 Times
Likes For smd4:
Quoted: 277 Post(s)
Liked 190 Times
Likes For PromptCritical:
Quoted: 6004 Post(s)
Liked 2,940 Times
+1
Mounting tires is more about finesse than strength or leverage.
So far, after over 50 years, I've never needed tools to mount a tire.
In all fairness, I'm careful about selection of rims, rim tape, and tires, so my solution to hard fits is more about prevention than fix.
However, I also help others mount tires, so it seems that I've either been lucky or skilled.
However, to the OP, maybe the key is to not let go. Or if you absolutely find another way, consider tying a string to the lever.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 277 Post(s)
Liked 190 Times
That's impressive! I'd say half of my tires don't need tools to install, half do, and of that half, 10% get returned because they are unusably tight. The string would at least make finding the tire iron easier.......
Cheers, Mike
Cheers, Mike
Liked 3,105 Times
So I think I’d be more worried about losing an eye when the lever snaps back on the string!
Liked 3,105 Times
I admit to never having mounted a tubeless tire, but even then, I suspect there isn’t a tire I couldn’t mount using just my hands.
Liked 2,940 Times
First and most important, replace your rim tape with the thinnest as suitable option. I use filament tape, but urethane rim strips are an equally good option.
If you can find ones you like, buy tires with steel hoop beads rather than Kevlar or similar. Steel beads have the least stretch, so are made truer to size vs. stretchier beads that need to by undersized to allow for that.
When mounting, start opposite the valve, push the tire fully to the center and massage it forward as you work both sides to the valve. You should now be able to finish with hand strength alone. If not, put a tire iron between tire and rim push inward, while trying to lift the tire and crab it along until you can get the last bit over.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,940 Times
Common sense, measure the string too short to reach your face.
FB
Chain-L site
FB
Chain-L site
Liked 3,176 Times
Quoted: 277 Post(s)
Liked 190 Times
Well, just for kicks, try mounting a Challenge, Strada Bianca in 700x36C, or a Schwalbe - Marathon Plus HS440 Tire on a Bontrager Affinity rim.
Cheers, Mike
Cheers, Mike
Quoted: 277 Post(s)
Liked 190 Times
Here's some practical advice.
Cheers, Mike
Cheers, Mike
Liked 3,105 Times
I always start at the valve. You want the bead and the valve both properly seated.
Likes For smd4:
Liked 3,105 Times
Liked 2,940 Times
It's actually very simple. The rim is deepest at the center. The valve blocks that and keeps the tire on the side, costing you what could have been working slack.
Let's step back a moment. I don't know anyone who can't mount the first side fairly easily. So, given that both sides are the same, why do these same people have so much trouble on the second side?
The key is to duplicate first side conditions for the second side.
Liked 3,176 Times
usually the ole "tim hortons" method works for me... just rrroll it up over the rim!
-YMMV
-YMMV
Liked 2,940 Times
But, I don't claim that there's only one way, or even a best way. Whatever works is right.
FB
Chain-L site
FB
Chain-L site
Quoted: 4245 Post(s)
Liked 3,990 Times
When in my young 20's and working in the shop's basement for hours at a time we'd start to play games. One was "fling that lever" using the partially removed tire's tension to toss the lever as far as we could. Another was upstairs in the showroom and the (then) small assembly stand service spot. We would shoot Hunt Wild bar grips across the room with compressor air, aiming for the Wald baskets we showed on the over the front door peg board. Until the boss entered as a grip was bouncing off the display right above him. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
There's another thread with VegasJen(?) having a terrible time getting a tubeless with foldable bead (so I assume kevlar) to properly seat. But since tubeless, would the above matter? Maybe if the inside of the valve takes up the rim center area. I'm gonna find that thread...
EDIT: Relayed that info to Jen on that thread (with attribution), above about valve side last, and also your comment about kevlar beads may be tighter at first. She *finally* got the bead seated, but this may help for the future. Thanks.
Liked 2,940 Times
But, it begs the question, "if you can get one side on, why can't you get the other side on?"
So, to all those struggling, I suggest the key is in the answer to that question.
FB
Chain-L site
FB
Chain-L site
