For the love of English 3 speeds...
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
There's a guy on this forum from Bellville (I think) who built a nice one last year and posted pictures/progress etc.
There's math involved as well with sprocket teeth etc.
I tried to do one last year and messed up and broke
some spokes in the back wheel when the derailleur travelled to far.
I gave up but would like to try again.
I did buy a Cyclo derailleur recently and would
like to install.
Looks similar to this one
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Quoted: 380 Post(s)
Liked 106 Times
There were some questions. When I did mine I got the shifters and derailleurs from an early 10 speed that an older kid broke the frame on. They were French manufactured with the rear being a Huret Allvet and the front ???? I know that is spelled wrong but I was 14 and am now 72. Surprisingly it actually shifted the wider 3 speed chain. At that age I didn't know there were different chains. Again from memory the rear sprockets were a 19 and 16. 2 SA sprockets fit on the hub if you left the spacers (washers) out and put the offsets on the sprockets so the big one faced to the center and the small one faced out. Roger
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Hybrid IGH-derailleur conversions never really caught on for any period in time. They were often fussy and heavy. I'd try to persuade Max that an FW with a large cog is the best way to meet his needs and keeps the bikes character. He doesn't want to muck about with the hybrid, seeing as he doesn't pay attention to the rear spread on his bikes. You'd want to be hands-on. Or have his good friend Paul service it for him.
Bikes: 1983 Trek 600, 1972 Raleigh Sports Step Thru, 1963 Rudge Sports, 2007 Dahon MuP8, Dahon Speed, Public Mixte 8-speed IGH, mid-70s Peugeot Mixte AW conversion, Riv Platypus
Quoted: 350 Post(s)
Liked 24 Times
Phyllo-buster
Liked 2,055 Times
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 599 Times
This past December I was gifted a made in Italy Milano step through. It was pointed out to me that it used the wider chain like our three speeds. The first I had seen. Its a weird but somewhat fetching bike that could be restored or repurposed. Perhaps next winter.
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Quoted: 350 Post(s)
Liked 24 Times
The black Simplex derailer gives a pretty good idea when it was made. I dunno. Asia has so completely taken over the production of bike frames that I think almost anything made somewhere else is worth preserving, and this one has some nice chrome and that low mixte configuration is something you don't see every day.
Quoted: 350 Post(s)
Liked 24 Times
Those plastic grips are so ubiquitous. My ladies' Sports arrived with them and I've never thought to replace them. The Rivendell folks seem to love them, although they cover them with padding and weird stuff.
Quoted: 350 Post(s)
Liked 24 Times
Can an FW hub be used without the correct SA four speed shifter? I ask only because it almost seems easier to find the hub at a reasonable price than a working SA trigger shifter.
Phyllo-buster
Liked 2,055 Times
No but there's more of them out there than you think. Many older triggers were designed for 3 or 4 speeds.
Quoted: 350 Post(s)
Liked 24 Times
Phyllo-buster
Liked 2,055 Times
Sorry, no I wasn't saying that. I'm so stuck in the past, I didn't even know there were new 4 speed hubs and shifters available. Someone else know the answer?
Quoted: 350 Post(s)
Liked 24 Times
The new hubs use a rotary shifter on the hub, not the pull chain, so it's probably too much to ask for. Maybe I'll drop them a line and ask.
Quoted: 12 Post(s)
Is there a reasonably simple way to do this? I can’t think of it. We might be able to find an old FW or S5 hub and shifter and have a new wheel built or swap the internals into the existing hub shell. But here in the USA, those hubs and 4 speed shifters are hard to come by. Max might also be dubious about spending on such old parts. I'd have to find out. ... Or add an extra sprocket and derailer to the existing AW hub. But that’s hardware from the old days. Again, very hard to find all that in the USA.
This one has me scratching my head.
For the S5 conversion all you need to convert (aside from the hub) is a shifter for the left side of the hub, cable, and assorted cable stops/pulleys. You can swap the guts of the hub into your existing wheel as a unit. If the left side bellcrank is missing you can save some money by adapting the bellcrank from a Shimano 333 hub to fit instead of buying the pricey SA part. A nice feature of the S5 hub is that all of the common wear parts (bearing surfaces, clutch, pawls, etc...) interchange with the AW. This was fortunate for me, since both of my S5s came from junkyard bikes and had suffered badly from water intrusion.
The only tricky part of the derailer conversion was adjusting the chain guard so that it didn't rub when I was on the outer cogs in the cluster. I think I had to bend it a bit, but didn't have to cut anything. On a newer frame with the brazed on chainguard mounts this might be tougher to set up. I used the Cyclo 3 cog cluster and Benelux pull-chain derailer and they mounted up and worked fine. My Cyclo cluster was slightly wider than the hub driver, so I had to add a small spacer spacer to each side of the hub axle in order to make enough room on the drive side and keep the wheel centered. I don't think you'd have to do this if you used the 2 back-to-back SA cogs mentioned above by another poster.
-Carl
Quoted: 350 Post(s)
Liked 24 Times
At various times, I've swapped S5 hub guts and used the 3 cog Cyclo cluster and Benelux derailer to add gear range to my bikes. As you say, the toughest part of the job is finding the old parts. With parts in hand, both are easy to set up, and, I suspect, would be cheaper than having a whole new wheel built. I prefer the S5 conversion, and that is what I still have, but had no problems with the derailer either...
-Carl
-Carl
Liked 443 Times
And a Rudge!
Liked 2,446 Times
I have seen 1/2" x 1/8" chain on a derailleur bike but only on a three- or four-speed cluster. My little 500A Flandria had that.
Quoted: 350 Post(s)
Liked 24 Times
Two word answer from Sun Race USA whether one of the current four-speed shifters will work with a vintage hub like the FW. "Sorry, no."
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
-Kurt
Liked 443 Times
They're out there and quite nicely designed.
Ask around, LBS, Community bike shops etc.
Stay away from ebay/crazy prices.
So, I’m at a loss, where the heck does this thing go? Lol, I’ve looked at a bunch of diagrams and videos and can’t find one that has this spacer. I’m thinking someone had this hub apart since some things weren’t in correctly based off of what I’ve seen. I also am missing the smaller washers, #4 in the diagram.
Liked 443 Times
Looks like a #4 from the diagram but from a Dynohub.....
Should still work.
Should still work.
Liked 4,396 Times
EDIT: I’m a dummy, got it figured out! Thanks
