ISO and for trade thread part 5
#5626
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
Cyclone MKii GT tiny tiny tab thingy...
A Suntour Cyclone GT MKii rear derailleur is missing the teensy tiny little tab that goes in the split bolt for the cage pivot. Without it, the bolt is either too loose to keep from further loosening, or too tight to allow the cage to pivot.. I don't believe I have the eyesight or dexterity to try to fashion one with a dremel. Anyone got an old, busted up Cyclone the might give one of these tabs up? Or an idea of an alternative? Locktite, maybe......?
#5627
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Real cyclists use toe clips.
jimmuller
jimmuller
Likes For jimmuller:
#5628
Liked 645 Times
Looking for short Campy crank arms! A long-time cycling friend, actually an ex-boss with whom I have maintained a closer friendship, wrote to me that he needs a shorter crank arm. He wrote:
He has short-ish legs which are, in his words, well beyond their warranty (as are mine). His cranks are 175. So he asked me if there is any functional substitute, or if Campy even made 165s back then.
It strikes me that any crank would do as long as the chainrings aren't too wide for the chain and the spacing can be accommodated by the FD ( which presumably is indexing) and the offset is suitable. So many if's.
If any of you know of or have such a crank, that would be awesome! We can work out a deal!
I'm riding a 1998 or 1999 Trek 5000 with Campy running gear. The
crankset is (I think) 1999 Campy Record 9-speed.
jimmuller
jimmuller
#5629
Likes For Vintage_Cyclist:
#5630
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
@ehcoplex
Got an extra, old 1/8" screwdriver around? Cut a 1/4 inch off the end and it should make a decent substitute.
Likes For Schweinhund:
#5631
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 437 Times
What pads are you going to use? It looks like I will have Suntour pads to replace sometime next week, so wondering if anyone knows the specs? Are these 36mm or 40mm? I'm looking at Fibrax pads as a replacement, they have X-pattern rounded ones, but they seem to come in both sizes.
#5632
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
https://www.amazon.com/Kool-Stop-Sun...283076&sr=8-57
#5633
Edumacator
Quoted: 2444 Post(s)
Liked 3,141 Times
#5634
Quoted: 215 Post(s)
Liked 437 Times
Well, went to KoolStop website and they are actually quite good and give all the measurements. So apparently the ones they have as Superbe brake pads replacement are 36.4mm long. The ones I was looking at, with X pattern, are probably Weinmann standard. There's a tiny difference in measurements, so probably best to avoid. But I completely forgot that actually I could just check manufacturer's website or contact them. Which, of course, is the obvious option
#5635
Quoted: 761 Post(s)
Liked 1,563 Times
@ehcoplex
#5636
Quoted: 761 Post(s)
Liked 1,563 Times
Hey, @echoplex I used to have a Mk II with a busted spring. (They rust out.) I may have sent it off to someone a few years ago. It's been a long time. If I still have it and you still need it I'll send it to you. Let me check first before you start celebrating.
#5637
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
does it matter if it doesn't have the tiny 'wings' at the bottom? My assumption (which absolutely could be wrong..) was that the 'wings' are what stop the nut from tightening to the point of binding the pivot... Love the way the Cyclone shifts, but wow this seems like an iffy design decision (the tab, not the hack!).
I think the main purpose of the tab is to have something above the spring after its put in the slot, to keep the nut from bending in the two halves of the slotted bolt.
#5638
Quoted: 472 Post(s)
Liked 1,047 Times
^^^^^^^ FWIW: I have that RD on my Fuji TS III and it also lacked that wee tiny “wedge” when I got it. I overhauled the RD and could not figure out what the wedge was for, given how the other parts went together and held everything in place. I did wonder about dirt getting inside the housing so fashioned a rubber plug for the hole. I rode that bike a lot for a couple of years without issue. The RD operated flawlessly. Last year I found a trashed Cyclone and salvaged the wedge then installed it on the Fuji just because……..
I’m not convinced it’s needed but it cost Suntour a pile to design, manufacture, stock and install the bitty things so it must have a purpose. But I would not worry about riding without it. YMMV.
#5639
Quoted: 761 Post(s)
Liked 1,563 Times
#5640
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Hmm, I think you were lucky. Initially I thought maybe I can get away without it, but I've been riding the bike with the bit missing and checking the pivot nut after every ride and it loosens up enough that I'm sure it'd eventually fall off (with obvious disastrous result). If I tighten it enough so that it doesn't self-loosen it doesn't pivot freely... I'm going to give the screw-driver tip hack a try for now.
I first took one apart in the 70's, thought that the piece was just to keep the bolt from squishing together myself after first saying WTH?
Would have been around the same time that I detroyed a Simplex rear derailer by ignoring the mounting bolt on the back side of the dropout and prying out the plastic plug before removing it with a big Allen key.
Ignorance was bliss, until it wasn't!
Likes For dddd:
#5641
Quoted: 1106 Post(s)
Liked 1,328 Times
Likes For oneclick:
#5642
A long shot but here goes - Rocky Mountain Sherpa 30 853 frame in an XXL. This is the long discontinued touring bike frame, not the newer mountain bike. Have Dura-Ace 7700 Road Hubset + cashola for swap. Gotta be an xxl (6'4" rider)
#5643
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 535 Post(s)
Liked 1,009 Times
#5644
Old guy & bikes
For trade (or possibly sale): Front wheel, working GH6 hub, Raleigh Pattern rim. Wheel runs true and has no dents, spokes are reasonably tight. I'd call it a serviceable wheel. Some surface rust on hub and rim, but could be dolled up with rubbing compound and aluminum foil treatment. GC cloth rim strip.
I'm looking for a 36 hole GH6 hub, optionally built into a Twenty rim. It need not be cosmetically great, but I'd like it to have minimal rust.
#5646
actually i guess newbie
I’ve got a Miami Vice Ironman (Tange 1) with a 64cm CTT seat tube in the shed, if that would be of interest. May be on the small side for you.
It’s broken down into a frameset hanging up and complete groupset (Shimano 105) in a box somewhere. Condition is pretty good, as I recall.
#5648
#5649
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
I have a pair of Fiamme Red label tubular rims (36H). One has a couple dents. I would like to find a replacement. (This is for my low budget Automoto build and will be mated to some FB hubs.) The labels look like this one nicked from Velobase:
I've got stuff to trade. Interested in a pair of Wolber anodized Arc en Ciel rims, Sugino crank (165 or 171), or ...? I can probably dredge up more trading material.
#5650
Bikes: many
Liked 1,396 Times
Likes For smontanaro:
