Addiction 2022.3
#5476
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
#5477
Quoted: 8281 Post(s)
Liked 9,053 Times
I had a friend who was obsessive about the cleanliness of his bike, like if it got wheel spray during a ride he would have to clean it off. One time I ran over a ketchup pack and it squirted on his bike. If looks could kill....
#5478
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3196 Post(s)
Liked 1,844 Times
Just back from a bonus Labor Day ride. It was mostly good, with one minor exception:
One of the riders had a flat. That's no big deal, I don't get angry about flats, it's part of the deal. I usually try to be at peace with this and only really get annoyed if I am under a time crunch (which I wasn't). My general strategy when others flat is to ask if they know what they are doing, and if so, just stand back and bite my tongue if they have a minor screw-up....and only give suggestions if they are really messing it up.
So I sat back and found a shady spot. The guy with the flat is a very experienced rider, and I was hopeful this would be a 3 minute pit stop. It was not meant to be.
He got the tire off and popped in a new tube. I usually think it's best to run the inside of the tire to find/remove the culprit shard (unless this was a pinch flat). He did not do that. He got frustrated remounting the tire and had to use a tire lever (I bit my tongue about that too). Then he broke out his "new" C02 inflator. He screwed the cartridge on and then screwed the inflator onto his valve. He started messing with the device and after a couple of minutes he was not getting any airflow and decided to take the inflator off. He could not, it was stuck, so he took the cartridge off (BOOM!) and was able to extricate the inflator and borrowed someone else's. They inflated the tire and (of course) it did not hold any air. I finally spoke up and said "please let's run your tire for any shards and please put another tube on without using the tire lever," one of my friends who was closer to the action apparently ran the tire with no shard, and the rider was able to (with some frustration) install a borrowed tube, remount the tire without a lever, and get it inflated.
Total time: approx 20 minutes.
I really wish all cyclists who run tubes and want to use C02 would do a trial run in their garage so they know how to use it. I also wish they would know to inspect the inside of the flat for the cause, and to use the center channel of the rim to minimize need to remount tire with tire levers.
TL;DR datlas had a fun ride but was slightly annoyed by his fellow cyclist's amateur flat fix skilz.
#stillgrateful
#firstworldproblems
#stillgrateful
#firstworldproblems
I remount tires with a lever and rarely have issues. You just have to know where the tube is, and don't go about it ham-fisted.
Occasionally I have to use a lever for the first bead.
#5479
Quoted: 1400 Post(s)
Liked 1,882 Times
Mariners first round pick this year is a kid I know (from our school district; he was a few years behind my youngest kid)
a kid from nearby district my youngest played against was the Giants first round pick in 2021
Likes For t2p:
#5480
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Good friken weekend! 3 awesome rides. Didn't get called in to work even though I'm on call, my favorite!
Blue is giving me problems with the rear mech. A week ago it started dropping the chain and shifing was like dropping the cutlery drawr. I put a new chain on a month ago because it wasn't shifting well. Thursday night I put an actual Sram chain on, it didn't help. Tried a different hanger, no effect. So I swapped to a different cassette. Now it's acceptable. I have no idea what changed. The place in its adjustment where it upshifts the best has a place where the downshift won't perform on 7th gear. It just chatters. So I am running in a compromise position, adjustment wise. I am going to try a different cassette, same gearing different manufacturer. So strange, it was flawless.
#5481
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Yep, they were new and the Orange Seal people basically said, "sorry." They said to just keep soaking and hope for the best and it kept getting better with each wash until you couldn't tell anymore.
Keep the chain tight!
Likes For Trsnrtr:
Likes For 2manybikes:
#5483
Bikes: Shmikes
Quoted: 10175 Post(s)
Liked 5,871 Times
That is one unpleasant job! The worst part for me is facing the 10 yr accumulation of crap in the cabinet.
Likes For MoAlpha:
#5484
Bikes: Shmikes
Liked 5,871 Times
And why did my fender get destroyed the last working day before the first rainy workday in months?
#5485
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
So, last week I observed that we had had an exceptionally temperate summer. Me and my big mouth.
Yeesh.
Yesterday it was about 97-98 at the peak, but right now, with the humidity at <20%, there's not a lot to slow the temp rise. OTOH, when the sun gets lower, there's very little to keep the heat in, so it cools down into the 60s overnight.
Yeesh.
#5486
shaken, not stirred.
Bikes: I've lost count.
Quoted: 1412 Post(s)
Liked 971 Times
Welcome to spring. First snow setting on the ground for a couple of years.
vBulletin: snafu
Likes For gnome:
#5487
Quoted: 3361 Post(s)
Liked 3,638 Times
#5488
Liked 3,638 Times
Speaking of rainy weather, we've received about 3.5" over the last two days. It's been off-and-on all day today so I finally just said screw it - so long as it's not raining at the start if I get wet then I get wet.
Got to climb Paris in the rain which is always such a treat. Just took it easy and enjoyed the coolness and dark misty turns. I will say that descending in the wet on rim brakes is a bit unnerving
One of the best results of the day was how well the new chain lube I'm using worked. I switched to Silca Super Secret a few weeks ago and I was super happy with how quiet everything stayed even through a thorough soaking and grimy roads, plus a quick wipe off at the end of the ride was all it took to clean up.
#5489
Bikes: Shmikes
Liked 5,871 Times
#5490
Quoted: 20810 Post(s)
Liked 9,456 Times
#5491
Liked 9,053 Times
#5492
Liked 9,053 Times
#5493
Liked 9,053 Times
#5494
Quoted: 1279 Post(s)
Liked 1,393 Times
too hot to ride…. but drivetrain and bike thoroughly cleaned and new drip-waxed chain installed.
#5495
Liked 9,053 Times
#5496
Bikes: Shmikes
Liked 5,871 Times
Didn’t think to go back for the free fragment, but yes.
This set had those breakaway tabs, which actually might have saved me some maxillofacial surgery one time. Unfortunately, they didn’t save the fender.
#5498
Liked 9,053 Times
#5499
Liked 11,912 Times
Now I'm just waiting for the outside temp to drop to 90, because that's about where the house is now.
#5500
Liked 3,638 Times
Likes For abshipp:
