Bike Myths We Wish Would Die
#426
I'm not saying that you don't know how to steer a bicycle. I'm saying that with a bit of training there are ways to steer a bicycle better.
Ever wonder how the show-boat motocross guys make their bikes do all the fancy trick stuff in free space 30 feet off the ground? Co-opting gyroscopic procession to move the vehicle. It's pretty hard to move your weight around when both you & the bike are floating in free space. Rider weight effectively does not matter.
True. The motorcycle, by the very nature of it's size & speed means that the necessary skills must be employed or you become a hazard to yourself & everyone around you. Hence supplemental endorsements & skills testing.
On a bicycle the penalty for failure of skill is generally pretty low & usually limited to one's self.
Also I don't see how stuff done in the air is relevant to steering inputs on the ground.
Likes For Daniel4:
#428
Quoted: 1084 Post(s)
Liked 687 Times
Well, it kind of was, tangentially. The supposed "myth" was that the difference in mass at the rim of a wheel has more of an impact (that many of us, including you, readily admit you can actually feel) on the way a bicycle handles and behaves, than the same weight on the frame. There are a few here who are claiming that adding a pound to each wheel is no different than adding two pounds to the frame.
#430
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
#431
Quoted: 1563 Post(s)
Liked 1,737 Times
Myth: Biopace chainrings were a poorly conceived and executed folly and are worse than useless.
Fact: Biopace chainrings are arguably not great for cadences above about 80 or 85. But for the lower cadences often used by non-racers, who comprised the target market of users for whom the rings were designed, they're pretty good. Not worlds better than round rings, but maybe a bit more efficient for that use.
#432
Quoted: 3958 Post(s)
Liked 7,312 Times
#433
Habitual User
Liked 8,100 Times
Not just the road. Trails and bike paths have dangers, too. Hell, I crashed in my driveway hard enough that the wounds on my knees and elbows are still healing 2 weeks later. If it wasn't dangerous, we (most of us, anyway) would not feel compelled to wear a helmet when we ride.
#434
Liked 7,312 Times
If you keep the differences small, you can use a model similar to the calculus, to zero that out. As the difference increases between the two, those tow values will continue to digress. You're the math and science guy, so do a simple plot. At approximately two for one, it doesn't take that long for the two lines to separate, if you use larger numbers for your weight differences.
Originally Posted by 3alarmer
Again, you are taking a specific case (or a number of specific cases), where the two rim weights are not that far apart, and using it to argue to the general principle that rotating mass has very little effect at any speed. I'm not talking about flywheels, or how acceleration is the only time you run into this. I'm talking about a broad range of handling effects that become more and more noticeable as the quantities increase. Think of it like adding salt or sugar to a soup. Big pot of soup, small quantities of salt/sugar = no problem. Or don't. It's not like I care any more. I'm just here drinking my tea.
We've been over it enough for me to know you must understand what I'm saying, it's just inconvenient to your argument to acknowledge it..
#435
I think most people simply misunderstand how Biopace works. A lot of people thought that it's there to lower the gear ratio when your leg has the most leverage at around 3 o'clock. When it's actually the opposite. It lowers the gear ratio near the 5 o'clock point. It's not there to let your leg perform more work when it has the most leverage. It's there to stop you from over-stomping 6 o'clock. The tendency for most people is to continue stomping downwards even when the pedal is at 6 o'clock, and this is obviously wasted energy. This is especially true when you are standing and pedaling. Another instance when this happens is when you are going down hill and spinning your pedals at a high speed. Sometimes you find yourself bouncing off the saddle- this is because you are over-stomping 6 o'clock. Biopace is designed explicitly to counter this tendency.
It makes a lot of sense that Biopace is designed to counter the tendency to over-stomp at the 6 o'clock point, which can lead to wasted energy. I can imagine that this would be particularly useful for standing and pedaling or going downhill at a high speed, when it's easy to lose control of your pedaling technique.
#436
Quoted: 5793 Post(s)
Liked 2,594 Times
Possibly the best arbitrators of whether bicycling is dangerous or not are those who do these calculations professionally. Specifically life insurance actuaries.
Just about every life insurance company, not only considers bicycling safe, and will not deny their best rates to cyclists. Moreover they not only say that bicycling is safe, but can show that the health benefits more than offset the risks.
So, to those who say bicycling is dangerous, I say not bicycling is more dangerous.
This isn't to say that it's absolutely safe. Like just about everything else, it's not about statistical risks, but how we manage them.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
#437
Habitual User
Liked 8,100 Times
#438
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
When looking down the steer tube at the rotational motion of the wheel, inputing a force 90 degrees to the rotational axis (turning the bars) forces a perpendicular force at the top of the wheel to drive the bike over into a lean. This is how a steer is started. Now that the bike center of gravity is no longer under the rider, a fall inward towards the ground is the consequence. The rider cleverly turns the bars the other direction causing an opposing force at the top of the wheel to counter the initial fall & remain in equilibrium in the new orientation.
A rider who has mastered this skill can change his line mid turn or make any necessary course or balance adjustments at speed & remain in full control keeping the desired line of travel under the apparent center of gravity (or not) of the rider as desired.
Bikes wheels have a lot less inertial mass than motorcycles, but proportionally more in relation to the body (bike frame) they are acting upon. Ie: Bikes are nimble enough most people don't realize how it works & do ok. Motorcycles OTOH, a failure of understanding & mastery can have disastrous consequences.
Between seeing a pile of sand in the middle of a high speed corner and hoping for the best & seeing a pile of sand in a corner & readjusting my line on the fly to avoid it, I'll choose adjusting my course every time. Indeed, I counter-steered forcefully to avoid a 30mph vehicle collision just today.
Paraphrasing my thoughts on the debate raging in the other thread:
The forces involved don't have to be big. Just strong enough to act upon the bike frame. It's the "why" behind why light wheels feel nicer & heavy wheels feel like pigs. With lighter wheels less effort is required to change the wheels plane of rotation. So, although the moment of inertia is essentially insignificantly different in terms of forward motion of the bicycle, the lighter wheel requires less input effort to act upon the frame.
(I'm sure I've mis-typed something, somewhere. But that is the gist of it, anyway.)
Car dependency is a tax.
#439
Quoted: 4227 Post(s)
Liked 2,488 Times
Carbon, on the other hand, is stronger and much more durable by weight than aluminum, so the carbon post need not be so thick, so the seatpost made from carbon can be less rigid than one made from aluminum.
Carbon fiber compared to aluminum is:
- over twice as strong by cross section area
- about half the weight by volume
#440
Habitual User
Liked 8,100 Times
Here is a little challenge for you. Take a carbon seat post and an aluminum seat post and bang them hard against a rock and see which one will break first....or put them both on a vice then put a long pipe on one end and try to bend them and see which one will snap first.
#441
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
Only because it had nothing to do with the big claims being made about the performance aspect of lighter wheels i.e. "huge gains in acceleration and braking". I thought we were just debunking popular myths here, not discussing how "touchy-feely" our bikes are. Did I mention any myths about that?
That 1.85 factor is just a rough estimate if weight is added at the rim. You have to look at the where the extra wheel weight is actually located to come up with the real number. If you're considering the extra weight of a deep vs. shallow wheel, for instance, then the factor is likely 1.5 or less.
We can therefore define limit as a number such that the value of a given function remains arbitrarily close to this number when the independent variable is sufficiently close to a specified point.
Originally Posted by me
I wrote a specific answer to a specific question, and stand by my 1.85x estimate for that limited purpose, In the second paragraph, I clearly stated that this was specific to inertial considerations only, and tried to offer some big picture perspective. So, while it may mean little in the big picture, wheel weight is still roughly equal to 1.85x frame weight.
I think the 1.85x is reasonable when calculating wheel inertial forces during acceleration, but as per Zipp's calculation in post 65 above, it's worth next to nothing in terms of real world power. I would say it shrinks to the wheel mass being worth exactly the same as any other mass on the bike. Given that the power requirement due to rotational inertia is less than 1% of total power required to accelerate, we are talking about small fractions of a percent when reducing wheel mass and only then when actually accelerating. Unless we hit the brakes we also recover the energy from accelerating the wheels when decelerating.
Quoted: 2490 Post(s)
Liked 2,961 Times
Which, in turn, reminds of a conversation I witnessed at a Shimano presentation to bike shop owners and employees in the Baltimore area that was conducted by Stetina.
He'd finished talking up a bunch of the current and forthcoming Shimano products and asked for questions. Alex, the owner of a chain of bike stores in the Baltimore area, stood up.
"Wayne, did I understand you to say that any Shimano-equipped bike we order from any of our brands next year will come with a Biopace crankset? No exceptions?"
"Yes, that's right."
"So---a customer comes in one of my shops. Wants a bike. Cash in hand. Doesn't want Biopace chainrings. What do I do?"
"Well, I hope you'll explain to the customer the advantages of Biopace compared to conventional rings."
"Wayne. Listen. I said: cash in hand."
Wayne [looking uncomfortable]: "Well, I guess you'll have to sell the customer a bike with some other component group."
Likes For Trakhak:
#443
Liked 2,488 Times
#444
Liked 7,312 Times
...do you recall any of the basic math you took as an introduction to differentials, or do you just use the formulas ? The brilliance of differential calculus lies in exactly this use of smaller and smaller differences in values as we approach certain "limits", to the point where we can consider them as unimportant.
...anyway it's a simple linear plot on an xy axis. Draw one line with a rise of 1, and run of 1. Draw another with a rise of 2 (or 1.5, since that's the number you prefer),and run of 1. What should happen, is that they diverge. That divergence represents the difference between weight on the frame, and weight on the wheels, as those values increase. I'm sorry, but maybe this explanation is too basic for your skillset ? Feel free to once again insult me. I'm kind of immune to it, by now, and it probably helps you to vent.
...OK, you don't agree at all, you think it's zero. And the tomato guy doesn't agree, and wants it to be less, at 1.5. I stand corrected in thinking there was any sort of agreement at all. World peace is difficult because of just such misunderstandings.
Regardless, the 1.85 factor is a red herring. You can use any number up to the maximum factor (= 2) and it doesn't change the fact that the effect of the rotating mass is insignificant.
#445
Quoted: 6975 Post(s)
Liked 10,975 Times
#446
Quoted: 7653 Post(s)
Liked 3,485 Times
My understanding is that the differences with CF As A material is that it damps vibration better than steel or aluminum. CF is "deader" somehow, which means a whack on the end of the forks doesn't travel to the other end so much. This made CF a very attractive material for forks because steel, to take the stress, will either be be heavy or exceedingly springy, whereas CF forks can have all the strength and much less weight---and while the CF forks won't dissipate impacts with harmonic vibration, they simply damp it out through lack of resonance. (AL forks .... beat your palms, but they are lighter than steel.)
Steel is springy, and will do some sort of harmonic resonance thing which transmits the feeling but takes the edges off---a sharp impact is fully felt but not as a sharp impact. The fork quivers which dissipates some the the energy and spaces out the impact over a span (admittedly very short) of time ... in essence, you feel many smaller impacts but each is smaller.
Aluminum, usually being stiffer in bike applications (because "springy" aluminum is aluminum using u its fatigue life in a hurry) so Aluminum forks transmit every impact and doesn't damp it at all .... one hit at one end, the same hit at the other end, just as short and sharp.
However .... as many (including Sheldon Brown) have noted, it is what you make, not what you make it out of. Carbon can be formed across a wide range of parameters, with different weaves, orientation of weaves, number of layers, and amount of epoxy. CF is probably the most customizable material .... the down tube/seat tube juncture can be rock solid while the chain stays and seat stays act as springs, the seat tube can get slimmer so it offers some minor flex, whatever ... and since CF doesn't fatigue from flex or vibration, all kinds of characteristics can be built into the bike's parts, and all of them could last a very long time (but they will eventually assplode ---- i know, because I read it here.)
Steel and aluminum can be formed pretty extensively now if people want to pay the money for hydroforming or olio-forming or whatever the latest, best, tech might be ... but it is still a lot harder to form than CF. Still, metal is generally more accepting of minor abuse than CF (gasp! I admitted it!) not because CF is brittle, generally, but it is less forgiving from point-impacts than most metals. Most metal bikes, if whacked with the peen of a ball-peen hammer, will dent. I invite everyone else who has a CF frame to do the same test at home .... be sure to video it. I might be wrong, but I am pretty sure that more times than with a metal frame, the CF frame will sustain serious (though probably patchable) damage.
That said, I have dropped or seen knocked over my CF bikes, have crashed them, have dropped other bikes against them .... CF is really tough. But I am not recommending it to people who disagree ... those folks are completely correct that CF will assplode and kill them.
It will be amusing to see what BF makes of all this mess.
#447
Quoted: 4421 Post(s)
Liked 4,874 Times
...I have made no "big claims" in this thread. I have simply stated what seems obvious to me, that limiting your examples to small differences gives you a very different picture of the experimental results. And that it's probably unwise to generalize, unless you state that limitation as part of your argument.
#448
Liked 3,485 Times
Whoops ... i see that a number of others have weighed in more rationally than I on the issue of materials and their properties.
And some, shockingly, as irrationally as I. I suggest a hammer test, another opts for the vice-and-pipe test.
#450
Liked 3,485 Times
Alos ... is cycling "dangerous"? Which is the undefined term?
As for insurance actuaries .... they are weighing the fact that A.) most bike injuries are non-fatal, B.) medical insurance, not life insurance, therefore covers most bike injuries, C.) people who don't get hurt riding often improve their health and longevity. So sure, ride a bike, get a good rate. Also, cyclists are a lot less likely to be smokers, and by definition are not sedentary, which generally increases lifespan.
US cycling deaths as far as I have seen have remained right around and just under 1000 per year for quite a while. That is a tiny number.
People who ride on the road might think cycling is dangerous because it can Feel dangerous---lot so drivers, lots of idiot drivers---but I think it is safe to say that no one who is reading this thread has been killed by a driver---though many of us might have been hit, or run off the road, or been the target of thrown projectiles---I was even shot by a loser with a BB gun---but is it 'dangerous" if we almost never get hurt due to the actions of others and always get back up and ride again, eventually? Not to a life insurance salesman.
