1987 Schwinn Prologue - FINALLY!!!
Old 05-10-18, 08:31 PM
Steve Whitlatch
Steve Whitlatch's Avatar
Quoted: 540 Post(s)
Liked 64 Times in 35 Posts
Sweet looking build. My Prologue is a size smaller than yours. Mine is 20 4 lbs with Suberbe Pro and Tubulars. I have a full Ultegra 10 speed group I am tempted to put on but I have not convinced myself to do it yet. Your is tempting me even more. Really love your build.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
Steve Whitlatch is offline
Old 05-10-18, 09:42 PM
RiddleOfSteel
Master Parts Rearranger
RiddleOfSteel's Avatar
Quoted: 1556 Post(s)
Liked 2,024 Times in 989 Posts
Originally Posted by PilotFishBob
Very nice ROS! I was looking for a Prologue myself but stumbled over an '85 Peloton in pristine condition, so that ended that quest. I only needed (okay wanted) one 80's PanaSchwinn in the collection, and who can argue with Columbus tubing? I'm quite happy - but... Wow, that paint scheme on the Prologue... So, so nice.
Thank you! Can't argue with an '85 Peloton, as I still have mine, albeit as a frameset currently. Light frameset, too!
Originally Posted by belacqua
Looks awesome. Did you simply squeeze the 10sp hub into the dropouts? Do you have an opinion on cold-setting this frame? Asking because I plan to squeeze a 130mm into my '89 Circuit at some point and it would be the nicest frame I've done that to, though not quite as nice as yours.
Thanks! Yeah, I just lightly squeezed in in there. I wouldn't coldset as it's fairly unnecessary going from 126mm to 130mm. From 120mm to 130mm, yeah, I'd do it, and have done it. An '89 Circuit is a proper bike. Columbus SL tubing (like earlier Pelotons) with late '80s Schwinn high-end race geometry (like my Prologue, which is identical to the Paramount except for the fact that the Prologue has 5mm more fork offset/rake).
Originally Posted by jamesdak
Very nice bike and you did a good job building it up. I have a red and white 87 but so love your color even more. They are great riding bikes.
Thank you so much! I would have jumped at a red and white one if it were the same everything as my black/grey one is now. I find red/white to be trickier to compose. Or rather, one's options are narrower. Lots of silver/polish (classic look) or just tons of murdered-out black that isn't too shouty. The red/white paint job has enough going on visually that one needn't not try to compete with it via other 'exciting looking' components, IMO.
Originally Posted by tyler_fred
Great build! Love your speed ma-sheen!!
Thank you!!
Originally Posted by ryansu
Love that black grey combo in the paint...oh the rest of the bike is pretty nice too , Chapeau
Thank you!
Thank you, sir! Fewer gears, no brifters (lighter brake and shift setup), tubulars, plus a touch smaller--makes sense that it's lighter, which is just great. Part of me thinks that, as much as it's cool to have light wheels and some deeper section, a more traditional box section rim and supple tire just work well with old steel frames. Helped on my '85 Paramount (over nice Mavic CXP33's with Conti GPs) Maybe it's just the Vittoria Open Corsa Evo CX tires. Those things are magic.
RiddleOfSteel is offline
Old 05-10-18, 10:00 PM
RiddleOfSteel
Component Update
So as previously wondered about:
1) The Modolo stem is SAFE! It's got the super wide, squared-off lower profile.
2) Potential weight savings. Weighed both Vuelta Corsa Lite wheels--one with the Kenda tire on them, the other with the Vittoria Open Corsa (25mm size). They were within 12g of each other. No tire weight savings. Weighed a 7700 crank arm (drive side) against my FSA carbon example. FSA weighs more by a bit. So at this point, I'm not going to chase sub-20 weight. The bike is built, it's happy. I could do a stem conversion, but there's no need. My Emonda doesn't need its part pilfered either, which is also nice. I really like it built up and the way it is.
Old 05-11-18, 01:56 AM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2155 Post(s)
Liked 3,406 Times in 1,206 Posts
Very nice. I tried to find a silver and gray one for years, finally settled on a very nice red and white one.
To polish the crankset, sand lightly with 200 grit, then spray with Easy Off oven cleaner. Wait ten minutes, scrub with SOS pad, repeat, lowering wait time to five minutes for each subsequent application. Wear rubber gloves, and best to do this in a stainless steel sink or large plastic bucket. This process will remove the thick anodizing.
Then hand sand with progressively finer sandpaper and water, ending with 000 steel wool and good metal polish. Or, use a bench buffer with successively finer grades of rouge to achieve the same result. Wax well after polishing and wipe down after every ride to keep sweat from staining the bare aluminum.
rccardr is offline
Old 05-11-18, 05:13 AM
Narhay
Narhay's Avatar
Quoted: 956 Post(s)
Liked 568 Times in 314 Posts
I have been waiting for the right frame to put together a retro roadie. I also have a modern bike with 7900 and Im glad to hear you are aware of the compatibility issues with the FD-7900.
Narhay is offline
Old 05-11-18, 05:27 AM
jethin
jethin's Avatar
Quoted: 288 Post(s)
Liked 330 Times in 160 Posts
Nice build and fun thread. I think it’s safe to say that a good time was had by all.
jethin is offline
Old 05-11-18, 07:08 AM
since6
Bikes: Stevenson Custom, Stevenson Custom Tandem, Nishiki Professional
Quoted: 367 Post(s)
Liked 196 Times in 128 Posts
Lovely bike and story many many good rides to come, enjoy.
since6 is offline
Old 05-11-18, 10:18 AM
cyclotoine
cyclotoine's Avatar
Quoted: 113 Post(s)
Liked 16 Times in 14 Posts
Good to know on the stem!
Dura-ace cranks were always my favourite. I'm running 180 mm 7800 cranks with Sram red 10 speed on my fast roadie, Dura-ace is lighter and aluminum. Mine are pretty scuffed from the previous owner and I laid the bike down once to the rear derailleur and right shifter now have matching scars so I'll stick with the slightly haggard look.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
cyclotoine is offline
Old 05-21-18, 12:42 AM
RiddleOfSteel
Update Part 1
The Modolo stem gave a bit of a gawky/goofy look in addition to being a bit visually bulky. That combined with the STIs made for a heavy-looking front end. And with a bike at 20 lb. 11 oz. I wondered where I could shave some weight. I couldn't do anything but about 12g at the wheels (tire differences) so I left those alone, as mentioned before. Seat post was as light as anything else I had, and the pedals were single-sided SPD mountain units--much lighter than their standard dual-sided counterparts. The crankset may have been Octalink and of the older 7700 generation, but I was already running the much lighter BB-7700 bottom bracket unit--any weight savings going to 7800+ (Hollowtech II) would be minimal, though stiffness would increase.
So I took a page from a certain red Trek with a stem conversion and converted the Prologue. A black 115mm stem at -17° rise with a lower profile adapter, and with the help of a beer can "shim," it all worked well and looked the business. It felt very sure up front and with all that length, I could guide it through turns. I shaved a whopping 160g (5.5 oz.) in the process! It was comfortable, but like the Modolo/Profile Design setup, was a touch long and made for slightly wonky/tiller-like auto-steering when climbing or accelerating out of the saddle. Well, the conversion more than the traditional.
Here it is looking quite purposeful. Notice the hood shape, where it goes from horizontal (where hands rest) to the vertical knob section. At an aligned side view, that kick-up point is pretty much right on the same vertical plane that the front axle is on. In my experience, same-plane alignment yields neutral--if a touch subdued--steering response. It's always smooth, and if the frame/bike is smooth, then that is a 'match' to it. A kick-up point ahead of the front axle plane makes for 'slower' steering, while a kick-up behind the front axle plane makes for quicker steering. Ideally, one would want the frame/bike characteristics to match the steering (stem, bars, levers) setup. The Prologue is definitely a more lively frame, but it didn't really complain with this conversion setup.
Old 05-21-18, 01:17 AM
RiddleOfSteel
Update Part 2
...Still, the matte black stem didn't quite match the gloss black seat post. Upon a recent test ride with a matching 7900 front derailleur (it's cable pull ratio is only compatible with a 7900 shifter), I noticed the noticeable tiller-like tendency when out of the saddle and how that involuntary turning opposed the mission of going straight forward at all costs. A shuffling of the hands back about three-quarters of an inch with an out of the saddle effort confirmed what I thought: I needed a shorter front end setup, even if it was within comfortable range of my preferred reach dimension.
[ As a side note, the 7900 FD works perfectly. Light, crisp, just push the lever and you're there! I literally pulled the cable tight enough with my fingers, cinched down the derailleur cable bolt with the 5mm allen key, and it was set (well, of course, after I set the low limit). I didn't need to adjust cable tension at all. Wonderful! ]
Enter in this nearly-unused, beautiful black 100mm quill stem I had picked up a few months ago in Portland (while meeting a former Bike Works employee now employed there--that was cool). What was I going to use it for, especially given the fact that I was in major sell-all-the-parts mode? Most likely for a bike I'd build up to sell.
So that of course hasn't happened yet...ugh. So as idleness (of parts, at least) goes, so does the coming up of ideas for builds and modifications. I weigh the Modolo stem: 359g. What a (nice looking) boat anchor of a stem! I weigh the mystery 100mm stem: 286g, a difference of 73g, nearly half the weight I shaved off. Considerable!
I go and unhook the conversion stem from the steerer (all STIs and bar tape still attached to everything) and slot the 100mm stem, with the Profile Design bar attached, onto the steerer. Looks pretty good. I know it won't get my STIs to the elevation they currently live at, but it's only 1/8" or so. The stem/bar combo change (again) is a go. Twenty or so casual minutes later, the change is complete. The reach measurements are confirmed as at or just barely less than spec. Perfect. Proportion looks good, the kick-up point is set back of the front axle plane, and even just standing still over the bike, turning the wheel, I know that the steering is livelier, now fully in line with the frame's character.
A test ride the next day (today) confirms my thoughts. Perfect out-of-the-saddle manners with regard to the front end keeping straight as I rock the bike back and forth. There is no "learning" the bike here, it's just natural and well-behaved, working with you the rider.
I seem to be reaching a point of wanting the saddle to hoods kick-up (reach) distance to be much more to the number (36.0" with my measurement system), and really not stray from it. I can deal with a little extra reach when I'm not tired, but when I do fatigue, feeling like I'm any kind of stretched out and slumping over the bars just adds to the fatigue. I experienced this with my recent (to be shown) Guerciotti build-up--it being a beyond top shelf bike--and now it is the same with the Prologue (still a top shelf bike, just with STIs).
So we're back. Quill stem, matching in gloss black to the seat post. Traditional drop bars, now with 10-speed levers. Looks just right, and works even better.
Likes For RiddleOfSteel:
Old 04-08-22, 06:15 AM
Indytriumph
Bikes: 1987 Schwinn Tempo, 1987 Schwinn Prologue, 2016 Felt Z5, 2022 Vaast A/1, 2023 STS ADVNTR PRO
Quoted: 23 Post(s)
Liked 43 Times in 18 Posts
I just love this bike! I am going to be copying a lot of your build for my recent Prologue purchase.
Tom
Indytriumph is offline
Likes For Indytriumph:
Old 04-08-22, 08:10 PM
RiddleOfSteel
Tom
Thank you, Tom!
I did several more rounds of updating the groupset that made their way into various other threads (though not this one, unfortunately). Ultimately, I sold the frameset mostly due to it needing to be taller once I got fitted more properly to a bike. Basically, I didn't want to have a gawky-looking stem setup on such a gorgeous bike/frame. Priorities, you know?
So I will rectify that! Below is the progression of the above bike to full 7900-era Dura-Ace. Great shifting groupset, and with the right bike color, a sweet looking groupset. Great generation of Dura-Ace. The Dura-Ace WH-7850 wheels (later to be classified under the C24 moniker in the Dura-Ace wheelset lineup) are wonderfully light, strong, springy, yet dampen vibrations due to the carbon overlaying the aluminum rim structure. The Vittoria Open Corsa Evo CX tires were another wonder. Super light and super supple, even for a 23mm spec. This I think was my lightest setup and just under 20.0 lbs (could have been closer to 19.6 lb IIRC). 7900 is a light groupset, and those wheels were not much over 1400g.
The next evolution was 6700 generation (6770 to be specific) Shimano Ultegra Di2, the first generation of E-tubes-based Di2 that only now has been phased out by the new generation (connections are different, at the very least). I would say that this composition was my most favorite. A high-water mark among others. Beautiful, lithe, wonderful shifting, with the tan wall tires setting everything off just right. I sold nearly all my bike parts and bicycles at the start of the whole coronavirus thing as I had lost my job, so the Di2 went away. Thankfully I have found employment and Di2 is back on the menu and I am slowly gathering components.
Right before I sold the Prologue as a frameset, I put it together with full 7800 Dura-Ace, because it's such a wonderful groupset and I also wanted to see how it'd do with silver components. Really nice bike, even if the stem conversion (and stem) don't work with the rest of the composition. Regardless, here is a modernized silver composition to serve as some possible inspiration.
And finally, updating the classic downtube C&V look/composition with A Few of My Favorite Things (components). Like the above image, 7800 for the crankset, BB, FD and RD, 7900 10-speed downtube shifters, and the most exquisite brake levers to ever grace a bicycle (IMO) because of look, feel, and operation: 7402 Dura-Ace. The wheels are Campagnolo Atlanta 1996 rims laced to Shimano 6400-era 600 hubs. These rims are far and away the hardest thing to mount tires to, and were not very light, but rolled well and weren't even that uncomfortable. Handlebars were Cinelli 65-series (Criteriums), which are really comfortable due to their shape. This composition was stellar. Not as user-friendly as my 7900 or Di2 setup, but 100% a looker. Anyways, hope this gives you some ideas and/or "allows" you to not feel like you need to keep a build within a prescribed norm.
Old 04-09-22, 09:10 AM
Indytriumph
Quoted: 23 Post(s)
So many ideas to work with, thank you.
My Prologue is the red and white version and has the Sante group set on it. I cant wait for it to arrive so I can start playing with it.
Thank you for the input, tips and ideas. The possiblities are endless.
Tom
Old 04-09-22, 03:25 PM
RiddleOfSteel
Red-and-white Prologue with Sante sounds like a perfect match! Full late-'80s!
Old 04-27-22, 06:03 AM
Indytriumph
Quoted: 23 Post(s)
I'm looking to replace the cables on the bike. Do you know if newer brake cables will fit in the stays on the frame?
Old 04-27-22, 08:02 PM
RiddleOfSteel
They will fit just fine.
wrk101
Classic & Vintage
60
04-22-13 03:35 PM
cuda2k
Classic & Vintage
89
05-21-12 10:29 AM
runningDoc
Classic & Vintage
6
04-20-12 06:51 PM
CchewW
Classic & Vintage
21
10-20-11 12:07 PM
theschwinnman
Classic & Vintage
14
08-16-10 11:44 AM
