Rene Herse sued over tubeless tire blowoff on hookless rims
#176
latex tubes are a non-starter for most people IMO. I've considered them for a while, but modern rims/tires are just too tight for me to fit them without levers (yes, yes I know that with the right "technique" and gorilla strength, you don't need levers). If you use levers, there's a decent chance you're gonna slice the tube.
Or that it's gonna get stuck under the bead.
#177
ignominious poltroon
Quoted: 2252 Post(s)
Liked 3,465 Times
Me included. Tubes that leak 15% pressure/day would be a hassle. The increased fragility is another impediment. On fatter tires, I have tubeless, but I am not convinced it is worth the hassle. I average fewer than 1 flat per year with butyl tubes, I can pump them up once every month without significant consequence, and compared to all the other things that slow me down, butyl tubes are far down the list. I have 38mm Barlow Pass (the OP tires) on my main ride, and currently ride them tubed. I was thinking of making them tubeless before I read all of this, and I even bought the valves (Peaty's), but my motivation to do this is low, even with HED Belgium + hooked rims.
#178
Quoted: 2333 Post(s)
Liked 2,097 Times
I have latex tubes on my Barlow Pass tires, the rolling resistance is very significantly lower than when I had butyl tubes in them although I do need to add air every other day when riding that bike whereas my Conti 5000 TR S tubeless tires need air every single day. When I used Schwalbe, I could go almost a week without adding air. In reality, I always check tire pressure before a ride and bending over to the compressor is about as trivial as learning how to mount a tube properly.
#179
Thread Killer
Quoted: 3166 Post(s)
Liked 1,724 Times
TPU tubes are the answer when debating between tubeless and latex.
#180
just another gosling
Quoted: 3901 Post(s)
Liked 1,953 Times
I accidentally bought a tubeless-ready hooked rim to replace a worn one. I didn't realize what a PITA it was going to be to run tubes in it because of the shelf or I probably would have sent it back. I'm running Conti 5K on it and they have a heckuva time popping up onto that shelf. I tried latex because that's what I usually run now, but they had a tendency to get under the bead and then pinch themselves during the getting-the-bead-up-onto-the-shelf process. So I run butyl, no problem.
Except that changing a flat on that rim is another PITA because getting the bead down off the shelf and into the rim well is quite difficult. It's almost enough to make be go tubeless on that one rim on that one bike. You think TPU would work better than latex in that mounting process? Or just give up and go tubeless? That's be more novel-to-me technology to have to learn the ins and outs of. On group rides, I see tubeless do repair themselves and just need a pump-up, OTOH they spray sealant all over the bike and rider in the process and seem to get more almost-flats than tubed bikes get real flats. Plus the horror stories, both seen and related, when the tubeless tire really fails.
On topic (sort of), I'd never run a hookless rim. Back in the 60s that's all there were and good riddance.
Results matter
Results matter
#181
Thread Killer
Liked 1,724 Times
As to whether you should go tubeless, that depends on your level of risk aversion, willingness to gear up and possibly face challenges setting up and maintaining tubeless, and of course, which equipment you want to run. The way I see it, Aerothan offers many of the benefits of tubeless over butyl or latex tubed setups, but without virtually any of the hassles or issues of tubeless. When tubeless works, it’s great— I also run tubeless on four bikes— but I use Aerothan on a bike which was giving me headaches because of the equipment choice when trying to run tubeless. The peace of mind tubeless offers, vis a vis punctures, is unrivaled and the systems greatest asset, IMO, but the whole point of this long thread is that realizing the benefits of tubeless can often be outweighed by the frustration of poorly matched tire, rim, and other components (e.g. tape, valves, sealant, pumps, etc.). I also think tubeless is a royal pain if you want to change tires for any reason, be it seasonal, event specific, curiosity or whatever, while Aerothan is as easy as butyl tubes to live with.
Likes For chaadster:
#182
Advocatus Diaboli
Quoted: 4752 Post(s)
Liked 1,537 Times
#183
Liked 1,953 Times
I'm on the fence about that. Bike tires aren't car tires. Several riders in the group I run went tubeless, had disasters, went back to tubes. There are also riders who went tubeless who haven't had disasters. Maybe that's haven't had a disaster yet. Disc brakes went through a period like that, too. So I wait for maturity. "You can always tell the pioneers by the arrows in their backs." IMO hooked rims are a mature technology. Carbon rims are now a mature technology.
Results matter
Results matter
#184
Advocatus Diaboli
Liked 1,537 Times
Likes For Sy Reene:
#185
Liked 2,097 Times
#186
Liked 1,953 Times
I see. Makes sense - the industrialists want to sell us whatever is most profitable for them, the fewer options, the more profit. OTOH, we get it down to 1 tire, 1 rim, no tube, that should be less expensive for the consumer. Progress, quite so. Very clever - I want to try TL because the rim I wanted is a PITA with tubes. Push marketing. With hookless, I suppose they can switch over to making all the new most desirable tires so that they don't work on hooked rims thus forcing us onto more profitable rims, TL of course, and we have to buy new rims, all the better.
Results matter
Results matter
#187
Liked 3,465 Times
I just received a pair of Barlow Pass 38mm tires and am setting them up tubeless on my hooked HED Belgium+ wheels. (I've been using these same tires, but tubed, for years.) I followed their suggestion and seated the tires with a tube and after a couple of hours, opened up one side, pulled the tube out, put my Peaty's valve in, re-mounted the bead, and inflated. I used my canister, but I forgot to take out the valve core. It worked perfectly the first time, both front and back. I still haven't put in any sealant and they've stayed inflated for several hours.
Now I have to decide between Panaracer sealant and Orange Endurance.
Likes For Polaris OBark:
#188
Quoted: 18883 Post(s)
Liked 10,646 Times
I've been using my wheels with tubes for a while and went back to my tubeless ones today. Same loop on each wheelset. Different wheels, tires, everything; tubeless is just one of many things contributing to the better ride, but my god I love this!
What a wonderful time to be a road cyclist!
Likes For Seattle Forrest:
#189
Liked 3,465 Times
Maybe I should ride them without sealant and live on the (hooked) edge.
I could start a new trend: tubeless commando.
#190
Liked 10,646 Times
The sealant will come in handy if you find anything sharp though.
#191
Fat n slow
Quoted: 3259 Post(s)
Liked 2,086 Times
I agree. TABR tubeless was an unmitigated disaster for me. And, it seemed I would flat more often. So, I switched back to tubes. I am hoping the tech is better now, I recently switched back. Fingers crossed. The GP5000 TR S tires are not faster than my latex tubed GP5000 but it would take many replicates to say for sure they are a little slower but I think they are a little slower, maybe if I removed the 45ml of sealant or cut it in half.
#192
Quoted: 2724 Post(s)
Liked 488 Times
Also, being a defense lawyer, I may not be very sympathetic to plaintiffs, but who files a law suit over what essentially appears to be some road rash?
Any tire can blow out and lead to a fall, for any number of reasons. It’s a risk inherent in cycling. When the adverse consequence is some road rash and a pulled muscle, put on some tagaderm, and suck it up.
#193
Liked 2,097 Times
#194
Super Modest
Quoted: 10978 Post(s)
Liked 4,641 Times
I use 2 oz., so 55-60 ml
Keep the chain tight!
#195
Liked 3,465 Times
I just put in about 60ml of Panaracer sealant in each tire (38mm Barlows).
I found that my Leur lock on the syringe (or the syringe itself) very effectively filtered out a large amount of the particulates (walnut shells) when I filled the front tire. For the pack, I just used a conical nozzle and plastic tubing. I am wondering if I should add about 30 ml more to the front to try to re-introduce some of those larger fragments. (The idea that they help clog large holes seems dubious at best.)
#196
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
I use 60ml (2 oz.) in road tires - Specialized Roubaix 2bliss in a 32mm size.
#197
Liked 10,646 Times
Likes For phrantic09:
#199
Liked 3,465 Times
