For the love of English 3 speeds...
Quoted: 7351 Post(s)
Liked 2,477 Times
Anyone who understands 4 and 5 speed hubs, want to comment on this drawing?
Larger version here. It is beautiful, obviously, but there's something I'm not understanding.
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The question is, does this make sense to you? Forgive me for being cagey, I don't want to draw your attention to anything in particular, but I will say, this drawing does not make sense to me. If you know what the inside of a hub looks like, look at the drawing, and ... what do you think?
www.rhmsaddles.com.
www.rhmsaddles.com.
Bikes: As my watts decline, I’m amping up!
Quoted: 153 Post(s)
I would suggest getting a DL-1 roadster instead of the lightweight DL-22 type frame. Far more rugged with a rear fork like a racing bike instead of a brazed in drop out. You'ld have to have reeeeel strong legs to flex one of those puppies.
edit: If you really love 3 speeds, you'll end up with one someday anyway!
As my inquiry post indicated, I'm using my SA 3spd in a very unique way; 2spd with granny low on an eMTB.
Hoping to locate a pair of sliding dropouts that will fit a Soma B-Side with an axle slot only the thickness of the flat sides of the axle (~8mm). Soma and Paragon dropouts are 10mm and the torque twist washers with single tab aren't cutting the mustard on my vertical drops. Maybe some of the experienced 3-speeders in this thread will know if there are any out there to be had?
FYI: Nice bike you posted up there!
Omg
I DID IT!!! Yes, I completed reading the entire thread! All 13,000+ posts/550 pages! In the time it took me to read this (on and off over a number of weeks), I have bought 3 Raleighs (pics to come), completely tearing down and rebuilding two of them. I have built the DIY cotter press from Harbor Freight (works great by the way), rebuilt hubs, built new wheels - wait - I have bought 4 Raleighs (donor parts bike) and sold 1... In addition to the wrenching, have put on (along with my wife) more than 100 miles on these great bikes in the last month.
Thanks to all who have contributed. Haven't posted in over 6 years, but this thread and these bikes have me back on this board...
Likes For jungwiar:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
https://advrider.com/index.php?thread...thread.135295/
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 444 Times
Quoted: 1299 Post(s)
Liked 103 Times
Everything was going along well with my 73 Sports project until I took the AW apart today. These pawl pins are rusted solid. Soaking in an acetone AT fluid mix now. We'll see. The hub shell is in very good shape on the outside so this was a bit of a surprise.
Oh man - don't look at that! Since I posted last here, I have "cured" myself of buying Honda twins as well... Down to one ('74 CL360) in the garage (well, not counting the two others in parts).
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
Attachment 580631
Attachment 580631
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Liked 103 Times
Well, it goes to show you never know what you'll find until you open up a hub. Looks perfect on the outside. It will be a little disappointing if I can't get the pins out. I won't be able to call it a 50 dollar bike. I'm not going to sacrifice any of the good 50s hubs I have for this. Still, it is a good bike. Well worth putting another 50 bucks into if I have to.
Liked 103 Times
Whew, after an all night soaking I was able to pry the pawl pins up enough to grab the top with pliers and pull them out. Got everything degreased and soaking in Evaporust now. All the parts except the pawl springs look reusable. I'd better replace the other pawl springs too. They're .011 inch wire. I have some .012 guitar strings, they'll do.
@BigChief - I love it! It will be fine. FYI a Dremel tool with a small stainless steel wire brush attatchment does with Nedra with stuff like that. Wear a mask though, otherwise you'll inhale rust.
multimodal commuter
Liked 574 Times
Liked 103 Times
Liked 103 Times
My problem now is that the only .012 wire I have goes with sets of expensive strings for my acoustic guitar. The bulk packs I bought for my electric go from .010 to .013. .013 would be quite a bit stiffer than the original.011. I'm reluctant to go lighter with the .010.
multimodal commuter
Liked 574 Times
This shape isn't too difficult to form since I have an original to copy. I'll chuck different drills in my bench vise and wrap wire around them until I match that radius. Then I'll see how far to wrap the wire around the drill until I match the end that comes off the radius at an angle. The other side is straight. Then I'll make those two bends with needle nose pliers and cut to length.
You can get individual strings on eBay reasonably cheap:
Professional 150XL/.304mm Guitar String 0.012in Musical Extra Light 88MM | eBay
Might take a while to arrive, but no harm in putting in an order sooner rather than later.
www.rhmsaddles.com.
www.rhmsaddles.com.
My Fleet
My contribution and current fleet:
Top Left - '73 Sports & Newly Aquired step thru Robin Hood. Hub says '69 on this one. Got for $20 in rough shape... New front wheel, rear rim (rebuilt with original hub), tires, full strip down and rebuild and linseed oil for the patina. Apologies for non-drive side shot. Mid-way picture on 20 mile rail-trail run...
Next - 1973 Sports in "Platinum" - have had this for 6 or 7 years. Bought from a co-worker returning to Sweden. New tires and B72. Solid bike - co-worker commuted on it year round for a number of years...
Next - His and Her's '70 Superbe's. Near mint condition! Bought from original owners with keys, racks (men's not installed), one pump, B66's in great shape, original Dunlop "White Sprite" tires and tubes, working Dyno hubs/lights... Unreal how nice these two are.
His and Her's in action - mid-way thru another 20 mile rail-trail run...
Finally, after complete strip down and rebuild, post past-Sunday ride. Hard to beat this ride with no one on the trail, Packer's game on the radio listening to them beat down Seattle (OK - maybe a stretch there) and a couple cold ones in the cooler.
Liked 103 Times
I ended up just using the needle nose pliers to form the wire. I used the .010 guitar string I had on hand. Remember the official size is .011, but the 10 seems to work fine. All you need is a circle big enough for the pin to fit through, kinked enough so it doesn't slip backwards off the pin and that little foot up front. The Evapo-Rust worked wonders after an overnight soak. So, I'm back in business. Might take a couple evenings off from working on this. Don't want the project to be over too fast.
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
Musical pawl springs - too cool for school Big Chief - I love the innovation on this thread! I'm very impressed with the evaporust clean-up too - that hub was looking POTUS orange
Looking at your fleet jungwiar - Raleigh did choose some really nice colours. That darker grey platinum is classy. And the other colours I've seen on this thread too - the light metallic blues, the golds, silver, and of course the shades of green, make for very good-looking bikes. With my DL-1 stripped down to bare metal I was very tempted to go with a darker green 'british racing green'. But I've stuck with black, and currently 1/2way through randyjawas brush painting advice.
rhm - I have two S5 hubs but I can't tell what is wrong with the image (nice image btw) - please share what you've seen?
Liked 2,446 Times
Here's a pretty one.
https://richmond.craigslist.org/bik/...306909625.html
1963 LADIES ROYCE UNION 3 SPEED - $149 (CHESTER)
NICE SHAPE
NICE SHAPE
Liked 444 Times
The $50.00 Superbe
Someone before me spent a little bit of money on this bike before I got it last weekend.
Not sure if they spent wisely....
I posted before that it appears someone tried to re-furbish the rear hub and had only succeeded in wrecking it.
The sun gear was completely ground down...
And the hub was way too tight. The adjustable cone side had the locknut and washer reversed as well.
The headset has been replaced and the chain and cables are new.
It also has a suspension seat post.
In any case, it's back on the road and I may take it to work for a while to get around on.
On the road
Quoted: 373 Post(s)
Liked 857 Times
Attachment 580878
Attachment 580879
Attachment 580880
Attachment 580878
Attachment 580879
Attachment 580880
Then the transmission breaks down and the person sells the bike (for $50 here, it's still a good buy). "I took it to a shop, and it's broken again, so this thing sucks!".
I once worked on a bike fresh from a shop that was having issues. I immediately saw: (1) the front hub was on backwards and (2) the cones were set up all wrong on both the front and the back.
Liked 444 Times
Today, even a bike shop can make these mistakes. Some mechanics have never worked on an old-type AW, and think they need to run fully tight like many modern hubs (zero play, and totally locked down). The old AWs run loose by today's standards and have pretty wide bearing tolerances, provided you set up the hub centering correctly by backing off the drive side cone by the 1/4 turn the manual calls for. It all goes to hell if you just max-tight down but the drive and non-drive cones. Then you have a hub running gears not properly aligned and all jammed together.
The sad sun pinion below.
On the plus side the wheels are reasonably true, Dynohub works and the paint is presentable.
