#7376
Overdoing projects
Quoted: 784 Post(s)
Liked 1,266 Times
Likes For JaccoW:
#7377
Quoted: 5892 Post(s)
Liked 3,479 Times
1979 Trek 510
The weather is unseasonably warm in central Iowa so it's time to get my '79 Trek 510 fixed up. I flatted last last year and finally got around to replacing the tube. I checked all the adjustments as well. The bike is likely due for an overhaul this year. This is one of my favorite riding bikes and I've changed very little (other than replacing the tires) since I first built it up a almost 4 years ago, https://www.bikeforums.net/classic-v...510-build.html
Likes For bikemig:
#7378
Quoted: 2338 Post(s)
Liked 5,121 Times
Using this unplanned sick day to catch up on some cycling stuff. Finally got around to putting the 35mm Bora Ultra's I bought in the fall on the C40. Used the same tires and latex tubes I had on it. Only change were he brake pads, wheels, and skewers. Much respect to the old alloy gold Shamal Ultra's I had on it. After the changes the bike was only 1 oz lighter, 16 lbs 12 ozs.
The gold Shamals will go on the white Olmo eventually. They should look good on there with the gold lined decals. But first I need to find a builder I can send the fork to for some alignment work. It has never been right and was beyond the comfort level of my LBS to deal with.
Next up today is the Krapf bike, need to swap out the old Dura Ace rings on it for the NOS Superbe ones I got for it. But first I think I need a nap....
Steel is real...and comfy.
Likes For jamesdak:
Likes For miamijim:
#7380
Quoted: 944 Post(s)
Liked 3,010 Times
I picked up my son’s Super Course for a checkup. It was mostly ok but the headset was showing signs of brinelling so I rotated the frame cup and fork race and it smoothed out. Did a bit of fussing with the brakes, gave him a wider range freewheel, new chain, and swapped out a Shimano Seven derailleur for a Suntour something or other that I had pulled out of the Box o’ Crap. It runs much quieter now. Finished it off with a bit of bling, a set of SKS shorty fenders, also from the BOC. I can’t help but wonder if I installed them in the proper orientation?
Likes For ascherer:
#7381
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 584 Post(s)
Liked 704 Times
Torpado
Torpado I am working on is nearly ready to put back together. I am going cheap as I see no future in it for me. Even though the original tires had very little wear on them, I got some others from the co-op for $4 each that are maybe only 20 years old vs 40. Going black on the cables vs the stock white ones as the frame has black accents. For now I won’t have any brake hoods as these Universal levers are hard to get hoods for. Pics when I get done. Perhaps I can dredge up the before and after thread. It is coming out pretty nice and that thread needs revived.
#7382
Quoted: 7367 Post(s)
Liked 2,510 Times
@sd5782, I have a special affection for mid-range bikes like that Torpado. Once you get it working right, I suggest you take at least a short ride on it to appreciate the ride, even if it's not your speed.
Be sure the stem is inserted adequately; it looks too high. And be sure it's clamped onto the handlebar well.
#7383
Liked 2,510 Times
@ascherer, I'm chuckling at those shorty fenders. There's probably no wrong orientation. Other than that, nice work on that bike. What does he say about the bike in general?
#7384
Quoted: 584 Post(s)
Liked 704 Times
Torpado
#7385
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1259 Post(s)
Liked 3,625 Times
These days most of my wrenching is spent getting things apart to fit in boxes...
There were 135 Confentes, but only one...Huffente!
Likes For AdventureManCO:
#7386
The Huffmeister
Liked 3,625 Times
#7387
Quoted: 339 Post(s)
Liked 632 Times
I just sprayed a coat of flat black on the high quality but unknown builder fixie/ single speed frame I got from the Bike Exchange as a pile of rust. A couple hours sanding with a palm sander and 320 grit cleaned off most of the rust . A little sand blasting got into the corners.
For a paint scheme I am going to try for a CalvIn and Hobbes tribute. I have ordered some Vinal decal / stickers from Red bubble and my plan is to put them in various spots then spray over everything with matt clear.
For a wheel set I have one set of black aero wheels
I also have a set of mavic ma 40's which a fellow volunteer laced up for me. The rear is an SA 3 speed hub with coaster brake. I might put them on this bike but I also have a Raleigh Supercourse frame which I would like to dress up as a 3 speed Lenton Grand Prix which I have an almost complete set of decals for.
I would encourage comments as to whether this is o/k. I don't want to miss lead anyone. I just like the idea of a light weight vintage 3 speed "Club Bike". Really though, it would be a custom bike, not an exact replica.
Likes For capnjonny:
#7388
Quoted: 944 Post(s)
Liked 3,010 Times
He loves the bike and rides it around Central Park and along the Hudson Greenway. I’m encouraging him to ride to Randall’s Island.
Likes For ascherer:
#7389
Bikes: Motobecane Grand Record, Motobecane Super Mirage (3x5 speeds), Motobecane Mirage, Atala (unknown model), Peugeot mixte frame Tourist and Schwinn Sport. A bunch more kids bikes. Most recently a Trek Verve One, tricked up for serious touring.
Quoted: 42 Post(s)
Liked 45 Times
Anyone know where I can get 19 inch Zefal toe straps? My wide feet with large toe box shoes are to big for the standard length.
Thanks
Thanks
#7390
Quoted: 1624 Post(s)
Liked 2,661 Times
#7391
Quoted: 228 Post(s)
Liked 273 Times
On the other end of my new Merz (size wise) is this teeny tiny Trek 710.
Almost done building it up to sell, but now contemplating modernizing it and keeping the group set for another frame.
Likes For jPrichard10:
#7392
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Whoops !
Old tubular with some new air gave me a bit of a fright !
Likes For 1simplexnut:
#7393
Edumacator
Quoted: 2495 Post(s)
Liked 3,237 Times
That's why I sell the parts at the moment!
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
#7394
Quoted: 584 Post(s)
Liked 704 Times
#7395
Quoted: 1149 Post(s)
Liked 1,773 Times
Lots of happy wrench for my time lately.
The Obrien repaint had a Cyclone group, which performed solid, but had a 120 or so stem that I just could not get comfortable with. The cyclone was taken off and put to a Club Fuji a number of years ago. The frame has set unused about four years since the Fuji was sold right before “the lockdown”. I call this my Ultegra build, 2x9 with xt rear and Dura Ace front derailers. A campy Veloce double crank with campy cartridge bb adorn with Ultegra chain rings. A couple of years ago I laced up some Ultegra wheels on hi polish rims, however my nds rear spokes were calculated shorter than spec. That wheel needs a rebuild. Presently the Obrien is rolling on a beat up set of wienman rims and very nice DA 7700 hubs.
The polished wheels I have decided need to go to the blue Evans. The blue bike has the blues. I got the thing all together and I see the frame is Ted Nugent, Wango Tango, lol 😤! It needs a Chubby Checker correction.
Here are those two wrapless wonders.
That was last week. The Obrien will get burgundy tape, and the F.W. will probably get white Fisik wrap. Note the Obrien got a flat on the test ride, ah dangit.
This week the flaming red hot Falcon from the Wildwood collection. Some alignment process was needed. That was addressed. the frame is on. The falcon appears to have had major side swiping. This frame was twisted, the seatube and headtubes have been pushed back to spec, and the rear has been respaced for 130mm.
The fork was not spared in need. The fork side to side was on, the offset was good, but bringing it to the table I found the drive side tine was a millimeter+ longer than the nds. I very crudely shortened the drive side and gracefully lengthened and pushed forwards the nds. Actually the tines measured was identical, the forkcrown is where the discrepancy was located.
The wheels on the Falcon are new built from spare hubs and loose rims, the spokes are from orphan wheels that were less than desirable condition. Again Shimano Frankenstein.
Life is good.
Life is good.
#7396
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
Working on my new to me 1985 Trek 2000, I've been ebaying up a bunch of carefully curated Dura Ace parts to do some justice to this old guy. I have a nice set of Mavic wheels laced to Phil hubs to ride on.
just put on one of the cleanest Dura Ace cranksets I've found. Working on a headset the rest of the day. Brakes in the next couple of days.
I still need a nice Seat post but Dura Ace seat posts bring some pretty good money, I'll do it though, I know me.
"ready to navigate"
"ready to navigate"
Likes For bykemike:
#7397
Bikes: Aluminum and Steel
Quoted: 116 Post(s)
Liked 399 Times
Installed my first Brooks saddle. I went for a pedal and discovered I have been missing out! I am impressed with the comfort. It was only a couple of miles, but look forward to longer rides.
“Ride like the wind boy! Ride like the wind…”
-The Voice inside my head, circa 1982
#7398
Cantilever believer
Quoted: 554 Post(s)
Liked 1,919 Times
Just need a fork with more internal clearance, but those are hard to find on C&V bikes...
#7399
ambulatory senior
Quoted: 1957 Post(s)
Liked 3,664 Times
I put together a Gitane Tour De France with some sturmey archer parts and have been adjusting and modifying the build as I ride with my girlfriend.
Currently this is what it is
38-19 gear ratio gives me about 39-70". Enough to keep up with Sarah and still climb some decent hills.
Soma rack and dynamo light.
Found this bar end mirror in my stash.
Inexpensive Chinese headlight with a stand light function that I converted to taillight with acrylic paint.
My 19 tooth cog was made by modifying a freewheel cog. I've ordered a 19 tooth 3/32 sturmey archer cog but honestly this one works great.
Likes For 52telecaster:
#7400
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,324 Times
The fork on my rusty Carabela was worse than the frame. I figured I would just scuff the chrome up and paint it, but I went after it today with some Simichrome. While it isn't great, the finish is now more able to be called patina. I probably will still paint the crown, but I think the socks will look pretty OK from 10' away.
Likes For Chuck M:
