For the love of English 3 speeds...
#1926
Bicycle Repair Man !!!
PJ, those are two of the best specimens I have ever seen.
Sixty Fiver, I can adjust an AW hub with my eyes closed, literally, because I do it by feel and sound. It's one of the first bike repairs I learned, at about age 11. I learned it from a kid in the playground, when he adjusted my hub on my Stingray clone. It had a real AW hub with a giant stick shift on the top tube.
#1927
Bikes: 1968 Raleigh Sports, 1970 Raleigh Twenty
Quoted: 9 Post(s)
Thank you, noglider. I worked hard to brighten them up. Here are some more pics -
https://www.flickr.com/photos/pj311foo/
#1928
Cottered Crank
Bikes: 1954 Raleigh Sports 1974 Raleigh Competition 1969 Raleigh Twenty 1964 Raleigh LTD-3
Quoted: 8 Post(s)
Liked 13 Times
I did the boil out procedure today. It was so bad that I had to pull the parts out of the pan and clean out the pan and do it again as there was so much grease floating on the top of the water that the parts probably just couldn't get any cleaner. This is after I hosed the parts off and wiped them all down with paper towel before giving up on the shellac and heading towards the old pot of water and vinegar trick again.
#1929
Quoted: 3817 Post(s)
Liked 6,744 Times
Well, I spoke too soon about the condition of the AW hub on the '69 Sports I'm overhauling. It rides fine in 1st, but slips badly in 2nd and 3rd. I replaced the clutch (which didn't look worn), but that had no effect. Any ideas, 3-speed cognoscente?
Neal
Neal
#1930
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times
Here's a Raleigh Superbe for $80 in NJ. I should be on my way to pick it up right now but I found my secret grail bike in upstate NY and I'm going to get that on Sunday. So I just can't but it's taking every ounce of charity I have to just sit and watch it go by. So you should go get it. That way at least I'll get to see some decent pictures.
https://newjersey.craigslist.org/bik/2417977359.html
#1931
Cottered Crank
Quoted: 8 Post(s)
Liked 13 Times
Did you make sure there wasn't any goop inside the axle? If there is it could be dragging the axle key and/or the indicator and getting stuck in between 2nd and 3rd in the neutral space.
#1932
Quoted: 17 Post(s)
Liked 43 Times
- Auchen
- Auchen
#1933
Liked 6,744 Times
Neal
#1934
Cottered Crank
Quoted: 8 Post(s)
Liked 13 Times
Wore as in the teeth where the planetary gears ride or how the pawls sit? I could see if the pawls were not pivoting correctly that could cause some problems but that much wear should be obvious I would think. I've never seen any wear like that in the hubs I've worked on but really only one of them was super high-mileage. The only real wear in that one was where the main dirver gear was pinned onto the axle. It was really sloppy which caused a lot of driveline lash but no shifting problems.
#1935
Quoted: 7359 Post(s)
Liked 2,497 Times
PJ, thanks for the more pictures. That's bike porn if there ever was bike porn.
Did you use polishing compound? Or what?
#1936
I was recently lucky enough to find a 1954 Dunelt and 1961 Raleigh Sports. I am in love with both of them, and they have both been ridden several times over the past few weeks. Here are a few pictures
PS - this is my favorite thread of all the internet! I also started a Facebook "like" page for Dunelt bikes. Please feel free to join and post pictures, information, or stories.
#1937
Quoted: 17 Post(s)
Liked 43 Times
I was going to mount the brakes on my Golden Arrow today but stopped because I thought I might need a different color housing.
. . . So time for a little Raleigh esoterica:
What was the color of Raleigh Brake/shifter housing in the '20's, '30', 40, 50's ... ?
I've seen different non-descript green-gray-beige colors, ivory/white ribbed housings, black cloth lined housings, etc - but I don't know which belongs to what decade.
- Auchen
- Auchen
#1938
Bikes: 1936 Raleigh Golden Arrow; Kona Honzo
auchencrow, My '36 GA has light grey ribbed rubbery plastic. Who knows if they are original or not. They are in pretty good shape, just a little splitting at the ends.
#1939
Schwinnasaur
3-speed sizing: I noticed this bike on eBay https://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT which appears to be larger than my 23". Were larger size Sports common.
Also on sizing there is this Clubman eBay https://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT The seller documents all very well. It appears that a size 22 1/2" is larger in a Sports. This bike has a 33" stand over height. My 23" Sport is around 32". I wonder is there a way to predict what size Clubman should fit me given that 23" Sports is good fit.
#1940
Sports models in larger sizes are rather hard to find... bicycles at the upper and lower end of the sizing spectrum are always built in lower numbers because there are fewer buyers of these so after some decades the numbers of these tends to be even less.
#1941
Quoted: 17 Post(s)
Liked 43 Times
Mine came with 2 of those greenish-gray smooth rubber housings and one ribbed white, like what was on my 70's Super Course.
I am pretty sure NONE were original because the GA's quad shifter was replaced.
Meanwhile, my '53 Sports has smooth black housing with a woven liner. (Below)
- Now you would think something even older would constructed similarly. (-or maybe out of papyrus?)
- Auchen
- Auchen
#1942
Liked 6,744 Times
Auchen, here's a shot of the brake housing on my '37 Sports. Much of it is wrapped in what looks like black electrical tape, but you can see that the outer housing is mostly made of some sort of fiber:
Neal
Neal
#1943
Quoted: 17 Post(s)
Liked 43 Times
Thanks Neal - that certainly looks original, but the woven (outer?) housing is now very weathered - Any idea what color that outer covering was - originally?
- Auchen
- Auchen
#1944
Liked 6,744 Times
^ I would guess black.
Neal
Neal
#1945
Quoted: 17 Post(s)
Liked 43 Times
I'm going with black then.
Let's say they used the cloth lined black housing from at least the late 30's into the 50's, and by the 70's we saw that ribbed white stuff. We'll just need to acquire more original examples to fill in the rest of the blanks.
- Auchen
- Auchen
#1946
Liked 6,744 Times
I've had 1950s bikes that had ribbed plastic housing and smooth plastic housing, some of which was likely original. I think it's been around a long time!
Neal
Neal
#1947
Liked 2,497 Times
The woven fabric looks like cotton.
#1948
Bikes: 1972 Raleigh Sports
Could someone recommend a good chain for an old Raleigh Sports ('73)? I was given a recommendation on the Izumi Eco Track chain but thought I'd run it by here first.
#1949
No longer here
This thread.....is now my favorite on all of the forums here-and I don't even own one of these bikes (YET),LOL!
I read through all (ok...most of the 78 pages) in the last few days,some REALLY nice bikes you guys have. I've never restored a bike before (got as far as disassembly on one once,it was too far gone with rust and bent frame),but I want to soon
#1950
Count Orlok Member
I have the SRAM PC-1 chain on my bike. Any singlespeed/three speed chain will probably do. KMC makes some good inexpensive chains.
