The 41 refugee thread
#576
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
I haven't looked at this thread in weeks.
It may be weeks before I do so again.
#577
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
first crash today; low speed maneuvering in some deeper-than-it-looked gravel. Baselayer saved my elbow (which took the hardest impact) from any gravel/road rash. Someone should tell everyone about these things.
Pulling gravel bits out of the leg wounds in the shower is an experience I can live without repeating. This will probably convert me into a leg-shaving type as soon as I'm able. The blood-matted hair is a pain.
#579
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
There is a method to our madness.
#580
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Remember my gf jynxing me last weekend, talking about how I'd never crashed?
13k miles and it happens so soon after she brought it up. Coincidence, I think not.
So, when are you going to email me the photos from Santa Cruz; are you home yet?
#581
Mitcholo
Bikes: 2010 Mitcholo w/ Sram Force/Red
Making a kilometer blurry
#584
¯\_(ツ)_/¯
Quoted: 967 Post(s)
I did my best with clippers. There really were little bits of gravel embedded in the skin when I got home, so it's pretty rough. Really not bad though, only two spots, each the size of a quarter. I'll live.
#585
Speaking of wounds, people weren't kidding about face wounds healing fast. Mine are almost completely healed a week later except for a flap of skin I accidentally ripped open again.
#586
Thanks. I was ready to scroll fast but didn't need to.
Wife got a TDI - 40-odd mpg, accelerates surprisingly fast (230-something lbs-ft torque), carries lotsa stuff. Nice growl to it too, at least from the inside of the car. I want to mod it, but I have to wait to have one of my own. Tax credit two ways until July of this year. I wish I'd gotten a TDI a few years ago when I was contemplating that or buying the 246k mile Honda from a friend. I decided to help the friend out and I'm happy I did it but still.
Wen - a few more ideas:
1. When bike is stationary, put bike in some big gear and push down on the cranks slowly, steadily, with increasing amounts of force until you're red in the face. Big gear helps keep the bike from actually moving. If you feel a click or something then try again. This may help isolate the cause. Try with each arm pointing forward
1A. Grab each crank arm and slowly, steadily, with immense amounts of force, push and pull the arm side to side. Check at different clock face locations (12, 2, 4, 6, 8, 10 o'clock. Check for click etc.
2. You mention standing. Does it happen when you're sitting? How about one- or no-hands? If it's just when you're standing, it may be a bar/stem/fork thing.
3. Hate to say this but check for cracks. A couple of my creaking frames (not a CAAD9, but a couple different brands) had cracks in them. One was a super-overbuilt frame, chainstay cracked. Another was a super-light frame, chainstay cracked. I've seen top of seatstays, downtubes, top tubes, everything. Look for cracks which are invisible except when frame is flexed. Chainstay ones are usually dirty enough to see, but other locations can stay clean/pristine and very hard to spot.
4. If creaks when seated, take out saddle/post and try. Sometimes post moves in frame. Don't forget to put saddle/post back
5. Try with/without cycling shoes. Different wheels.
6. Spray the living daylight out of different areas with a thin lube (wd-40 etc), one at a time. Rear der. Dropout. Chain. Cassette. Chainring bolt area. Bar/stem junction. Maybe even stem/steerer junction (okay if no carbon). Process of elimination. Keep braking surface and tires free of lube. Clean off after.
I forget what else you've tried and pages are loading slowly so I'll leave it at that.
cdr
cdr
#587
Mr. Dopolina
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times
I was tempted to create a thread in the 41 but the chance of getting a good answer here seems more probable. Today I noticed that when I engage the rear brake I hear a thumping sound, so I checked the brake pads (which need replacing soon), and made sure the wheel was on correctly. There's no thumping sound while I'm riding, only when braking. Any ideas?
The thump is caused by a variation in the width of the rim at the braking surface. Usually it is a result of an impact. If the rims are new I'd go with what was suggested and say it is the seam.
Since most rims have their braking surfaces machines after they are pinned you may have a real problem here.
Check truing and hop first and, if they are in order, take off the tire and run some calipers across the braking surface and find the variation. If it is at the seam you are hooped.
If it is not at the seam lay a 1x2 across the braking surface and wack it with a hammer. Flip the rim over and repeat (seriously). Look and see if any lines develop (cracks) in the braking surface. Wack it until it seems flat. You can run a steel ruler across the rim to look for gaps. The gaps will be where the light spills through.
Or you could just try for a warranty...
#590
Mr. Dopolina
Quoted: 149 Post(s)
Liked 117 Times
Sorry if I missed it but have you actually pulled and lubed the threads on you BB cups yet? Creaking and popping under load are pretty classic tells. I'd actually start there and not waste my time piddling around looking for the "less usual suspects".
#592
cdr
cdr
1A: Clicks/creaks when I do this, seems like all the way around but loudest at 9 and 3
2: happens when I'm standing, also happened when I rode no hands, so I think it's the pedals/bottom bracket, and I've tried everything I can think of on the pedals.
3: I didn't look too hard because of 1A making noise, but I didn't see any cracks
4: Didn't do yet
5: tried without shoes, still makes noise. I don't have other wheels, so trying other wheels will have to wait until I can borrow a set for a few minutes.
6: Haven't done this yet, hoping that 1A making noise means that the problem is there, which brings us to.
No. The bolt holding the crank on like it requires a tool that's bicycle specific that I don't own. Given the price of anything bike specific, I was hoping to avoid this, but it looks like I might as well stop wasting people's time and suck it up.
#593
Bikes: '03 Klein Q Carbon Race, 105/ultegra, reynolds wheels, toupe saddle
I'm jealous of the zero % financing though Gl with yours.
#594
Where's the best site to find out if there are any crits in my area? I've tried a few searches without much luck. I'm in the ft myers/Naples area.
#595
coffee-stained punk
#596
Mitcholo
I started doing some group rides about a month ago (I've been riding for about three months so far) with the estero trek store group on Sundays, and sometimes their weds night ride too.
The bartow race isn't too far away distance wise, but I don't think I'm ready for crits quite this soon. I don't see anything after October on that calendar, is that it for the year? Any idea if there is ever anything close to here?
#598
coffee-stained punk
South ft myers, near Daniels and 75. My wife actually teaches at Ida baker in the cape, though.
And theres a handful of races left on the calendar, crits and rr's...but its winding down for the year.
#600
meow
Bikes: 2016 Parlee Altum, 2013 Cannondale Super Six Evo Hi Mod Di2 only, 2011 Cannondale Super Six, Dura Ace 7800, 2007 Cannondale System Six Dura Ace 7800, 1992 Bridgestone RB-1, MB-2, MB-3, MB-5
It can be a little bit like golf: you know, when you're thinking "don't hit into the water, or, just hit it anywhere but into the woods."
