#4426
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
#4427
Quoted: 1609 Post(s)
Liked 2,216 Times
I try not to duplicate info but since I am not getting much response or comment, here it is:
Pinarello Montello component morphing - Bike Forums
In the process of converting from 2x8 to 3x8 on the Montello.
#4428
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
Likes For JaccoW:
#4429
señor miembro
Liked 6,491 Times
For the first 5 or 10 minutes after I hopped on the Miyata, it felt like the bars were more narrow than I'm used to. They were 38cm, and I've 38s on other bikes, so I can't explain that weird feeling for the first few minutes. I finally bit the bullet and changed out the original 3ttt bars for some Cinelli 64-40s after I decided to also replace the cotton with Fizik tape.
That's sort of difficult work. It's not so straightforward like rebuilding a bb, overhauling a pedal or truing a wheel. It takes me quite a while to get the brake levers just right and even longer to tape the bars perfectly and add finishing tape. I've always found these "small" jobs can be frustrating.
Fizik now has their white colored logo on one side of this tape, which I can hide pretty easily with the wrap until I do a figure-8 around the lever. So there was one little emblem showing on the outside of each lever. I wasn't too worried about it. A little acetone took care of that, although it left behind a little smudge.
But the first ride today told me it was all worth it. My hands thank me. The cushy 2mm microtex tape feels almost like the tires got a little fatter without losing that precise road feeling I'm used to. But at the same time, I do think I've lost that more vintage look and feel of the cotton. It's definitely a trade-off.
The new Cinelli stem's clamp bolt was also a little long, like three threads were showing, which bugged me. I tried a pipe cutter first, and that clearly wasn't going to work with the threads on there. So I used a hand clamp and took a hacksaw to it. I was a little worried I didn't have anything to clean up the threads, without a nut in my bin of the same size. Afterwards, I used an iron file on the end, and maybe I took a bit too much off. But now I can sleep.
Likes For SurferRosa:
#4431
señor miembro
Liked 6,491 Times
You get Fizik! And you get Fizik! And you ...
#4432
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I just finished a 1980s Cannondale rigid fork, hardtail MTB 3.0 series for a client. They had been "gifted" this one from a neighbor in FL, and brought it back to VA for me to fix up. It had serious corrosion within the BB shell, a rusted/frozen chain, and cable housings that had collapsed under the UV and humidity of FL. The BB spindle was pitted in the bearing tracks and had to be tossed. I was able to get this back up and running for the wife, with a shorter reach stem and chopped bars. I buffed up the paint, trued the rims and did a general cleaning. The wheels have sealed bearing hubs that remained smooth, so I didn't touch them.
It rides surprisingly well on 2.25" tires at lower pressure. Terrific bike, it'll be perfect for her to ride the C&O canal tow path or other local cinder/dirt multi-use trails.
Equipped with 3x6 SIS thumbies!
#4433
Liked 2,216 Times
Completed the morph on the Pinarello to 3x8 and took it out for a test ride in the neighborhood. It works. I am happy and am looking forward to trying it out on some hills.
@Roger M - Interesting project for the tandem mount. How much of what you are using is from Yakima?
#4434
Liked 6 Times
I saw a lot of great steel MTB's of this era on my ride of the full length of the GAP to C&O two weeks ago, very cool! Lot's of these kicking around Philly as well, such great city bikes!
#4435
Quoted: 469 Post(s)
Liked 2,443 Times
Just for reference and for those questioning the width, here's some pictures of it mounted.
Likes For Roger M:
#4436
Quoted: 823 Post(s)
Liked 1,395 Times
I pulled my ‘82 Mercian Colorado off the pegs it has called home for several years. A recent interest in 80s Shimano indexing developed from the last two Clunker Challenge bikes led me to reading, which led me to realize the shifting issue on this bike was the Dura-Ace rear derailleur, which won’t play nice with less expensive Shimano parts. I wound up taking the Sachs New Success off the ‘71 Mercian KOM I am building for my son. Sure enough, a little fiddling with the barrel adjuster and it works beautifully with the indexing 600 dot shifters.
Before I fitted the Sachs mech I dug put a 300EX Exage and tried it. It worked nicely, but I think it’s a better match for the MicroNew brifters on Eli’s green machine. All that’s left to do for now is to polish up the Sugino 165 cranks and wait for the new BB to arrive.
#4437
GDFTR
Bikes: '74 Falcon San Remo, '80 SR Semi Pro, '88 Trek 360, '18 Fairdale Goodship
Quoted: 51 Post(s)
Liked 82 Times
I have never been particularly fond of the Universal Super 68 brakes my ‘73 Falcon came with so I “upgraded” to some Modolo brakes since I know I like how they feel and work. Got a pair of NOS Corsa levers and very clean Flash calipers. I know it’s not the best but I wanted to keep them silver and if they’re a bit heavier or not as beautifully polished as the more high end models it’s Ok, I know they will work about the same.
Now just waiting on Amazon to deliver the gel pads for the bars so I can wrap the new cork tape and take it out!
*I know it’s time for new pads, these have about 700 miles on them with the Universals, but I wasn’t about to use the rock hard Modolo pads. A set of Kool Stop Modolo inserts are on the way.
The old Universal Super 68 which look good but aren’t great imo.
New Modolo Flash calipers
NOS Modolo Corsa levers
Likes For RustyJames:
#4439
Quoted: 472 Post(s)
Liked 1,039 Times
Last winter when I rehabilitated my Fuji TS III wanted to try just a front rack but they are quite rare and expensive (and I did not know if I really wanted one). so I fabricated a front rack for it out of a rear rack. Worked just fine but I've thought it was not quite right. One thing was that I made the mistake of fitting it so the rear rack stay was vertical which meant the top of the rack was not quite parallel to the top tube. And one of the mounting eyes was damaged so it's integrity was questionable. So I'm making another one and have been "wrenching" on that. Actually cutting, bending, measuring, fabricating.
The one I made last winter is shown on the Fuji now. The black one on the box is much like what the new one started as. The gray primer'd one is the new one, cut down to size and bent. I started by cutting off the very end then straightening out the two rods and the center tray. Turns out I did not need to as they were eventually cut off but my method helped me sneak up on a solution. I then held the fresh cut rack beside the silver one and moved it back and forth to confirm level and where I wanted the new bends to be. Then I bent the side rods and the tray. How nice to have a good vice and a few other things to bend with. I could not make a production run the way it did it but it worked. No cracked aluminum. I then cut the rods and tray to their current length and filed everytihing smooth. Then sanded the whole shebang and prep'd for paint. The Ace "Chrome Aluminum" enamel is what worked just fine for the first rack and what I'll use this time. As its summer and the loft gets nice and warm/hot, I'll get this painted then leave it hanging in the loft for a month or so. I'm in no hurry. When it is installed it will get a wood rod mounted across the cut ends, like the black one on the Fuji now but gloss varnished cedar.
Oh, that steel thing in front is a spindle from a scrap pedal. The steel is very hard and these make good nail sets/drive punches for things. Tough. I wire brushed it clean and one thin coat of boiled linseed oil. Another useful tool.
Likes For Prowler:
#4440
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
Likes For 3alarmer:
#4441
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
Current project is the rebuild of a 2001 Colnago frame that has just returned to me after many years of it being in the hands of others (more about it here... https://www.bikeforums.net/classic-v...lnago-vip.html )
This thing is constantly getting tweaks. Latest was a new bar and stem. Next is probably new cranks and a narrow-wide chainring.
On the back burner is a Bianchi Eros that is getting a flat-bar 1x8 conversion. There's a good chance this could end up as my daughter's college campus commuter in about 12 months.
#4442
WV is not flat..
Just finished up this 1985 Ross Signature 294S full Campy. Restored, but all original parts except the ones that did not age well.
Likes For brandenjs:
#4443
señor miembro
Liked 6,491 Times
^ Sweet pedals!
#4444
WV is not flat..
#4445
I've been working on this Rossi since the spring. Still a ways to go, but some new paint and cleaning up the parts have made a big difference already.
Likes For Reid_Fleming:
#4446
Zip tie Karen
Liked 1,542 Times
There's a tiny cable guide beneath the BB shell, but it's really small.
#4447
Re-attached saddle top layer
This Cool Gear ‘The Seat’ I have owned since it was new - mid-to-late 70’s. And it’s the second time it has needed the top layer re-attached. Years ago I used contact cement and over time the edges peeled up again. When it happened then, I replaced it and just set it aside.
The hardened adhesive took a lot of scraping to remove.
Cool Gear saddle’s top layer under side with dried up contact cement.
This time I used a material meant for shoe repair. Below it’s taped for the overnight curing time.
If something doesn't ache, I could be trying harder.
#4448
Quoted: 823 Post(s)
Liked 1,395 Times
finished one!
When I came home from work last evening the bottom bracket was waiting for me in the mailbox. I installed it this morning and gave the Sugino VP cranks a quick polish and mounted those, fitted the cleaned and lubed chain and dialed in the shifting. It’s PERFECT. Of course for my son it’s best feature is that it’s GREEN.
#4449
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Just the Sidewinder tandem mount is from Yakima. I used to have one of their old tandem mounts, without the swing out feature. It would be better for this application, cutting a few more inches off the length. Unfortunately I sold it years ago.
Voltaire
Voltaire
#4450
Quoted: 835 Post(s)
Liked 2,144 Times
Just a thought: If you are willing to loosen and re-adjust upon arrival, you could loosen the stem, then turn the bars and fork 180 degrees during transport. That way the rear triangle and bars wouldn't be quite as exposed. I could understand not wanting to do that too often, but might be worth the trouble for a long trip.
Likes For gaucho777:
