ISO and for trade thread part 5
#5351
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
The axle locknut thread is a somewhat unusual 7mm x 0.75mm thread; maybe source from a place like McMaster-Carr? Otherwise, other pedal hardware e.g. Campagnolo Gran Sport, Gipiemme Dual-Sprint, Ofmega, etc. pedals axles, cones and hardware are interchangeable with Record and Superleggero pedals. You might be able to find a beat-up set of one of those, from which a locknut can be scavenged.
The dustcap thread is pretty common. MKS Sylvan dustcaps will fit, are widely available and affordable. If the MKS logo offends you, you can file it off and make the cap anonymous. It won't look like the Campagnolo cap, but if you use it on the non-drive side pedal and nobody will notice.
Before and after "anonymizing:"
Likes For JohnDThompson:
#5352
Quoted: 1324 Post(s)
Liked 927 Times
I think I covered all of the varied names for that size!
I'm hoping to put some alloy rims on my Superbe that I actually use as a rainy-day commuter and guest bike (both scenarios where braking performance is worth having), but also want to maintain the look as best I can. I know CR18s used to come in a polished finish in this size, but it would seem that is no longer the case.
If anyone has any 36h polished CR18s (or similar) in ISO 590 kicking around that they'd like to make a buck off of, let me know!
(I am in Canada, but could probably bug a friend in Rochester to ferry these for me if needed)
Cheers
#5354
Quoted: 1609 Post(s)
Liked 2,216 Times
I was wondering what other pedals might supply the parts.
#5355
Industry guy
Likes For 100bikes:
#5356
Bikes: Rivendell Sam Hillborne, '70 Raleigh Superbe, No-serial Mandaric 80s MTB turned klunker, '96 Rocky Mountain Hammer, '75 Sekine fixed conversion, Bertus Bakfiets
Quoted: 11 Post(s)
#5357
Quoted: 2364 Post(s)
Liked 1,751 Times
^^^^ First "vacation" with the girl I married was in Elora; we X-C skied the gorge trails, going on 40 years ago now.
#5358
Quoted: 288 Post(s)
Liked 330 Times
I need the washer and lock nut and of course the cap for only one of the pair.
68FrejusSRPedals on Flickr
@ me or PM.
Thanks.
@ me or PM.
Thanks.
#5359
I have multiple sets of the beartrap style pedals and would gladly trade for a set of 730's. Or I _might_ have a set of rectangular shaped ones of some sort but my junk is in storage at the moment so it would take me a week or so to find out.
#5360
In the meantime, here's a peek at the 730's.
#5361
Liked 2,216 Times
#5363
Old fart
Liked 3,401 Times
#5364
Bikes: Condor, Cinelli SC, MKM Metcalfe, Peugeot AE08, Bianchi, Cougar, Miyata, Harry Hall, Holdsworth Special, Raleigh Int'l, Le Croco, Bob Jackson, Zeus
Quoted: 114 Post(s)
Liked 102 Times
Campy NR Globe gum brake lever hoods
Does anyone have a good, recent source of these hoods. So many of them online look like they're made of the wrong rubber.
thanks.
Brad
thanks.
Brad
Better bike .. Better life!
#5366
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
It's messy (wear gloves and use a bunch of cloth rags) and takes time but nearly always does the job.
After air-drying the works, spray in a light weight lube of your choice, it won't be as durable as the OEM grease so you'll need to repeat lubrication periodically, but DON'T rely on the flush-out fluid to be your lube.
#5367
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
have you confirmed there are parts actually broken inside the unit? Cause if it's merely stopped shifting (as often occurs with age) the easy cure is to flush out the old dried up grease with a big long bath of WD-40 or PB Blaster and working the mech until all grease has softened up and moved along.
#5368
Quoted: 1952 Post(s)
Liked 2,013 Times
Campy TT cable guide screw?
I lost one last night when the spring clip launched it over my shoulder. I think it landed on the work bench but…
I think it is a 1/2 size that my Ace doesn’t have. What size are they?
Jeff
Edit: it is a 5-40 machine screw.
Jeff
#5369
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
#5370
Edumacator
Quoted: 2440 Post(s)
Liked 3,133 Times
MTB? Or standard touring? I am pretty sure I have some. Let me check.
#5371
Liked 4,396 Times
Have thrown too much effort and money at the thing already - the goal is simply to get rid of it with the least additional expense.
-Kurt
#5372
Edumacator
Liked 3,133 Times
It's for that '88 Schwinn Voyageur I've had kicking around, so technically touring, but I'll take MTB too. Not picky, just want something that works that's compatible with the Shimano 6-speed shifter.
-Kurt
-Kurt
#5373
Liked 4,396 Times
#5374
Edumacator
Liked 3,133 Times
#5375
Quoted: 1611 Post(s)
Liked 2,594 Times
That Deore is the ticket.
