New Tiagra 4700 compatibility with 11s Shimano parts
#51
Bikes: Stevens Super Prestige CX, 2005 Bianchi Cross Concept, 2000 Breezer Venturi, Bianchi's: Project 7 (&5 &3), 2005 & 2002 Volpe, 2007 San Jose, 1990 Boardwalk semi-mixte, 2005 Eros; 1996 Cannondale M300 A-frame, Schwinn 2010 Tourist
Quoted: 7 Post(s)
Liked 5 Times
My bike has a full 4700 tiagra groupset, ...
1. Will the R7000 or R8000 shifters work with 4700 FD and RD, along with the current 10sp 11-32 CS-HG500 cassette?
If I don't upgrade the shifters now:
2. Will the Tiagra 4700 shifters handle an 105 (R7000) RD (or Ultegra R8000 RD) with an 11sp 11-34 CS-HG700-11 cassette. If not, that means that the 4700 shifters are locked to 10sp changes and not 11sp, since the cable pull ratio is the same on 4700, R7000, R8000 shifters when used with 4700, R7000, R8000 RDs.
A2a. YES. The Tiagra 4700 shifters work very well with the "11-speed" R8000, 6800, R7000, 5800 rear derailleurs and *10 speed* cassettes.
I have been using this setup for years on my Cyclocross bikes. I don't need a 11T cog in CX races and so 11-speed gives me no advantage, while using more expensiveness chains and less mud clearance. The more cable pull of Tiagra 4700 over Ultegra 6700/6600 means shifting is better in thick mud and in the later season.
A2b. NO. The Tiagra 4700 shifters + "11-speed" rear derailleurs will NOT work with an 11-speed cassette.
If you use Tiagra 4700 shifters you MUST use a 10-speed cassette. If you use R7000 or R8000 shifters you MUST use an 11-speed cassette.
(you referred to this as "being locked" to a certain speed)
Likes For Dr_UNIX:
#52
So, one more complex matching components question related to the A1 answer for a step-up "easy" upgrade:
1. GRX 600 shifters (2-11sp) - which are fully compatible and interchangeable with 105-r7000 shifters (to buy)
2. GRX 400 disc brake calipers - which are fully compatible and interchangeable with tiagra 4700 or 105-r7000 dics brake calipers (already bought)
3. Tiagra 4700 FD with Tiagra 4700 crankset (that I'm now using)
4. Tiagra 4700 RD (that I'm now using)
5. 105 r7000 (CS-HG700) 11sp cassette (to buy)
6. 105 r7000 (CN-HG601) 11sp chain (to buy)
I know these groupset is a lot of mixed, but as I have all the Tiagra parts and planning to buy the GRX 600 hydraulic shifters or 105-r7000 hydraulic shifters, it leads me to at least change of cassette and chain.
In the future I might upgrade more parts but do I also need to change the 4700 RD for an 105-r7000 RD at once?
Thank you!
#53
Quoted: 7 Post(s)
Liked 5 Times
The FD-4700 double has the same new cable pull as the FD-6800/5700/R8000/R7000. The triple has the older (lesser) cable pull.
The rear RD-4700 will work fine with the GRX 600 2x11 shifters to operate as an "11-speed" RD with your new 11sp chain and 11sp cassette.
Compared to the RD-6800, the RD-4700 officially works with a slightly bigger cassette (34T vs 32T).
Likes For Dr_UNIX:
#54
This DEFINITELY works. I have a rear ST-4700 10-speed shifter with a RD-6800 ("11sp") rear Ultegra dérailleur on my cyclocross bike, with CS-6600 and CS-4600 cassettes.
It is the best 10-speed shifting I've experienced.
As has been said, the rear cable pull ratio of the ST-4700 and RD-4700 now match that of the Dura-Ace/Ultegra/105 11-speed mechanical groupos. Thus you can mix and match them. You could also use a ST-6800 and RD-4700 long cage.
Currently, I have a Tiagra 4700 (10 speed) with all of the 4700 components. (50/34 + 11-34), medium cage.
(I also have a 105 11-30T cassette and an 11-speed compatible wheel)
My questions are.... if I want to do an upgrade to the 11 speed...keeping my 4700 50/34T crank (to be used with the 105's 11-30T cassette)
1. Will my 4700 crank work well with the 105 11-speed components (ie 11 speed cassette and the 11 speed chain?
2. According to the OP, my 4700 shift levers and the cables should be fine to work with the 105 derailleurs?
3. So basically, all I need to complete the transition is: 105 front/rear derailleurs, medium cage and the chain? (or can any of the still be compatible?)
Is there anything else that I'm missing?
Thank you!
#55
Thought I'd dig up an old dog as opposed to starting a new thread.
My questions are.... if I want to do an upgrade to the 11 speed...keeping my 4700 50/34 (to be used with the 105's 11-30T cassette)
1. Will my 4700 crank work well with the 105 11-speed components?
4... or could I still use the 4700 medium cage and the chain (which might need to be shorterned, I imagine...
Thank you!
Thank you!
Hello,
First, for 11-gear cassette, you definitely need 11sp shifters, so the right one shifter(the one for the read derailleur) must be changed to 11speed. 4700 shifters have only 10 shifts available! Think of like the shifts are controlled by the shifters (amount of shifts and pull ratio), the derailleur is like a "dummy" mover, since in your case 4700 and 105 derailleurs have the same move per pull ratio.
You also need a new 11sp chain, because I think the chain is narrower than the 10sp.
Then, you cound probably keep all other components unchanged, which means, front derailleur, crankset and rear derailleur.
I'm not 100% sure, I mean that I did not test this in real situation or any friend of mine actually did, but all site info/forums and engineers I know will tell you it's possible.
In conclusion:
1. crank probably ok.
2. 4700 shifter must match the number of gears in the cassette. So, 4700 shifters with 10sp cassette (and 4700 or 105 rear derailleur) or 11sp (105) shifters with 11sp cassette (and 4700 or 105 rear derailleur). No 4700 shifters with 11sp cassette!!!!!
3. shifters (right one at least) and the chain.
4. 4700 rear derailleur with 11sp casette ok, but only with 11sp shifters. Chain must be changed.
Christos
#56
Thanks a tons, Christos...
So, so far... All I need is a:
105 (right shifter)
11 speed chain
(already have the 105 11 sp cassette)
My 4700 GS (med) rear derailleur, 4700 crank + front derailleur should all work fine.
If anyone has any other last thoughts before i make the purchase, feel free the chime in
105 (right shifter)
11 speed chain
#57
I keep hearing from multiple sources that:
Tiagra 4700 10 speed shifters use the same pull ratio as the newer 11 speed Shimano stuff.
You can't use 4700 shifters with 10 speed 105 / Ultegra mechs.
You can use them with 11 speed 105 / Ultegra mechs, but you'll obviously only have 10 speeds.
If I were to use an 11-30T 11-speed (105) cassette... would I just need to replace the chain only - no problem with the rear derailleur?
Also, since I can only use 10 gears, I'm guessing it's the 30 that I wouldn't be able to use... which would be fine.
Thanks again
Thanks again
#58
Quoted: 714 Post(s)
Liked 800 Times
Thanks again
Thanks again
You can't use the 11 speed cassette with the 4700 shifter. The cogs in the 11 speed cassette are closer together than the 10 speed cassette, so it will never shift correctly for more than 2 or 3 cogs.
You need to either, buy a 10 speed cassette and use that with the 4700 shifter or buy an 11 speed right shifter and use that with the 11 speed cassette.
Likes For dsaul:
#59
Quoted: 7 Post(s)
Liked 5 Times
You can use the 4700 shifters perfectly with both front and rear 105 11-speed derailleurs. BUT you will still have a 10-speed setup.
To go to 11-speed, you do not need to replace your 4700 derailleurs. You need to replace your 4700 rear shifter + 11sp chain + 11sp cassette. The 11sp 11-30T will work fine with your existing 4700 rear derailleur. The 4700 front shifter will have the same shape and feel as an 11speed rear shifter, delta the difference in materials (metal vs. carbon) and finish. Thus if it doesn't bother you to have have one shifter labeled "Tiagra" and one labeled "105" you can save money by just buying one shifter.
You should have no problem using your existing 4700 crankset. It might not shift quite as well as an "11 speed" crankset, but I think you'd be hard pressed to tell the difference just due to the chainring spacings. I'd expect an Ultegra set of chain rings to shift better than Tiagra ones - but that's just due to the level of the group sets involved.
Likes For Dr_UNIX:
#60
Quoted: 7 Post(s)
Liked 5 Times
The ratio is a ratio of X amount of cable pull at the shifter effects Y amount of derailleur movement.
Each click of a 4700 shifter moves more cable at the shifter than the 11-speed shifters as the distance between two 10-speed cogs is greater than the distance between two 11-speed cogs.
Likes For Dr_UNIX:
#61
Quoted: 7 Post(s)
Liked 5 Times
2nd, you MUST MATCH the # of speeds of the rear shifter with the same # of speeds of the cassette. NO you cannot simply use an 11sp cassette and just not get to one of the cogs. The distance between two adjacent 11sp cogs is less than the distance between two adjacent 10sp cogs -- it is that 10sp cog distance that your 10sp shifters are wanting to move your rear derailleur laterally by (depending on knowing the cable pull ratio of the rear derailleur).
You might be confusing "10 of 11" where you install only 10 of the 11sp cassette's cogs into an 8/9/10-speed hub (i.e., the freehub body isn't wide enough to accept all 11 cogs). But the spacing between two adjacent cogs is still the 11sp intercog spacing and requires an 11-speed shifter.
Likes For Dr_UNIX:
#62
Havent managed to read it all, but lots of wrong answers.
You CAN mix 5800 and 4700, but NOT 5800 and 4600. You CANT use a 5800 STI for a 10S cassette tho, because the # of gear doesnt match, -11S STI vs 10S cassette.
You need a 10S 4700 STI for the 10S cassette and a 5800 Rear DR or a 4700 rear DR for at 10S setup.
Likes For Racing Dan:
#64
Quoted: 714 Post(s)
Liked 800 Times
Wrong. The 4700 has the same PULL RATIO as Shimano 11-speed shifters.
#65
Thanks again
Thanks again
#66
Quoted: 11 Post(s)
I'm also a user of 4700 10 speed shifters with a Ultegra 6800 RD on a 10 speed cassette. Has worked flawlessly for years.
#67
Quoted: 7 Post(s)
Liked 5 Times
Just to be clear for others. An R7000 105 RD would work too. Or any Shimano 11-speed RD that's been released to date. That includes Ultegra, Dura-Ace, and GXP above the 105.
#68
The number of clicks is in the shifter, not the RD. You get your 10 speeds worth of clicks, and the 11 speed RD moves the correct amount per click.
#69
Quoted: 11 Post(s)
Are you using the older 10 speed cassette? Have a question. I'm currently using a 10 speed 105 RD and shifter and Ultra 6700 cassette. Let's say I decide to change to the Tiagra setup and 11 speed RD, will the RD and Tiagra 4700 shifter work with the older 10 speed cassette flawlessly? Cassette spacing wise no issues even though the pull ratios are different?
#70
Monstercross
New tiagra 4700
I converted my mtb 9speed to drops, i used full 4700 set derailleur, sti's,chain and cassette,not to expensive, smooth shifting and look's cool.1x setup
#72
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times
Feel...
I much prefer the hood size/ shape and shifting of my 2007 Tiagra 9-speed with newer Sora derailleur to my 2020 Tiagra 4700 10 speed. 4700 is hydraulic disc brake, so apples and oranges, but 4700 is a bit clunky. Hard to say if it's shifters or derailleur.
#73
Quoted: 7 Post(s)
Liked 5 Times
All Shimano/SRAM 10-speed cassettes have identical inter-cog spacing. You can use *any* Shimano/SRAM 10-speed cassette that has ever been made.
#75
Regarding 4700 compatibility i am using on an old bike the following setup: Tiagra SL4700 flatbar shifters , shimano 9sp chain+casette , shimano RD 5600 10sp , FD+FC 1055. . Working great !
For my new bike: I want to ask (again maybe) if i can keep using my FC 4700 double crankset with shimano 11 speed shimanoa 105 R7000 groupset (shifters,RD,FD,casette,chain)
Thanks
Thanks
