What makes a bike a "climbing" bike?
Old 07-17-20, 10:52 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
Years ago it had to do with the stiffness of the frame. If the bottom bracket shell is flexing some of the power is being lost. At least that is what was hyped.
That may not apply to modern carbon frames. All things being equal of a rider’s ability to climb, a lighter shorter wheelbase bike would probably outperform a heavier bike with the same rider.
John
70sSanO is offline
Likes For 70sSanO:
Old 07-20-20, 01:26 PM
rbrides
Curmudgeon
rbrides's Avatar
Bikes: Specialized Diverge Comp
Quoted: 157 Post(s)
Liked 32 Times in 28 Posts
John
Hey, John, you are the first to mention wheelbase as a factor. Could you elaborate on the effect wheelbase has on climbing?
rbrides is offline
Old 07-20-20, 02:52 PM
70sSanO
70sSanO's Avatar
This is really my personal preference, and I imagine a lot of tourers will disagree, but I like having a nimble compact bike especially out of the saddle.
Admittedly I'm biased having ridden an '88 Cannondale Criterium for years that is super stiff and I can't fit my index finger between the tire and the downtube.
John
70sSanO is offline
Likes For 70sSanO:
Old 07-20-20, 04:06 PM
Leinster
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times in 207 Posts
John
A short wheelbase might also be easier to whip around high-speed tight corners on steep winding descents, much like riding a Crit. I love climbing on my Criterium, and on my CAAD10, with their aggressive geometry. Descending on them is a blast.
When people talk about a "climbing bike," they're usually talking about a bike that is designed to get rider and machine uphill quickly, with no other ballast. Tourers may well prefer long wheelbases to keep their ride steady under load up and over long passes, but their primary concern is to get over the mountain in comfort, and speed is a secondary consideration.
Leinster is offline
Likes For Leinster:
Old 07-20-20, 08:19 PM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
The new TREK SL6 PRO has a drive train of 52/36 chain rings and rear cassette with max 30T gear. That is a 1.2 ratio. They market it as "This upgrade makes it a worthy choice for any ride, from sprints on your local roads to pro stage races to hill climbing competitions." That just seems like not as low a ratio by today's standards for climbing. Maybe 1.2 is well suited for younger, lighter weight riders but is seems underwhelming to me. I'm currently on a bike with a 48/32 chain rings and cassette with 34T for a .94 ratio.
What are typical gear ratios for climbing these days?
I like 50-39-30 x 13-14-15-16-17-18-19-21-23-26 which is 1.15 for the Santa Cruz and Diablo mountains, but in peak form am the same size as Alberto Contador - 5'9.5", 135-137 pounds.
Twenty years ago I liked 50-40-30.x 13-14-15-16-17-18-19-21 which is 1.4 for the Rocky Mountains. Same low as 42x28 for the mountains west of Boulder, CO plus a 13-19 straight block for plains east.
It's about grade, length, power to weight ratio for the resulting duration plus how many hours you want to be fresh afterwards.
That varies enormously. Most people just use whatever the bike company will sell them.
Drew Eckhardt is offline
Likes For Drew Eckhardt:
Old 07-20-20, 08:24 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Liked 1,044 Times in 667 Posts
Originally Posted by cubewheels
Don't forget the nasty headwinds! I go to some hills in the city at roughly the same time everyday and everytime, I always get headwinds. I'm training to increase my power-to-weight ratio but since I ride in a densely populated city, it can be dangerous to ride fast so I deliberately wear loose, flappy clothing. They can "balloon" in strong winds/high speed, working like a mini parachute lol!
It makes riding uphills in strong headwind, double the effort! So I'd say, aerodynamics still matters!
I never ridden outside the city anyway so I have no idea how winds are in the mountains. But in the city, the tall buildings can catch the wind and channel and focus them at the ground level.....Annoying! But makes for a great workout without going dangerously fast (in a crowded city where going fast can be dangerous)
Good point! The wind resistance force will be approximately kAsv**2, where k is the coefficient of air resistance, A is the combined frontal surface area, s is the speed on the road and v is the speed in the air (road speed plus headwind).
So absolutely, a headwind can suddenly put the wind resistance term into a high speed value (without the reward of actually moving at high speed). Climbing uphill into a headwind will be made significantly harder by both the work against gravity and the work against wind. For any given hill and rate of climb, there will be a wind speed at which the air drag exceeds the gravitational term. Additionally, as head wind increases, the importance of aerodynamic efficiency of rider and bike (or purposeful inefficiency in your case) will increase and at an increasing rate.
Otto
ofajen is offline
Likes For ofajen:
Old 07-21-20, 09:23 AM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Yep, and the unpredictable nature of winds in some cases means you cannot reliablely take advantage of them via tailwind to build momentum as downhill sections can. If speed matters, then aerodynamics is still worth looking even in hills.
There's one case, the headwind is so strong and I'm uphill with my baggy clothes, I nearly dismounted the bike to just walk the way up! An extreme case of poor aerodynamics.
I never had a ride in mountain roads before so I have no idea how bad it is out there but I reckon if the road goes through a significant tree canopy, the trees can dramatically attenuate the winds so there'll be no wind at the road.
Foliage will have an effect on the wind. A lot of my riding is in hilly neighborhoods or roads lined with trees or on various trails that are also mostly tree-lined and many of my climbs are either coming out of sheltered valleys or up tree-lined hill sides. At this time of year, the foliage often knocks down the wind. In the winter... not so much! Of course, with the leaves down, the headwinds always seem strong on the flats all winter long.
Otto
ofajen is offline
Likes For ofajen:
Old 07-22-20, 12:26 AM
ZHVelo
Quoted: 528 Post(s)
Liked 230 Times in 161 Posts
In no realistic world is this a climbing bike for the average person. 36-30 is a joke on long, steep climbs. The amount of watts you would have to churn out just to do say 60 RPM.
ZHVelo is offline
Likes For ZHVelo:
Old 07-22-20, 01:34 AM
Toespeas
Quoted: 164 Post(s)
Liked 44 Times in 41 Posts
id say a climbing bike is a bike that focuses on hills , its built to be in a climbing position , its less aero focused and more focuses on light weight stiffness , and an 11/30 is great climbing gear set , like you said the double rings allow you to take on all terrain , but its mostly for hills and not for flats
Toespeas is offline
Likes For Toespeas:
Old 07-22-20, 09:29 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
ZHVelo, Thanks for being focused on the correct context of my question. Is the bike aero enough and light weight enough for the 1.2 final gear to effective on long stead climbs? I don't know. As I mentioned in my OP, that does not seem to be a particularly low gear by today's standards.
rbrides is offline
Old 07-22-20, 10:38 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
For what its worth. An article from bike radar on "best" climbing bikes.
https://www.bikeradar.com/advice/buy...limbing-bikes/
rbrides is offline
Old 07-22-20, 12:01 PM
Leinster
Quoted: 344 Post(s)
Most of them with an 11-30 as stock, some even with 11-28.
Thing is, with most of these bikes, they're trying to build something that will sell in multiple regions. Yes, if you're biking in the Swiss Alps, you will more than likely need a lower gear than 1.2. But you're unlikely to need anything that low on the roads of northern Europe, large swaths of the US, anywhere in Australia, etc. And if you're buying a System 6 with Di2 Dura Ace, you should be able to climb the Matterhorn in 36-30 (and if you aren't strong enough to do that, then at $9,000 for a bike, you're rich enough to swap your cassette, derailleur, chainrings out). If I still lived in Ireland, a 34-34 gear would go unused on anything with slick tires.
Leinster is offline
Likes For Leinster:
Old 07-22-20, 12:46 PM
ZHVelo
Quoted: 528 Post(s)
I agree, but if you call it a 'climbing' bike you can expect that it should be for climbs. Be that longer steepish ones that will tire you out and you can't grind on 36-30 forever unless you are very strong, or short but very steep ones where again a 36-30 would be hell (I would not want to do 20% or more on 1.2).
I guess that is why mostly they don't call it climbing bikes, bike brands themselves usually use race, endurance, and aero. Which is why that article on 'climbing' bikes is silly imo.
ZHVelo is offline
Likes For ZHVelo:
Old 07-22-20, 12:48 PM
bikejrff
bikejrff's Avatar
Bikes: No. 22 Bicycle Great Divide, Lynskey R260, Salsa Colossal Ti, Litespeed T5, Lynskey Peloton, Bianchi Vigorelli, CAAD 10, Giant FastRoad CoMax 1, C-Dale Quick 1
Quoted: 50 Post(s)
Liked 36 Times in 18 Posts
Originally Posted by Phil_gretz
^this is really it. No bike will make you a better climber. Only you can make yourself a better climber. It's hard work. Lose every ounce that you don't need on your body.
I had to laugh when I realized as I was reading your post I was eating an ice cream sandwich.
bikejrff is offline
Likes For bikejrff:
Old 07-22-20, 01:47 PM
Dave Mayer
Dave Mayer's Avatar
Quoted: 1370 Post(s)
Liked 476 Times in 278 Posts
Climbing gear ratios? Marco Pantani used 54/44 rings together with a 11-23 cassette - on the tough climbs. Like Ventoux, where he would ascend long 8 percent grades at 20 mph. LMMV.
Climbing bike: as light as possible (<15 pounds), particularly minimizing wheel rotating mass. So carbon frame and low-profile carbon tubular wheels - obviously. 300 gram rims with 200 gram tires. No discs or other useless ballast - obviously.
I've seen the studies that imply that a couple of pounds on the bike will make little difference. These miss the fact that every pedal stroke incurs an acceleration, and the power for these thousands of accelerations per climb come from you.
Dave Mayer is offline
Likes For Dave Mayer:
Old 07-22-20, 01:58 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
Inertia works in both directions. A higher-inertia object resists acceleration, but also resists deceleration.
Increasing mass does increase gravitational drag, but there's no micro-acceleration secret sauce.
HTupolev is offline
Likes For HTupolev:
Old 07-22-20, 03:17 PM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 646 Post(s)
Wow. That’s about 700 watts! He weighed about 55 kg, so rough estimate of 8 kg bike (total 63 kg) means about 440 watts for the climbing term, about 240 watts for the aero term at 20 mph (8.9 m/sec) and another 10 watts per tire plus 10 watts for drivetrain.
Otto
ofajen is offline
Likes For ofajen:
Old 07-23-20, 12:31 AM
ZHVelo
Quoted: 528 Post(s)
Yes, the average Joe is definitely as strong as Pantani and able to put out the watts he did.
ZHVelo is offline
Likes For ZHVelo:
Old 07-23-20, 03:42 AM
rbrides
Curmudgeon
rbrides's Avatar
Quoted: 157 Post(s)
heck yeah!
rbrides is offline
