Addiction 2022.1
#2701
Administrator
Quoted: 11981 Post(s)
Liked 6,689 Times
Fasten your seat belt, it gets bumpier.
#2702
Administrator
Liked 6,689 Times
See post 2701.
#2703
Quoted: 20810 Post(s)
Liked 9,456 Times
#2704
VFL For Life
Bikes: Velo Volmobile
Quoted: 28673 Post(s)
Liked 1,860 Times
#2705
Habitual User
Quoted: 5006 Post(s)
Liked 8,177 Times
#2706
Should Be More Popular
Quoted: 22628 Post(s)
Liked 8,950 Times
Please do. I've only had it a month or so but I'm shocked how fast it loads my sensors from 3 different bikes without hesitation and that's a lot of sensors. Besides my HR and Varia, that's three different PMs and electronic shifting systems. It seemed like I always fiddling with sensors on my Garmins. Also, the thing uploads to Strava quickly by using my phone as a hot spot. My Garmins would upload for a week or two and then decide to just screw it.
Anyway, tell him that I'm happy.
#2707
Liked 8,950 Times
I have a softner but my Gaggia seemed to have trouble with the three-way solenoid plugging up. My Rancillio doesn't seem to have that problem. In fact, I would see mineral bits in the water when descaling my Gaggia but I couldn't't detect any in my Rancillio.
As for frequency, Rancillio wants you to run a little through the machine and then wait 25' and do it a 1/4 tank at a time. Then rinse with two tanks of fresh water. That's a couple hours. Supposed to do it every three months with purified water or softened water. I use both.
Likes For datlas:
#2708
Super Modest
Quoted: 10979 Post(s)
Liked 4,642 Times
#2709
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3224 Post(s)
Liked 1,865 Times
We were a couple of days without internet. We went to the Guatemala border and down the Usamacinta River to the ancient Maya site of Yaxchilan, a ruin that's been on my list for 35 years, due to its location. It can be reached by river or by air(and probably on foot). We stayed two nights in the Lacandon forest.
#2710
Liked 8,950 Times
#2711
Liked 1,865 Times
Coming out this morning we noted lots of people walking on the side of the road. Our driver informed us they are refugees from further south, trying to get to the USA.
Sobering.
Sobering.
#2712
Liked 1,865 Times
#2713
Bikes: Shmikes
Quoted: 10182 Post(s)
Liked 5,881 Times
Got a fancy new outdoor light fixture today, hooked it up, and it blew up within minutes. It’s got $150 worth of electronics sitting on the board with the LEDs. They blamed it on the photocell switch I replaced at the same time, so they’re shipping out a new board, but asked me to skip the photocell. The photocell has failed in the “on” state and is only showing 9 kOhms between the hot neutral feeders, which seems low, and the insulation is burned on the hot wire of the light. Best hypothesis is the photocell shorted and overloaded the LED circuit. I actually think that’s where the spark was.
#2714
VFL For Life
Liked 1,860 Times
#2715
Liked 1,865 Times
I have the Lincoln Highway Companion on my Scribd reading list. Don't know when I'll get to it.
#2716
VFL For Life
Liked 1,860 Times
#2717
Habitual User
Liked 8,177 Times
#2718
VFL For Life
Liked 1,860 Times
#2719
Liked 1,865 Times
#2720
Mostly Harmless
Bikes: Have two wheels
Quoted: 13730 Post(s)
Liked 4,539 Times
#2721
Mostly Harmless
Liked 4,539 Times
#2722
Quoted: 9656 Post(s)
Liked 6,366 Times
Had real food for supper - chicken enchiladas with a verde sauce, and cilantro-lime rice.
Likes For Mojo31:
#2724
Klaatu..Verata..Necktie?
Quoted: 10466 Post(s)
Liked 11,964 Times
Route 30 was also the alternative way to get to Pittsburgh, if you didn't want to take the Turnpike. It's WAY hillier than the Turnpike, since it has to go OVER instead of THROUGH a couple of the ridges of the Alleghenies.
#2725
Silver Comet Fred
Bikes: 1
Quoted: 8854 Post(s)
Liked 3,005 Times
Boringly technical discussion of bike geometry and fit follows. Feel free to scroll past:
I was puzzling over why the saddle on the Litespeed seems to be slammed forward in the cradle of the zero setback post I bought. After a bit of analysis, I conclude it's a combination of several factors.
1. Because I have short thighs for my leg length, my saddles are generally farther forward than average.
2. Because my legs are long for my height, and I point my toes when I pedal, my saddle height is higher than average.
3. Because the virtual seat tube angle at 73 degrees is more slack than my other bikes
4. Because the ACTUAL seat tube angle is even more slack than 73 degrees, since the seat tube is curved to shorten the seat stays
5. Because the clamping part of the saddle rails on the Fizik Aliante VSX is about 1 cm farther forward, relative to the contact points, than my other saddles.
The funny thing is, with the saddle slammed all the way forward in a zero-setback post, the saddle setback (measured saddle nose to center of BB) is about a cm greater than my other bikes with different saddles. So I measured the distance between what is functionally the back of the saddle and the tip of the nose, and the Fizik is a cm shorter. Which just goes to show you that measuring setback that way only works when all your saddles are the same.
In any case, Sunday's ride confirmed that the saddle height and setback are correct, no matter how odd they may look.
Likes For DougRNS:
