Show Your Vintage MTB Drop Bar Conversions
#7201
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Dew Deluxe,Zone Ltd. (frame, needs parts), Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, Fantom Cross Uno, Bridgestone 200
Quoted: 108 Post(s)
Liked 227 Times
Mine isn't really suited for racing (I don't think so anyway), but I did build it with all sorts of road types in mind. It'll suit for those trips when I'm even hesitant to take the LHT.
#7202
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
It’s a Cyclone MK-II body that I attached a 3-pulley to. It was a clean swap from the original GT cage. For as much as I also love the look, it seems to get very temperamental if the hanger is even slightly misaligned.
#7203
Yes, it has required a bit of adjusting and seems like it will work out well. Still not 100% but it is getting there, and a little touch to the barrel adjuster mid-ride is ok for now.
I'm using a no-name stem adapter which I bought a while ago, so I don't know which website. I can't recall how tall this one is but I know its either 160 or 180mm. In this photo it isn't quite extended to the max height, so I can still bring the tops level with the saddle if needed. Maybe I'm wrong, but I haven't heard of many quill stem failures on the fork insert part so I'm not very concerned about the reputability. I think most fail near the handlebar clamp.
#7204
Loving all the tan wall options showing up on the vintage drop bar MTBs. I went with the Maxxis DTH for mine. But the Billy Bonkers and the Gravel Kings look pretty sweet.
Here's my ride in its latest iteration (photo is from summer though). She's a pretty steady gravel road climber. The only thing I may change yet is the stem setup. Maybe doing a threadless stem adapter quill stem. Actually, how I go about that might depend on a recent observation I had of the steering behavior. I'd been riding a vintage flat bar MTB a bit on some single track trails and hadn't gotten out on the drop bar MTB much. First ride I took on it again, I felt a sensation like it wanted to steer into the corners. I can't recall noticing that phenomena before and I don't think I have on my road bike either (though, I haven't been riding it for a while either and not since I road the flat bar MTB more). Can it be something to do with stem height, or length? Or some combination of them?
Likes For mattk42:
#7205
Quoted: 86 Post(s)
Liked 78 Times
Interesting! Mine is an original XC body that hasn't given me any trouble even after repairing the broken off b-stop tab. I'm on the lookout for derailer bodies that could be subbed in when it finally fails for good.
#7207
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
so, you never noticed it before on this bike? i would guess if you're used to how it or other mtb's handle with flat bars, then it could be just that. mtb's aren't really geometrically designed for drop bars. so, your weight distribution changes going from flat bars to drops particularly at the front wheel. more of your weight is toward the front wheel and your sensitivity towards it's handling would be accentuated. and, weight distribution affects how front trail/wheel flop behaves
#7208
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
These bikes look so rad, I really want to make one and those tan wall tires give it that extra bling. I notice most people have to raise the handle bars significantly, is that because the ergonomics of the mountain bike frame require it or more of a personal choice? I admit, I like the look of the builds using a road bike stem and bars but want it be comfortable enough. This is the bike that I would be converting if I can do it.
Likes For gthomson:
#7209
What a beauty. What size are those DTHs and where were you able to find them? I've been looking for the fatter version of those but can't seem to find them.
#7210
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
#7211
small ring
Quoted: 438 Post(s)
Liked 925 Times
93 Rockhopper single speed
not sure about the silver/grey bar tape but I get tired of always using black. Thinking about adding racks
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
#7212
Likes For mattk42:
#7213
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
#7214
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
There used to be little alloy loops that fit over the back end of those racks for reflector mounting. You could probably use P-cllps to approximate one, or drill through the joint where the top loop and stay run together for an inch or so and bolt through there. I've done that.
Likes For thumpism:
#7215
Quoted: 282 Post(s)
Liked 129 Times
Likes For vp1337:
#7217
#7218
Bikes: Lots of Schwinns
Quoted: 109 Post(s)
Liked 250 Times
this thread inspired a Drop Bar build, the candidates are a '94 Single Track 920 in Purple (love the color) and a '96 in Green. The Green fits better at 21" so its likely the one, the purple will either get moved on after it donates/swaps some of its better parts to the green (def the tan wall tires!) - or just become a family loaner/campground cruiser for the wife. I did put 40 miles on the purple before deciding its just too small. Unfortunate as its really nice and clean.
The only new parts I plan to buy for the Green are some Micronew 7 spd brifters. I have the 10 spd version on a recent build, and for the money - very happy. I think I have the rest of the part on hand which puts me well under $200 for the total build.
question - at 42-32-22, and a 11-28 cassette in 7 spds, seems to spin out on any kind of downhill , trade off is some insane low ratios for climbing which could come in handy on a trip we are planning to Colorado next summer - but would 48-38-28 be better for mostly road use? I'm an average, maybe improving, but def average cyclist. How would the 42-11+ combo be on a relatively flat rail trail such as the Katy Trail or Mickelson?
I ride a 50/34 11-28 set up mostly on my road bikes in my area. the 34/28 is enough for my toughest climbs (prob not tough to you hill climbers)
thanks for any input!
Likes For justcynn:
#7219
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 267 Times
Likes For squarenoise:
#7220
Quoted: 472 Post(s)
Liked 1,028 Times
Are the stem diameters the same? Can you install your bar n stem set in each to get a feel before you ditch the purple bike. BTW! Yeah, great paint on the purple one.
This is the 850 on my Century ride thru the woods. That is probably 8" of seat post showing. The reach from the sit bones to the hoods is exactly the same as on all my road bikes. That's helped with fit. Good luck with your project.
Likes For Prowler:
#7221
Quoted: 109 Post(s)
Liked 250 Times
Before you commit check the top tube lengths. Remember, on many mtn bikes the TTs are relatively longer than on road bikes so the purple bike may be fine once dropped and you're riding on the hoods. I'm 6' tall with 32" inseam. My conversion is a '95 Trek 850, 19" frame. It is very comfortable. Every day comfortable. Last summer I did a 100 mile ride on it, through the woods one day.
def gonna give it a shot. Both are nice bikes, but the purple is def nicer
#7222
Bikes: 2020 Trek Checkpoint ALR5, 1991 Trek Antelope, 1993 Specialized HardRock, 2021 Trek Slash 9.9
Liked 5 Times
Just spent a few days scrolling from page 1. Like a number of others, I created an account specifically for this thread. Looking forward to checking out more cool conversions and posting my own once I get to 10 posts.
Likes For cjm1347:
#7223
Is this too much stem? The stem it had on it was garbage and this was the only 25.4 stem I had. Its a 135! Riding the hoods, the hands would be right at or maybe just past the front hub. I'm thinking of building it up just to see what the ride characteristics are like.
#7224
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
...it also probably means the bike's geometey isn't ideal for you, but many of these bikes fit that reality.
If the Stem is being used simply because it's what you have, maybe pick up a different one and some 26.0 or 31.8mm bars.
#7225
Quoted: 1952 Post(s)
Liked 2,013 Times
With all that seatpost, your stem may work fine. I would put some cranks and pedals on it and spin a bit before going any further with the build.
