How do I remove a freewheel if the tool doesn’t fit over the axle nut?
I can’t remove the axle nut because the nuts on the other side untighten instead and there’s no grip. At my wits end here - please help!
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
There's a different tool with extremely thin walls that will fit, by Bicycle Research. You might try breaking loose that locknut but it might unscrew the cone with it. I've done that.
Quoted: 3813 Post(s)
Liked 6,727 Times
Put a wrench on the flats of the cone of the non-drive side (the cone is under the locknut), then another wrench on that locknut+spacer on the drive side and turn counter clockwise.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3894 Post(s)
Liked 6,497 Times
This is not rocket science.
Quoted: 4722 Post(s)
Liked 3,039 Times
Likes For T-Mar:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,006 Times
Take the axle out, It will not matter what side you remove it from. Take off the keeper nut and the cone from the NDS and pull the axle. Be prepared to have some bearing fall out but this will make it easy.
Likes For bwilli88:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
And clean everything and re-grease before you put it all back. PS-while you have the axle out break the lock nut loose before reassembly. it will help greatly when you go to pre-load the bearings.
Quoted: 3464 Post(s)
Liked 2,831 Times
Atom removal tools presented the same problem.
I suggest cone wrench on the non drive side cone, remove the offending spacer nut
side on remover- then remove the freewheel.
repack the hub and adjust, lube hub threads and assemble after you service or exchange the freewheel.
I was able to remove the freewheel by getting a second nut stuck on the nd side even harder. The threads on the nut and/or axle are stripped. Now I’m not able to get that nut off. Two-wrench method is not working as both lock nut and cone turn instead of staying stationary.
Not helping.
They kept breaking loose because the axle itself would turn when I went after the frozen nut.
This should have worked but … it didn’t. I should have tapped it harder from the ND side I guess.
Thanks everyone for suggestions! I guess I’ll cut the stuck nut off …
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
try running it under water and throwing it in the freezer first. it might be enough to break the surface tension of the stuck nut
Liked 6,727 Times
Well, freewheel is off, so that’s good! Replacement axles are easy to obtain, too.
Quoted: 1109 Post(s)
Liked 1,329 Times
If so what has happened is you have removed the threading from a short section of the axle underlying the nuts; and further raised an edge from the portion of the threads just outboard each nut such that the nut will not engage the thread leading away from the damaged section.
Congratulations.
In any case, the cheap-and-cheerful solution is a new axle complete with cones. Save at least one locknut, and when you get the new axle do this:
Check to see if the drive side has a cone, then a locknut (with possibly a washer between), then the spacer, then an outer locknut to hold the spacer on. It probably doesn't, it probably just has the spacer locknut holding the cone as well.
If it doesn't, take the locknut you saved and put it next the cone (with washer between if there is one).
Use a smaller spacer to compensate for the additional locknut.
When you build the axle
1. do the freewheel side first, get the cone/(washer)/locknut/spacer/locknut package on so you have enough axle sticking out that side to hold it in the frame
2. tighten the freewheel-cone and its locknut TIGHT. *Very* tight. You want that to come apart last next time, and you don't want it loose and spinning inward destroying your hub.
3. put the axle in and adjust the bearings from the non-drive side, tighten that side locknut tight, but not as tight as the freewheel side.
4. put the spacer and its locknut on, tighten them as the non-drive side.
5. put the freewheel back on
Old fart
Quoted: 3594 Post(s)
Liked 3,404 Times
Liked 2,446 Times
Right. Remembered I have one but was too lazy to go out to the garage to check.
The backstory is as follows: after realizing that I can’t fit the freewheel tool over the lock nut and ND side is not able to provide sufficient tension to unscrew the drive side locknut I panicked and tried to hold the axle on the drive side with a locking wrench damaging the threads. I then tried to force the frame (outer) nut on to see if I can still get it on. I could but with a lot of force which I think damaged the nut threads. I took it off then and after some more fiddling must have put the damaged nut on the ND side without realizing. While trying to get that on (very tight) I broke the drive side lock nut loose allowing me to remove the freewheel. I noticed that the nut I was trying to screw on the ND side got very hot. So here’s where it leaves me. In hindsight forcing the nut was a bad idea but I was worried that I had the freewheel stuck. Embarrassing
Quoted: 478 Post(s)
Liked 634 Times
If you are planning to possibly destroy the axle anyway, why not grip the non-threaded portion of the axle tightly in a vice or with vice grips and try unscrewing the stuck nut? Best case it comes off with only a bit of cosmetic damage to the unthreaded portion......
(And by tightly I meant TIGHTLY)
Liked 1,329 Times
No, that’s not it. Here’s what I think I’m supposed to be doing: unscrew both cone and lock nut up to the stuck nut, that should ensure that the lock nut has no axle thread left to screw down on, effectively locking it between cone and frozen nut, then with two wrenches tighten the lock nut and loosen the frozen nut. This isn’t working as the cone below starts to screw down together WITH lock nut and I don’t have opposing tension to unscrew the outer nut. Do I make sense?
Better luck next time.
OP used the wrong tool.
A larger splined tool would engage the outer splines on the freewheel, missing the lock nuts all together.
Having the right tool makes all the difference in the world, even if used infrequently. Albeit a non-professional, I still have about 10 freewheel removal tools and some other odd ones.
Liked 1,329 Times
And I'm having trouble seeing these "outer splines" on the freewheel.
No difference at all if you don't know how to use it.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I think what was meant was the splines IN the freewheel that are to the outside of the TOOL, lol.
And for any stubborn threaded nut on an axle, whether it's a locknut, cone or axle nut, there are ways to make them easier to turn.
Penetrants or heat do have some effect. Another favorite method I devised is to put the nut in the vise and compress heavily on two opposing flats. Repeat this several times, turning the axle and nut 1/6 turn between compressions. This causes elastic ovalization of the nut so creates clearance between the threads of the mating parts, loosening them. Using some oil at the same time makes this even more effective, the nut may then spin off by hand!
Cut off the nut to liberate the cone. Ordered a new axle as the threads were messed up on the old one. In hindsight, the best solution (in my case) would have been pushing out the axle after removing the nuts from the ND side. Had I remembered that the dustcap was separate from the cone I would have pushed it harder. I thought they were a unit and the cap is blocked by freewheel. Then the drive side lock nut could be dealt with using something like this. Big fiasco, a lesson learned. Hopefully I won’t mess up the new one.
Again, thanks to all who chimed in with suggestions!
Perhaps this will help. Then again, maybe I don't understand the OP's problem.
"No difference at all if you don't know how to use it." - well, that's kind of raspy. :-)
OP has solved his problem. That's good.
