Most expensive vs "ultimate" touring bikes
#151
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 322 Times
I spent all summer making myself a CF chaincase. Not perfect because of a big crank hole, but will keep the rain off. It is the strongest by far however.
Besides that I don't like the belt's wavy mimic a chain design. The square grooves on Harleys looks far better to me.
#152
Quoted: 671 Post(s)
Liked 49 Times
In re electronic shifting, one convenience could be a single control where rider selects gear # & it shifts front and/or rear automatically. Also, how about brake-by-wire hydraulic brakes?
For frames titanium is nice but a bit pricey. If there was one improvement for touring frames I'd like to see front & rear elastomer suspension which would work well with affordable & light aluminum frames.
#153
when you get to France , drop by the Berthoud HQ, there they will build a made to measure bike of your dreams ,
if you dream of those.
#154
I was in Hartford last weekend at the Cyclocross Nationals and Shimano just came out with an electronic MTB group that has that. Works with 3x11 and 2x11. One shifter, front and rear derailleurs shift as needed to avoid cross chaining. It was on display, I didn't see any bikes using it. Shimano rep told me that although competitors are moving away from triple and even double chainrings, they still see a need for triples.
#156
I'm thinking all we have to do is pedal. The electronics will do all the shifting AND steering. That would make touring really fun like those stationary bike bikes at the gym! Except after 6 hours of pedaling you stop and you're in another gym.
#157
Quoted: 2236 Post(s)
Liked 1,314 Times
Yes indeed because... shifting gears on a tour bike has been soooo stressful up until now.
Can't someone make this easier because mah finga's is plum wore out.
#158
Quoted: 3461 Post(s)
Liked 1,467 Times
On two of my derailleur bikes with triples, I changed the tooth count on one or two of my chainrings, if I had some computerized system where it shifted my front and back for me, it would likely get it all wrong on bikes where I used chainrings of alternative sizes. Same issue if I changed cassette sizing.
And I avoid using the two most cross chained gears for each chainring, for example on the middle ring I avoid using the largest and smallest rear sprockets. With my eight speed cassette and triple front, that means I only use 18 out of my 24 possible gears. But I am quite sure that a manufacturer would use all 24 gears because if they did not and their competitor did, their competitor would brag how many more gears their bikes had.
That shifter would likely be programed for a specific crankset and specific cassette. I really like the ability to switch things around. On my rando bike I am using a Shimano XT M739 rear derailleur, Sram 11/32 eight speed cassette, a Campy triple, some other brand of front derailleur, Campy brifter for the rear and vintage Huret downtube friction front shifter with Tektro front brake lever.
But for those bikers that fix their own flat tires but leave all other bike work up to the bike shop, then I can see that such an electronic system would work fine because they are never going to use a component other than one that was part of that specific gruppo. And once one component breaks and is no longer available, then the whole bike becomes a pile of used parts and they buy a new bike. I know a couple bikers just like that too.
#159
Liked 1,467 Times
If the electronic steering hits bumps and potholes, you might spill your drink.
#160
#161
no need for that.......VR goggles now with blueteeth connectivity
to your very own tourbot!
#162
They started out in Branford, relocated to Montana as an online business after fire destroyed the downtown Branford location. Bought my first pair of proper cycling shoes there in the early 80's long before I moved here. The Montana business was destroyed by a wildfire. New ownership, now in Seattle.
#163
https://www.youtube.com/watch?v=mT3vfSQePcs
#164
Quoted: 671 Post(s)
Liked 49 Times
Maybe Shimano will cut me a royalty check! I like my barcons OK, just kinda fun to think about new tech possibilities.
#166
Quoted: 671 Post(s)
Liked 49 Times
You just described a non-electronic version of my Rohloff.
#168
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
#170
Quoted: 671 Post(s)
Liked 49 Times
So far a mild winter in Mid-Atlantic US & next 10 days will be quite warm. Really messing up the local ski situation.
#171
AllWeatherJeff
48
05-22-19 08:41 AM
Kertrek
Touring
6
09-07-15 07:42 AM
