Trying to convert 27" to 700C w/ Cantilever brakes...
Quoted: 838 Post(s)
Liked 1,082 Times
Quoted: 1872 Post(s)
Liked 692 Times
And we'll probably have to turn the front ones around backwards.
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
The pads pictured in the Amazon link look like the Eagle Claw. There's a customer photo lower down that also looks like an Eagle Claw. This looks like it should definitely be the thinline.
Quoted: 838 Post(s)
Liked 1,082 Times
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Quoted: 4806 Post(s)
Liked 3,932 Times
I had a Miyata 610 ('83?) that came with 27" and Shimano cantis. I went from the start with 700c, just tipped the pads down, let them wear in and made it a point to check them several times per pad life. Pretty easy. Swapped the calipers to identical (geometry-wise) Mafacs. Front went to centerpull later. (That bike saw several big crashes.) Yes, the pads would "drift" (I forget whether it was up or down" but correcting it wasn't hard. Brakes stayed excellent throughout.
My namesake Mooney has cantis positioned half way between 27" and 700c so I could run either. Started on the Mafacs. It got the Miyata's brakes because they were nicer.
Liked 3,932 Times
Turned out the bike has always lived in 700c country. First 6 years were Santa Cruz and the Bay Area. JUst kept riding sewups. (And 700c was easy to get out there, even back then.) I had that bike made to do everything but race. (Went with horizontal dropouts just so it could go fix gear.) 38 years later, I put big tires and 3 mountain fix gear ratios on it to ride a mountainous part gravel tour. 700c but the first time I put on the fat tires it was designed for. And it loved them!
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
My ‘85 Miyata Two-Ten came stock with 27” wheels. The only reason that might persuade me to change to 700c wheels might be tire availability. I’m sure that there are other valid reasons but for now, I’m not considering them. RE: the adjustability of the Dia-Compe 981, that oval shaped hole in the canti arm certainly allows for it. That option is not part of the design on the Dia-Compe 960s that on on my Two-Ten. (Perhaps another reason to stick with the 27”ers ). I did have more than a little bit of a struggle setting the pads properly and can’t imagine that having the oval adjustment slot would make it any easier. The convex/concave washer arrangement on both the 981 and the 960 does allow for toe-in. Since that has nothing to do with “upgrading” to 700c wheels (the OP’s topic) I’ll stop now .
Liked 692 Times
shoota My thinlines have arrived. They are much longer than I expected, but are indeed very thin as well.
polymorphself btw you have to use the "@" symbol, then the user's name comes up in a list as you type. I almost didn't see this. Or this feature is just broken.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 838 Post(s)
Liked 1,082 Times
How do they fit? And more importantly, stop?
My new old 700c wheelset is being laced as we speak so the new pads haven’t been mounted yet. I’m picking the wheels up tomorrow.
Liked 692 Times
Oh cool, I’m interested to see your wheel build. I’m going to have to find a suitable set of wheels too.
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 838 Post(s)
Liked 1,082 Times
Ill post a pic here when I pick them up.
Likes For polymorphself:
