Crashing techniques and styles
#251
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
If you're trying to stop in the shortest distance possible in an emergency, over clean and dry pavement, using only the front brake does the job best, if not, with the most reliable results.
Just because the hypothesis had the misfortune of being presented by LarrySellerz does not discredit it.
There's many reputable sources on the internet saying the same thing about front brakes.
#252
Quoted: 4227 Post(s)
Liked 2,488 Times
#253
Quoted: 4260 Post(s)
Liked 1,364 Times
Listening to you is much less effective.
You can’t practice techniques just by reading articles (on the internet or not) for reputable sources but you can certainly learn about what to practice.
Figuring it all by yourself isn’t going to be effective.
#254
Liked 2,488 Times
I don't need experts on internet to tell me how to use my brakes, when to use my brakes or if I should be using one or two brakes to stop. I learned all that stuff by going out and riding.
#255
I tried to post an MP4 video of me falling off my bike yesterday but at 360KB for 1min 34sec, it's too big and I don't have a Youtube channel to link to.
#256
Liked 1,364 Times
Anyway, you are telling people to ignore everything you write here. And you aren’t reputable either. Bizarre.
#257
Now that I'm older, it wouldn't be advisable to take deliberate risks that will likely result in a crash and so far, internet seems good enough.
Likes For koala logs:
#258
Liked 1,364 Times
Back in the early 90's without internet, I figured out many things about bike handling by experimentation. That included braking in the shortest distance possible and how fast can you ride across a speed bump riding one handed without falling.
There were places to read about this stuff before the internet existed.
Many people are scared to use their front brake. Does it really make sense for all of them to figure this out by themselves?
#259
Liked 2,488 Times
#260
Liked 1,364 Times
You aren’t any sort of expert. So there’s even less reason to believe anything you say.
#261
Klaatu..Verata..Necktie?
Quoted: 10440 Post(s)
Liked 11,914 Times
Likes For genejockey:
#262
Quoted: 2700 Post(s)
Liked 486 Times
sheldon brown is ridiculously legendary and he says only using the front is fastest, because the rear gets unweighted so any braking force applied to the rear will cause it to skid
#263
Quoted: 1279 Post(s)
Liked 1,393 Times
and yet, all you have to do is roll down a hill and apply the rear brake (only) gradually to discover that the above isn’t true. yes - some amount of force will break traction. but “any braking force?” no, absolutely not. depends on a complex mix of speed, weight, weight balance (position on the bike), grade, type/size of tire, road surface…
Likes For mschwett:
#264
Liked 2,488 Times
Sheldon is a useful source of technical info on bike maintenance and tinkering, bike parts info etc...however when it comes to bike handling I will go with my own experience over what somebody else has said.
#265
Liked 2,488 Times
#266
Advanced Slacker
Liked 2,537 Times
He is not legendary for his bike handling skills or coaching. He's more like Grant Peterson talking about how to ride: a guy with opinions.
And frankly, his article on this is pretty weak. His arguments are mainly based on a false dichotomy of "Only Front" vs "Only Rear"
Also, I have no idea on what he is basing his assertion that "skilled cyclists only use the front brake 95% of the time". I don't know anyone who almost never touches the rear brake. Its a bit of a True Scotsman argument he has there.
Likes For Kapusta:
#267
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
He is legendary for his Bicycle mechanical knowledge and how he shared it.
The more I think about this unweight the back wheel stuff, the less sense it makes. Taken to its extreme, putting the rear wheel in the air puts the frame and rider in the air with a lot of god only knows what lateral momentum while all of the weight is on the fork and front wheel. That sounds like the bike could actually jack knife like a semi.
Likes For livedarklions:
#268
It's real. The lateral momentum is also real. In fact, you can get catapulted up and laterally at the same time.
#269
Liked 11,914 Times
Not surprising - when I've skidded the rear wheel the whole back end of the bike kicked out to one side.
#270
Liked 1,364 Times
No one is claiming that the rear brake alone (or with a front brake not used heavily) has no "braking force".
Using the rear brake alone doesn't have the front-weighting issues that occurs with using the front brake hard.
#271
Liked 1,393 Times
You are definitely not understanding the basic argument.
#272
Liked 1,364 Times
https://www.renehersecycles.com/how-...-on-a-bicycle/
#273
Quoted: 3514 Post(s)
Liked 2,927 Times
I have two brake levers, and will continue to use both brakes at the same time, regardless of what some guy I never heard of named Sheldon or Larry or anyone else says.
#274
Liked 1,364 Times
that’s not how i interpreted larry’s statement, which didn’t specify whether the rear brake was being used alone or in tandem with the front. i agree that the dynamics are different when both brakes are used, but if there was no load whatsoever on the rear wheel, you’d have other problems than slowing down. at least i would. my example holds if you add a small amount of front brake before gradually applying the rear. it does NOT (at least in my universe of bikes and hills) result in any kind of instantaneous skid/lockup. in fact it slows the bike down faster.
No one says using the "gradually applying" the rear brake always result in "any kind of instantaneous skid/lockup".
It seems more than likely that very few people are braking at the limits. For those people, also using the rear brake is going to be faster.
The problem is that the "armchair experts" here think because they don't brake at the limit, whatever their technique is (and it could be terrible) must be faster.
#275
Liked 1,393 Times
If you can apply the rear brake without locking up the rear wheel, then your weight isn’t shifting forward – a clear sign that you aren’t braking as hard as you should …
