The Water Cooler, Scuttlebutt, Chit Chat Thread
#5251
Quoted: 8287 Post(s)
Liked 9,062 Times
#5253
Liked 9,062 Times
He also sells a line of helmets for bikes and moto. No TT helmet, though.
Likes For ridethecliche:
#5257
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Man... I just got this cross bike and havent even ridden it once and it's already a headache.
It came with a Shimano crank with a 46/36 setup which I figure is totally fine for road/gravel /cross. The arms were 175, big for me but fine because Im swapping my road cranks up 165 and figured I'd swap the rings to my 172.5 cranks and call it a day.
Well the cranks on the bike were old style Shimano with the 5 bolt rings. All my stuff is the newer 4 bolt stuff now. Ended up installing a 50/34 setup on it for now and then found and ordered a 46/36 ultegra crankset on ebay for 85 bucks. Should be sorted when that gets here.
I have a left sided specialized power crank pm that id been using on my roadie that I was hoping would go on my cross bike.... But the clearance once it's installed is like 1-2mm. I have a 4iiii ultegra one that would match the incoming crank but I was hoping to sell it. Guess I can may have to install that since it'll have 1-2mm more space between the crank and the chain stay. Oy.
Hopefully these power crank pms have good resale value. I quite like mine... Oh well.
Starting to feel like i overpaid for the bike but I'm fair certain that it's because I haven't been able to get out on it yet.
I dunno.... 900 for an Al frame that's a little beat but has an 11 speed shimano hydro disc setup. And 2 sets of wheels, one for gravel and one for cross. Not bad imho.
#5258
I've been trying to find a MTB and someone on CL will sell me a 26er specialized hardrock for $100, no front wheel, but those should be cheap enough. I don't know if 26ers are worth being project bikes (seems like the world has moved on to 27.5 and even moreso to 29) I just want something I can goof around on and figure out if I really do actually like MTB. Of course it's a bad time of year to try, I'm kind of all in on my indoor base training lol
Likes For hubcyclist:
#5259
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Doesn't seem bad to me. I paid $700 new for my CX bike with cant brakes a couple of years ago, and I still consider it a steal. Of course you need to come back to NE for some CX racing next fall!
I actually gave up on getting the cables done myself after hours of struggling with the RD integrated cables. Dropped it off at the shop as a frame.
I guess I don't really see the point of installing my 50/34 crank on it for now since I'm waiting on the 46/36 I bought online. That should be pretty good for a dual/triple duty bike I think. Maybe I'll swap the 36 for the 34. I don't really want to deal with swapping rings all the time because moving from 46 to 50 will probably require moving the FD and adjusting the chain as well right? 46-11 gets you into the high 30s at 110ish rpm. Fine for short bursts.
Re mtb are you looking at older stuff? The 80s/90s trek mountain tracks are pretty nice for tooling around. If you're looking for something specific and nicer shoot me a message and I can ask some Boston mtb friends if they're selling anything or know anyone that is.
#5260
Liked 9,062 Times
#5261
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
If you've moved to shorter cranks, what changes did you make to compensate?
Just put the 165s on (from 172.5) and moved things up about 7 and back about 2 and it still feels pretty off.
I have my position marked off for how things were with the 172.5s but I'm hoping i don't have to go back to that if the 165s can actually be knee protective. I had been feeling mostly okay with the 172.5s lately but thought the trial would be worth it.
#5262
Version 7.0
Bikes: Too Many
Quoted: 1341 Post(s)
Liked 2,482 Times
When you raise the saddle up to accommodate the shorter cranks, the saddle also moves back and the seat to handlebar to seat drop increases. So there is a lot of small changes being made to the fit. You may have to raise your handlebars and move the saddle forward.
Likes For Hermes:
#5263
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
I guess I was just under the impression that the saddle would need to move backwards if the crank was essentially moving back at the 3 o'clock position.
#5264
Quoted: 1851 Post(s)
Liked 679 Times
That said, RTC, given all of your current knee problems and history of back and knee issues, I greatly encourage you to stop fiddling with things and go get a professional fit - on a fit bike - not your bike - to determine what size frame, stem, bar, crank you need. Then go buy exactly what you need given your unique physiological issues.
Yes, this may be more expensive in the short run, but it will ultimately save you in terms of pain, medical expenses and continually buying parts and frames to try out what feels better.
Missy Erickson in Allentown is an excellent fitter. https://www.ero-sports.com/2020/index.php
Likes For topflightpro:
#5265
Version 7.0
Bikes: Too Many
Liked 2,482 Times
I use ERO at the Carson Velodrome. Cyclists slide on the saddle a lot. We slide forward when in the drops which used to be called riding on the rivet. And we slide back when climbing. We change our ankle position by sometimes pointing our toes and others dropping the heal. The goal of a fit is to find a neutral position and secure the foot on the peddle and then set the saddle height. UCI has specifications as to saddle fore and aft position. Many cyclists like to move the saddle forward especially when riding the TT bike.
Going from 172.5 to 165 cranks is a big change and it does not surprise me that it would feel weird. In my case, the change on the track bike felt great. As I recall, we just moved the saddle higher. However, I went through a Retul fit in the studio and aero fit on the track with ERO.
#5266
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Due to the angle of the seattube, the saddle is already moving back when you raise it.
#5267
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
In other news.... the giant tcx I bought the other week as a cross/gravel bike has a crack through the chainstay. Haven't even ridden the bike yet, but I was cleaning it up and taking care of a few things and noticed it with the crank off. I took it to a giant shop which basically said it looked totally fine, then cdr told me to take the rear wheel off and try flexing at the dropouts to see what happens. You can see the crack move about.
Fark.
I hope the seller comes through. He's the original owner so he's going to look into warranty. I told him he should buy the bike back so he can sell the new frame he gets for more money. Dont want to have 900 bucks tied up in a bike I can't use
This bites.
Fark.
This bites.
#5269
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Face to face sale. I think I paid him by venmo.
He seems to want to help though and already contacted the shop he bought it from.
I offered to sell the bike etc back to him for what i paid. I'd be out some money since I bought cranks for it and had some work done at the shop. Shop hadn't mentioned the crack which is a bit off-putting, but I had sent it there for them to swap the RD cable inner.
So I offered to:
1) Sell him back the bike for what i paid
2) Work with him through the warranty process and wait along since it could be a while.
If he goes for option 2, it's possible the frame would be upgraded since all their new frames are carbon. Geometry seems to be the same though. Am I wrong in assuming that I shouldn't have to pay more if he goes for option 2? I just want to make sure my thinking is right. If I did end up with a new frame I'd probably send him some money anyway because it's something I didn't expect, but I also didn't expect to spend almost a grand on a 5 year old bike I can't ride lol.
So I offered to:
#5270
out walking the earth
Personally speaking I don't think you should be expected to pay more, nor do I think you should. You were sold something (knowingly or unknowingly) that was damaged. Yes you might get a better frame, but you're also unsure what might happen and you have to wait out someone else's error.
Likes For gsteinb:
#5271
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
#5272
Quoted: 140 Post(s)
Liked 327 Times
This kid is pretty darn fast. 36mph for 3km. Wow.
https://www.velonews.com/news/road/m...ursuit-record/
Likes For cmh:
#5273
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
Likes For cmh:
#5275
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Shorter crank experiment is going okay...
There's a 100% chance that the 52/36 is not low enough for me right now with the 11-32 cassette, esp with the shorter cranks. Definitely need to swap my compact rings over from the other crankset so I can spin a bit more. With the compact I was spinning pretty well and had a bail out gear I really didn't need to use. With the mid compact today I was looking for a bigger cog to keep my cadence up on some climbs. Ended up having to stand up which I didn't last time.
Oof.
Oof.
