Totally Tubular
#2626
Bikes: 1980 Dawes Super Galaxy + 1981 Lotus Classique + 1986 Bianchi Sport SX + 2005 Van Dessel Project WR + 2021 Zizzo Liberté
Quoted: 143 Post(s)
Liked 481 Times
Here's a question for the peanut gallery: why the hell is Conti glue so damned expensive these days? My old 350g can for which I payed $25 at my LBS is nearly gone. No matter where I look, it seems they want about $70 for the same thing. While it's been a while since I've purchased glue, the jump in price seems unreasonable to me. The tires themselves have gone up a bit, but by a reasonable amount.
I just ordered a can of Conti cement from Velosaloon in Austria. Fair warning, making their 50 euro order minimum turned into an epic trip down a rabbit hole of 800+ items in the sale/clearance section alone. My first experience with them but the site is fantastic, with clear photos and descriptions of even the tiniest parts. I am so looking forward to my genuine NOS French needle and thread kit for 90 cents
Likes For EVlove:
#2627
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
The discrepancy in price between Euro and US vendors suggests to me there's something going on, tariffs, perhaps?
#2628
Quoted: 143 Post(s)
Liked 481 Times
I tried. It worked, up to a point. Sure enough, 350g cans of Continental tubular cement are only €10,08 from Bike24, but doesn't ship to the US (to avoid competition with US vendors or shipping of VOCs?). I'm sure there are other vendors who will, but I haven't searched further.
Bike24 has a lot of items they won't ship to the US, everything Shimano, SRAM, DT Swiss for example. I suppose that's just a contractual obligation to protect the US distributors.
#2629
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 230 Post(s)
Liked 298 Times
To be honest, I don't buy the VOC argument since tubes of the stuff are still readily available. As I recall, Conti glue uses hexane as the solvent, and even with the cans, you're not getting exposed at high levels. A nearly triple-fold increase in price looks like gouging to me.
I'm still somewhat annoyed that dichloromethane based strippers are prohibited by law these days. Those in very small quantity were the best chemical means of removing sew-up glue from aluminum rims. Using non-trivial amounts in enclosed spaces is really a case of stupid games/stupid prizes.
#2631
Quoted: 4806 Post(s)
Liked 3,933 Times
*The front wheel is going on my first track bike and the rear may not see actual use at all so should I worry about that brake track wear? I can't seem to find a sectional drawing of the old aluminum tubular rims, only the carbon ones. I'll have to figure out a way to measure the wall thickness at the valve hole, there are no spoke holes in the gluing surface on these.
Well, I did state a photo could help clarify, but I bow to your judgement if the concavity is measured at less than 1mm. However, having said that, I wouldn't go so far as to judge a rim's strength based upon how well it held up when removing a previously-glued tire.
If you want true peace of mind, you should be able to find sidewall thickness data regarding your specific rim (even stuff from the 70s and 80s is likely to have specs giving that information). Also, in the case of Mavic's SUP rims, their modern offerings have a 'wear indicator' groove in the center of the brake track. When the sidewall is down to the point it's effectively been 'erased', it's time to retire the rim. To my eye, the groove is only a couple millimeters deep, so you might take that into consideration as well as you go forward.
While I'm sure that advice from the manufacturer is one way of ensuring repeat customers, it must also be a case of the same manufacturer not wanting the bad publicity of their rims causing accidents and possible death due to failure of the rim sidewall, and the likely accident which follows.
DD
DD
Yeah, I suppose you could have a very light rim fail on a corner and maybe taco but I still think the odds are far greater that any small pavement irregularity will cause the dent I described first. (Unless this is strictly a velodrome or perfect pavement criterium wheel.) My experience has been with the 330 gr Arc en Ciels (always died of pothole dents and the like - eventually too far from round and with poor braking), the 400+ gm whatevers of the same era (same deaths; just taking far more abuse to get there). and my Ergal and Medal d'Or race wheels. (Again, same deaths but far sooner.) The GP4s I mentioned above. Again, basically the same death. Front got retired when I got home because it also had zero sidewall in places.
Th new light racing rims with high strength alloys ridden by big, strong riders - well more caution is warranted. I'm guessing some or most of those have wear indicators that I would honor.
#2632
Liked 3,933 Times
The word is that Challenge has been not living up to the challenge of reliably gluing on the treads. I've heard that here and in relation to their clinchers elsewhere. (My venture with Challenge clinchers a few years ago ended after I stopped believing I had safe and reliable tires under me. Bead issue. Beads lifting off the rim, blowout and destroyed expensive tubes. After spending far longer than I ever have to get that bead perfect. Then I had both latex Challenge tubes, brand new, blow out at the junction between the valve portion and the rest of the tube. 10 and 14 miles from home, first ride. So, simply not rubber I want to do a mountain descent on. Sad that I am hearing issues with their tubulars. But Vittoria makes such a nice and idiotically reliable tubular that I'm simply going there. (I've got a pair of Veloflexes I'm looking forward to.) Vittoria has been making those stupidly reliable tires a long, long time. The cheap training cottons they made with so many different labels back in the '70s. (Yes, not all vendors took proper care of those tires. Thank you, Palo Alto Bikes!)
#2633
Likes For EVlove:
#2635
Quoted: 143 Post(s)
Liked 481 Times
Keep in mind we are talking tubular rims, not clincher. A sidewall failure with a clincher is bad. A rifle shot to the ears and the jagged sidewall is now a sawtoothed chariot scythe cutting all (chainstays, calves ...) in its path. But a tubular rim just collapses when the sidewall fails. And you just ride home a little slower, bump, bump, bump.
Anyway, as I have been explaining, I'm not rushing into this and will measure the wall thickness as accurately as I can before I put any more work and money into this wheel, let alone ride it. Right now I simply would like to find a sectional drawing to see what's what when the rim is new. Again, this is not a C&V wheel at all, it's one of those Mavic integrated things with proprietary hubs, spokes, nipples, and whatnot. At this moment, from what I have been able to observe, I think 1mm of aluminum is all there ever was in many places on these rims. Without removing the spokes (which, of course, requires a proprietary wrench), the valve hole is the only spot where the thickness of the extrusion can even be seen. The inner valve hole measures 1mm thick exactly, the outer is considerably thinner in the center of the tire bed.
#2636
Quoted: 143 Post(s)
Liked 481 Times
To explain in more detail, what I would like to find is something like this, except this is a Weinmann Pegasus clincher rim, not a Mavic:
So I imagine the Ksyrium looks much the same in cross-section, minus the clincher horns of course. My brake tracks are worn down but there is still a little "step" between the brake track and the rest of the sidewall. Which would mean there is just as much material left there as there is throughout the rest. But I want to measure that and/or confirm the original cross-section did indeed have extra material in the way of the brake tracks.
It's just not the same starting point as with an old school rim that's the same thickness everywhere and hence every bit of wear makes the brake track the thinnest wall.
#2637
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
Check into Araya Aero rims. There are several models which might work for you. One model below on my Raysport.
20080911_9 by L Travers, on Flickr
#2640
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
Well, I mounted my first set of tubular tires. I did not get them as straight-as-an-arrow, but they are on the rims. Some glue got around to where it should not be, but fortunately not a huge mess. What's the buzz? Lighter fluid will take it off? I pumped them up to 140 lbs to set them (my pump only goes to 160), and hopefully, I'll have good luck with them this summer.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
#2641
Quoted: 2588 Post(s)
Liked 4,826 Times
The front looks pretty much okey-dokey.
DD
#2642
Quoted: 1952 Post(s)
Liked 2,013 Times
You can’t be serious. 😇 Do over. You can do much much better. You have 4 months.
Likes For Classtime:
#2643
Standard Member
Liked 940 Times
Okay, I will. Thank you very much.
Likes For 1989Pre:
#2644
Standard Member
Liked 940 Times
I struggled just to do this, and it was my second try. You have any tips on technique?
#2645
Quoted: 1609 Post(s)
Liked 2,216 Times
Minimize pressure, then lift and adjust evey 6 inches or less. Check for uniform exposure of the base tape side to side.
Likes For SJX426:
#2646
Liked 2,013 Times
Yep. Go round and round, spin to check, make some adjustments, repeat til your satisfied.
#2647
Standard Member
Liked 940 Times
I'll give it a shot, but this tire is so tight, I don't think it is going to budge at all. Lift with what?
#2648
Standard Member
Liked 940 Times
Yeah, if there was no glue on the rim and tire, maybe I could do that! You seem to have no idea how adhesive this glue is. Nothing will budge, once the tire is on the rim. I am going to strip all the glue off the rim and going to tape. I've heard I can strip them with a hair-dryer and a rag. These results are entirely unacceptable. Now I see why my mechanic refused to do this job. Maybe I should have just used tape, instead of three coats of glue. It took me three (3) tire levers to get these tires on, because the glue I put on them seems to have prevented the tires from stretching onto the rim.
#2649
Liked 2,013 Times
Don’t give up so easily. I’ve only used Continental and Vittoria glues. What are you using? And I don’t think tire irons can be used to good effect. You want to stretch as you go and if you run out of tire, start over and stretch more forcefully. Watch some Videos. I think Continentals are the tightest and yours don’t look like them.
#2650
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
I'm just going to mention tape:
- Put the tape on the rim with backing still on
- Put the tyre on and centre it (it's not stuck yet)
- Pull the backing tape off (from underneath the tyre, at the side).
- Inflate to hard and leave
Likes For Aardwolf:
