View Poll Results: Frame Material Preference
Carbon Fiber
40
31.25%
Aluminum
10
7.81%
Steel
61
47.66%
Titanium
17
13.28%
Voters: 128. You may not vote on this poll
Frame Material Preference Poll
#51
Quoted: 4413 Post(s)
Liked 4,867 Times
I have no desire to try carbon because I believe it's inferior to steel it terms of toughness and durability. And I also have an old aluminum MTB with a rigid steel fork which is holding up great after many years of hard riding. The only issue with aluminum frame is a bit of galvanic corrosion on the lower chainstay bridge and that is the result of road salt corroding a steel bolt and reacting with aluminum. My steel frames had rustroofing oil sprayed inside tubes and there is no rust even after many years of winter riding.
Likes For PeteHski:
#52
Quoted: 6971 Post(s)
Liked 10,968 Times
I like steel, too -- three of my five bikes have steel frames. But let's be realistic.
#53
Quoted: 3241 Post(s)
Liked 2,512 Times
#54
Quoted: 8281 Post(s)
Liked 9,052 Times
#55
Quoted: 4227 Post(s)
Liked 2,488 Times
#56
Liked 10,968 Times
#57
Friendship is Magic
Bikes: old ones
Quoted: 26424 Post(s)
Liked 10,380 Times
...hi. What's this thread about ?
Quoted: 3952 Post(s)
Liked 7,299 Times
#59
Quoted: 18420 Post(s)
Liked 15,563 Times
Likes For indyfabz:
#60
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Fiber-reinforced resins do not exhibit a fatigue limit, which makes stress failure harder to design for. Presumably, bike frame engineers are being very cautious and building in big strength safety margins to be on the safe side.
Also, current fiber-reinforced resins typically are using a resin that is relatively brittle which is an issue because initial fractures may be hard to detect and tend to fail catastrophically. There are promising new matrix options that will significantly reduce brittleness but are currently too expensive.
Otto
#61
Liked 7,299 Times
#62
Quoted: 1034 Post(s)
Liked 1,290 Times
I've been doing so much research into frame materials that I actually forgot why I was looking in the first place, sorry. I'm looking for the holy grail of bikes. In other words, the single one that says, "Hey, you don't need those others." And that would make my DW very happy. She encourages me (I'm 73 btw) to do good in the neighborhood which is why I fix other people's bikes, cars, trailers, and whatever is needed. But she is now encouraging me to begin downsizing the herd. I'm looking for an endurance style bike that I can put full fenders on in the winter, ride strictly roads/mups. Don't need to fit anything wider than 28mm tires. And last, but definitely not least, not weigh as much as the iron I currently own. I've already donated several bikes to the local charity and I still have 2 sheds full. (They're small sheds) I need to get down to one though so the DW can have the other for a potting shed. My fave right now is an aluminum with carbon fork, but it's a racing geometry and after 30 miles I feel done in but love the speed and quickness of it. My second fave is vintage steel and so comfortable I can go all day on it, just much slower. I contemplated upgrading it to brifters and 700c wheels a while back, but that won't make it any lighter. The other's in the stable are mostly alloys with low end components that I never ride anymore. Carbon was my first choice, but then I started thinking maybe titanium. However, like I said earlier, my current fave is alum, so maybe just find an alum endurance bike with drop bars. Lots of nice ones out there. Too many options really. Just thought I would filter through what others thought and why. Thanks for all the input. Smokey
Likes For phughes:
#63
Liked 15,563 Times
Likes For indyfabz:
#65
Liked 15,563 Times
Likes For indyfabz:
#66
Liked 2,488 Times
Aluminum frames can be pretty damn strong and long lasting depending on the frame design, the type of aluminum used, and manufacturing process / quality control. Aluminum will only corrode if it comes in prolonged contact with corroded steel in wet salty conditions. Corrosion on aluminum frames is really a non-issue , I have never seen an aluminum frame corroded to a point that it was unusable.
#67
Liked 7,299 Times
#68
Quoted: 1819 Post(s)
Liked 1,696 Times
My experience with frame materials: Steel frames, the most comfortable and least comfortable frames were steel with several in between. Aluminum mountain bike frame: broke 2 main triangles and one rear chain stay. Titanium? Crack in seat tube. Carbon? No failures so far after over 15 years. Conclusion? These are not generic frame materials that you can judge by the material alone. I will not weigh in on the survey because it makes no sense
#69
Liked 10,968 Times
#70
Liked 9,052 Times
Likes For big john:
#71
Liked 2,488 Times
I've only few examples of aluminum drop bars getting corroded, but I've never seen any other types of aluminum handlebars getting corroded to a point of becoming unusable.
#72
Liked 2,488 Times
Your sweat must be more toxic and corrosive than the road salt and de-icing chemicals that I ride through each winter here in my city ...
#73
This is it for me. Road bikes I have ridden (I'm no connoisseur just an average Joe) I prefer steel IMHO its a less hard ride. On my Cruiser (like I said Im not a biking connoisseur) I prefer steel just like th feel and once its rolling along the extra weight isn't an issue. On my Fat bike the similar steel model is a figging tank so Aluminum gets the nod.
Likes For JehD:
#74
Liked 7,299 Times
The shape of the bar is irrelevant -- the fact is that aluminum can corrode, and there are many examples of aluminum bars corroding to support that.
#75
Liked 9,052 Times
It's pretty bad. I had a pick up for years and I melted the paint off the door panel and corroded the top of the door and the steel backing on the felt around the window from resting my arm there.
