Touring pics
Likes For djb:
#1729
Pining for the fjords
Quoted: 130 Post(s)
Liked 445 Times
Some of my best, most exciting miles ever, in the Lesser Kaukasus. Despite the big dogs chasing me every half hour or so.
Likes For CMAW:
#1730
Bikes: Corvid Sojourner, Surly Ice Cream Truck, Co-Motion Divide, Co-Motion Java Tandem, Salsa Warbird, Salsa Beargrease, Carver Tandem
Quoted: 534 Post(s)
Liked 435 Times
hope he is with her ;-)
Likes For PedalingWalrus:
#1733
Being so wide open, if the weather goes bad, I'm sure it could be quite a handful, and little shelter.
Were those tires ok, I think I'd have preferred wider.
Are they 1.75, 2 inch?
Must have been really neat biking there.
#1734
Quoted: 130 Post(s)
Liked 445 Times
Quoted: 130 Post(s)
Liked 445 Times
It was only a day and a half up there and in case of really bad weather I could have found shelter in one of the shepherds summer camps, there were quite a few of them (hence the dogs). 2 inch schwalbe almotion in the back, front is a 40 mm GTR1 (bontrager) because I had a blowout earlier. Not great for this kind of terrain, true. Wish I could choose my tires in the morning, depending on what's coming, like you pick out a tie. But it worked, slow and steady when it got really bad.
Ive used some Schwalbe Hurricanes, inexpensive 2.1 inch with a flattish tread in center, dimples off center, and then some actual knobs on the sides. Worked really well in mixed terrain, and nice with a medium load similar to yours when going in softer stuff cuz the side knobs help a lot in those situations (they make 27.5 and 700 versions in 2.25 and 2.4in) .....BUT there is always a compromise to be made for traction, speed and comfort isn't there?
and as. you say, I've been fine getting by like you with slow and steady through bad bits, but hopefully those aren't too long.
tire talk aside, those areas you're biking through look really cool.
#1737
Quoted: 130 Post(s)
Liked 445 Times
I have yet to try Almotions. Ive ridden a lot on 2in Supremes 26in, and for those sort of surfaces you were on, wider would be better. As you say though, either due to frame limitations or just balancing how much rough stuff you'll be on vs manageable stuff, it's always a bit of a guess of how wide to go---carrying a certain amount of weight, I lean more and more towards wider nowadays.
For wider tires I'm gonna need a new bike, maybe in a year or two - Fits Fatties Fine, but times change and you get older. Since a few years I've been toying with the idea to bring an extra tire for the front, a medium knobby Thunderburt, for this kind of situation. I' ve never done it (the weight!) and at some point always regretted it.
Georgia is fantastic, bit of a hype destination in Europe recently. There's a flat portion in the north, it's called the beach, and the rest of it are mountains . So you have to be careful and take lots of time off, to enjoy the great food for example.
I have a different model of fatties fit fine, that can take up to 2.5 maybe 2.8 tires, a Troll, and that was the appeal for me.
But there are lots of neat bikes that can take wide tires now, and I'm probably a lot older than you, so really like the wider comfort thing.
And wider and low pressures works pretty good for different terrain, within reason and to a certain extent anyway.
#1740
Quoted: 130 Post(s)
Liked 445 Times
Cool, Ghent is maybe the best city to spend some time in on tour. We're a small country, invaded by everybody with a half decent army, so we speak our foreign languages.
And oddly enough, it's only about 60kms from Paschendale where my grandfather left a leg back in 1917......weird eh? nearly 30 years apart, thousands and thousands of kms from Canada and the two brothers go through all that ugliness in almost the same place in Belgium....but at least my grandfather came back.
cheers
#1742
Quoted: 130 Post(s)
Liked 445 Times
It's less weird (but just as sad) when you think of it as one war with a pause in between, as some historians suggest.
Quoted: 6000 Post(s)
Liked 956 Times
I agree. Bruges might be prettier but it has a bit of the same issue as Venice, that the ratio between tourists and inhabitants takes the soul out of the City. Ghen it much more a real living city while it also has really old stuff and canals.
#1744
Liked 956 Times
It was a bit sarcastic for good humour, but if English can lighten up the language issue a bit I'd genuinely like that. I didn't want to make it heavy either but I notice from your reaction it still is. For me it's just something that is particular to and interesting about Belgium, which is very dear to me. .
Likes For str:
