Show Your Road Racing Iron
#151
Quoted: 2588 Post(s)
Liked 4,824 Times
DD
Likes For ctak:
#153
Liked 4,824 Times
Your Mitchell turned out beautifully, and the blue highlights really make it pop!
DD
#154
Liked 4,824 Times
You're absolutely right - a little background info adds to the mix; I certainly like the added commentary by others. Think I'll go back and add some info to my posts later today...
DD
DD
#155
Liked 4,824 Times
Drillium Dude I trust you recognized the drillium work on the Masi rings?
DD
Likes For Drillium Dude:
#156
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,613 Times
Another Bontekoe, this time with a frame made by Locomotief. Late forties or early fifties.
Very similar - if not the same frame - to what was ridden to the team victory in the 1953 Tour de France, albeit with a little less chrome:
Likes For non-fixie:
#157
Señor Member
Quoted: 284 Post(s)
Liked 299 Times
First two are now disassembled with framesets hanging on a peg, since I barely have time to ride one race-configured bike.
It's mostly low and slow for me these days.
1981 SR Pro
1984 Vicini Tour de France
1987(?) Pinarello Montello
The bikes may change but the garage door remains the same.
1981 SR Pro
Likes For CO_Hoya:
#158
Liked 4,824 Times
Medici has a storied (some say sordid) past. I love the way my Medici Pro Strada rides - fast or slow. Acquired from the original owner (who bought it brand new as a frame/fork in early 1980), it's an early frame, probably built in '78 or '79. He didn't ride it much over the years, and as he got older he modified the bar setup in a quasi-Grant Petersen style and added a forward-slanting seatpost to achieve a better fit - which he never really dialed in. Originally outfitted with Zeus 2000 components, I ran it that way (albeit with a standard Cinelli bar/stem combination with normal drop) for a year, then converted it to Campy NR/SR mix, as is pretty much my gold standard. The bike simply does everything just right. My choice if the road conditions are good and I want to ride in relative comfort all day long. Plus it's red
As found (for sale ad photo):
Today:
DD
Today:
DD
#159
Quoted: 4513 Post(s)
Liked 6,389 Times
#160
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Wow! Quite the thread! Gorgeous equipment.
I won't show my Schwinn, since it is a racing mountain bike. No eyelets, so I had to affix the rear rack with P-clips.
My Bianchi:
Apologies to die-hard Celeste fans, but at least I was able to find a Celeste-colored Bianchi water bottle.
My Bianchi:
Likes For John E:
#161
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 377 Post(s)
Liked 1,089 Times
I started writing about that there are some bikes in this thread - none mentioned, none forgotten... that... does not...etc.!
But lets keep this fun and happy. I am just an grumpy old elitist guy - and who should/would really have the right to throw the first stone...!? I am of course perfect in all sorts of ways...
But back to the above Colnago... It has it all. It ticks all the boxes.
Buuuuutttttt.... It just has to be the photo perspective that makes the bars look a smidge bit over rotated!? I can not belive the lower part of the bars not being parallell to the ground!? Please tell me it is the photo!
Much to my disdain - we also have to talk about the valve stems. I guess DD has not fully understood the importance of my post (in which I was called a psychopath):
https://www.bikeforums.net/classic-v...-problems.html
And what about the exact distance between the three rear brake lining/cable holders...! This is no easy matter - I guess they are at least 10-15 millimeter off. Let me know! This might hinder my sleep tonight.
If not for these three things I would be happy to replace the picture of Tullio in my shrine with DD: s Colnago Super. (1973?) And a pic of DD!
With utmost seriousness and alkohol induced OCD - yours styggno1. (you know I love your bikes)
Edit. In an attempt to mitigate what might come - I present to you:
The missing stepped ferrule! A debacle that still makes my stomach turn.
PS. I hope you do understand that I do this for a greater good. I also hope that you would do the same for me. Love your work. Johan
Likes For styggno1:
Likes For El Chaba:
#163
Liked 4,824 Times
The bars are indeed parallel to the ground; what you're seeing is the front end ever-so-slightly turned to the right - note that the stem also appears to have a slight downward-sloping angle (it doesn't) as a result. The headset on this was NOS and perfectly adjusted; no matter what I leaned the bike against, it would never stay completely straight, always turning that smidge away from whatever the bar was resting against.
As for the excessively-long valve stems, I didn't trust myself to cut them down as you did (I remembered that thread), and if I'm honest, I kinda liked them in the original length as they are old-school brass - the tubes were original and very old (but still functional) and came with an old wheelset I found a long time ago.
Finally, the cable clips: it's true, they are NOT equidistant, but you have to have a sharp eye to see it! One is off by about 1/4"; I noted it during the build, but decided not to take the chance of scratching the paint trying to rectify the problem and left it as is. Used to bug the piss out of me, but I learned to finally live with it. And since the bike was sold last year, it's now the new owner's problem
No worries - I totally get where you're coming from and I don't take any of these "criticisms" personally, especially when it's obvious they aren't offered with malice. It's all good!
DD
#164
Liked 4,824 Times
#166
Quoted: 1609 Post(s)
Liked 2,216 Times
Everything you might want to know about this bike is here. It is a frame up build and my most expensive bike. It is my goto bike as well, when I am in shape. Lots of pics recently on here so I picked a pic that hasn't been used here and may not be the best.
I believe now that it is about a 1988 Pro.
None of my bikes are a pristine as so many in this thread. My budget during acquisition was tight and I don't get support in the house. They work, they show use and they are great rides. The red on this one nearly hides the imperfections.
P1050282 on Flickr
P1050282 on Flickr
Likes For SJX426:
#167
Steel is real
Quoted: 377 Post(s)
Liked 1,089 Times
I would love to find a Pro. I know of some in Sweden but they are "taken".
PS. Today all these brands are owned by the Swedish Cycleurope company. I have met the owner, Salvatori Grimaldi personally at more than one occasion and he is a nice guy. Italian - but has been living in Sweden since young and he is nice and knowledgable... As many of the guys and gals at that level of success they have a very short attention span. We connected because of multiple interests - vintage bicycles, vintage watches, vintage boats, etc.
Today his sons has taken over and I know nothing of what is going on. But on the other hand - I am not interested in modern bikes. At all.
Likes For styggno1:
#168
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Perfect for that bike. Another example of how the French were not about to give up on centerpulls without a fight. Does this bike still have its Dogwood reinforcement in the bottom of the fork column….and is the bottom bracket stamped with Simon’s name? …They often did that, but not always…These were very special bikes, and as you mentioned in your original post they ride beautifully. I searched for one in my size in good condition for about thirty years.
Only other marking is on the fork steerer .
Likes For 1simplexnut:
#169
Liked 6,389 Times
#170
Liked 4,824 Times
My chronometer currently reads 1507, giving us an 8-hour time difference.
DD
DD
#171
Liked 4,824 Times
It is sad, however, to hear about the "lack of support"; I'm sure more than a few folks hanging out on BF have that issue, too. C'est la vie...
DD
Likes For styggno1:
#173
Liked 4,824 Times
If it's French and vintage, I'm gonna assume it's Delrin
DD
DD
#174
Quoted: 3015 Post(s)
Liked 3,805 Times
Likes For iab:
#175
Bikes: Road: 1972 Raleigh Competition,1989 Marinoni, 1990 Limongi. MTN: 1990 GT Team Avalanche, 1991 Rocky Mountain Blizzard, GT Team RTS , Rocky Mountain MSL 50 Element, CCM fat bike
Quoted: 35 Post(s)
Liked 81 Times
Tight tire clearance makes bikes fast.
25 width tires just fit.
Limongi SLX frame, about 1991
Likes For Paul Waque:
