Negative chain stretch?
Quoted: 6196 Post(s)
Liked 4,811 Times
Well don't do like the video and measure the bottom run of chain. Measure the top run and have some tension on the chain when you do it.
And of course a good quality picture of you measuring it will help us understand what you are seeing. Just make certain we can see the 0 and 12 inch mark clearly in the same photo and what they are measuring.
Likes For njkayaker:
I also measured the top and saw the same thing, no change at all. I'll see what I can do about that and close ups to show condition.
I can't coast even if I badly wanted to. I don't use the zero resistance GP5000 tires, I have full fenders, touring tires, 32 spoke wheels, bags all the time. My kit has more resistance than the French Resistance back in WW2.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I did the same as the video below. I see if I can take a snapshot in a day or two. You'll be impressed with the chain's condition.
https://www.youtube.com/watch?v=5okJdYrANt8
So far as I know, there's no such thing as "negative stretch" so it's much more likely that the explanation is you're measuring it incorrectly. Do you seriously think that the chain is getting smaller after being put on your bike? Maybe you shouldn't stick your bike in the freezer before measuring it.
Tragically Ignorant
Liked 9,098 Times
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
Likes For mstateglfr:
Sunshine
Liked 7,495 Times
Quoted: 6972 Post(s)
Liked 10,971 Times
Likes For Koyote:
Quoted: 18424 Post(s)
Liked 15,581 Times
Likes For indyfabz:
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Is this the bike with the shrunken chain?
Likes For shelbyfv:
Quoted: 9656 Post(s)
Liked 6,366 Times
I'd wear cammo too if I had to ride that thing.
Is that a lead acid battery strapped to the rear rack? I guess it helps with wheel slip on the extreme climbs.
Likes For Mojo31:
Liked 10,971 Times
And if I didn't have another bike, I'd walk.
Likes For Koyote:
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
Then it's clearly and issue of insufficient guadpower.
Liked 6,366 Times
Likes For Mojo31:
Did your rapidly spinning chain trigger a reaction in a maladjusted dog causing him to bite a few links off? Considering all of your posts together that is the most likely explanation.
Likes For Dominae:
Liked 6,366 Times
Don't forget the meat sweats.
