Birdy thread
#526
Very feasible, but you will need something to keep the chain in tension, which means either a dedicated chain tensioner -- there exists an Alfine version -- or you can repurpose the existing derailleur for the job via limit screws or a short piece of cable from the adjuster stop through the cable clamp.
#528
On a regular non-folding bike, there's usually a way to adjust chain tension on a single speed or IGH hub, whether just horizontal dropouts, eccentric BB, or other mechanical tensioning system. So first off, the Birdy has vertical dropouts at the rear, no adjustment possible. Second, the chain line length changes when folded, so even if you did come up with a "magic ratio" which had the chain in tension enough to be serviceable, it would probably get out of whack when folded.
But again, no reason you couldn't just repurpose your existing derailleur to do the same thing, and it would allow you to keep the chain-catch gizmo as well.
#531
Hi
I just received my Birdy City Premium after a 10 weeks order, and after about 2 minuets of riding I can hear an annoying creaking sound from the front end of the bike (WHEEL?).
The creaking sound seems to happen after a few minutes of a new ride and will still be there even after stopping and pressing down on the handle bars.
Whats strange is when I took the bike out the next day there were no creaking sound at the beginning but after a few minuets it returns.
It does not seems to be from the handle bars or front Elastomer Suspension.
Could it be the head set or something with the fold device or even the front wheel.
The last thing I want to do is send it back and wait x amount of weeks for a repair/replacement.
Any help would be great
#532
Quoted: 321 Post(s)
Liked 7 Times
The front fork hinge.Spray some WD-40 at individual spots, ride, until you have the culprit which would hopefully be quiet at some point. Could also be the headset.
#533
Bikes: 2010 Mezzo I-4
Birdy's
I'm not certain if I'd sell my Mezzo if a frog became available or if I'd rather have my Mezzo + Birdy . .
Is Frog talk welcome in the Birdy Thread? Are they available anywhere in the US?
#535
Bikes: 2X dualdrive Mezzo folder,plus others
Quoted: 107 Post(s)
Just got another used birdie that needs building up.
This one has a seat-post clamp that looks like a handlebar stem for 25mm bars. does this mean there is a clamp for the seat with a bar fitting?
If so where do I get this?
#536
Some photos might help, what model or year is this birdie?
#537
Quoted: 107 Post(s)
Hi manged to get the part for the seat-post mentioned ealier.
Does anyone know of a source for, (preferably cheap) chain devices suitable for a birdie instead of using the easily bent cage?
By chain device, I mean a front chain wheel chain catcher for the folding chaain slack like the mezzo one. Must find out cost of a mezzo one.
I know a birdie one exists from these threads but this one was 150 pounds when I looked in to it.
#539
Bikes: Birdy Yellow 8 speed, Birdy Monocque Rohloff 14 speed
Bfold is the US east coast dealer as stated in the manufacture Pacific Cycles web site:
Pacific Cycles
#540
#543
Bikes: Birdy Red 8 speed, Birdy Blue 21 Speed, Birdy Monocoque 24 Speed, 2002 Devinci Desperado, 1996 Rocky Mountain Hammer Race
If you're on/closer to the west coast, then Urban Bike Fitters is the new kid on the block. Now, I just need them to keep Birdy's for the next year or two, so I can afford one.
Warm Planet Bikes still has the old 2010, you can make a deal on, according to their sites stock list.
#545
Bikes: 2014 Birdy Disc Polished Silver 9sp; 2013 Downtube Nova; 2008 Specialized Sequoia Elite
Try www.bfold.com
Pacific Cycles
Pacific Cycles
#546
Factory Birdy Pump SKS: Birdy Pump SKS
Does anyone know if the pump works on Presta or Schrader valve? Above web site does not give any product details.
#547
Bikes: Fully customized 11-spd MTB built on 2014 Santa Cruz 5010 frame; Brompton S2E-X 2014; Brompton M3E 2014
Quoted: 17 Post(s)
Can anyone tell me what is the biggest wheel one can fit to a non-modified Birdy? Is 355s pretty much the limit?
#549
some photos
**********? - <??>Birdy??20???~ - ********** - Mobile01
#550
Quoted: 17 Post(s)
