Addiction 2021.3
#6001
Administrator
Quoted: 11972 Post(s)
Liked 6,655 Times
The announcement will be made from Velo Vol world headquarters, but the exact time will not be disclosed.
#6002
VFL For Life
Bikes: Velo Volmobile
Quoted: 28622 Post(s)
Liked 1,858 Times
#6003
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,531 Times
#6004
VFL For Life
Liked 1,858 Times
#6005
Quoted: 10238 Post(s)
Liked 5,185 Times
Benefits of Di2 over sram etap?
Looking like new bike coming soon.
Originally planned on a madone project one. Wanted the benefit of buying local, but the madone is kinda of ugly.
First pick is the wilier filante slr with the zero in close second. On the wilier main site it advertises that you can get it with sram force 2x12 but on the usa site it only comes Di2. Price is similar but I would prefer the added power meter and I don’t really want cables. Looks like it would be a huge pain if an issue ever arose.
Caldonia 5 is a close contender if the wilier grows to costly.
BMC is also a possibility and I could buy that local, but the color is horrible, and after the fork recall I am a little turned off.
Still just in planning stage. Reached out to adrenalinebikes about the wilier build. Informed me they get the bike from wilier usa. Adrenaline says I can build it anyway I like but I’m a little confused on how that would work. I would want the original cockpit and wheels from wilier but just switch out the drive train. Not sure if they would do that or if that would increase the cost more than the 4 grand the sram force package already cost.
#6006
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
Likes For LesterOfPuppets:
#6007
Bikes: everywhere
Liked 7,695 Times
Lake Minnetonka update:
OMG, that's way too many trash pandas.
#6008
VFL For Life
Liked 1,858 Times
#6009
Bikes: everywhere
Liked 7,695 Times
You should put forth a motion to reduce the number of TN counties. Use TDOTs regions, maybe.
#6010
Bikes: everywhere
Liked 7,695 Times
I guess I worked in the boondocks in Vancouver, USA, with this being right down the road ...
#6011
VFL For Life
Liked 1,858 Times
No. Our counties are the proper size. One should be able to ride across a county on one water bottle, max.
#6012
VFL For Life
Liked 1,858 Times
#6013
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Interesting experience on today's ride. Recall I still run Ultegra 6700 on my bikes. Also recall that the exposed parts of the shifters are notorious for rusting, and there is a bit of rust on mine.
When I started the ride, my inner paddle (to shift to a smaller cog in back) would sometimes just move but not shift, and sometimes would "catch" and shift properly. Oh crap. The outer shifter would shift crisply to the bigger cogs nice and crisply. So I am pretty sure the problem is NOT a fraying cable or a cable problem at all, but something in the shifter mechanism that is not engaging properly. I am not enough of an expert on the shifter innards/mechanism to make a definite diagnosis. Luckily, as the ride progressed, the weak "catch" or inability to shift at all became less frequent, and within 15 minutes it was working fine.
My suspicion is that whatever ratchet or other gizmo inside the shifter may have gotten stuck due to rust and lack of use (this is my first ride on the bike in 2 weeks), but I am torn whether to just leave it alone versus spray a bunch of WD40 and/or lube up into the mechanism to help clear out whatever the cause was.
Suggestions???
Suggestions???
#6014
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
One of the great mysteries of the english speaking world: Spelling of the word, "lose."
Keep the chain tight!
Likes For Trsnrtr:
#6015
Quoted: 20810 Post(s)
Liked 9,456 Times
Once installed, I would think that the issue of wireless vs wired is pretty much moot. Since they'd be installing, that's more their problem than yours, anyway. Well, unless you don't get the fit right and you need to swap bars/stem down the line (but the hydro lines are going to make that a pain in the ass either way).
Power meters are wonderful, but you can add that any time, so I wouldn't let that be a major factor. More like a cherry on top.
#6016
Super Modest
Liked 4,620 Times
What bothers me about new high-end bikes is the use of so many proprietary parts like integrated seat posts and stems. Also, the industry needs to standardize thru-axles.
#6017
Administrator
Liked 6,655 Times
Oh Lawd. smh
#6018
VFL For Life
Liked 1,858 Times
#6019
Quoted: 18422 Post(s)
Liked 15,571 Times
#6020
Liked 5,185 Times
If given the choice, I'd go Shimano over SRAM, at least if we're talking hydro. Wireless would be nice, but I'm more leery of SRAM brakes. Part of that may be my familiarity with Shimano and ignorance of SRAM, but I like the idea of mineral oil vs DOT and even SRAM fans like psimet talk about the shortcomings of maintaining their brakes. There's a thread on the front page right now, I think.
Mute point if the wilier only comes Di2. I really don’t want any cables visible if I am going to spend that much money.
#6021
VFL For Life
Liked 1,858 Times
#6022
Liked 15,571 Times
Likes For indyfabz:
#6023
Liked 15,571 Times
Shoes with recessed SPD cleats are not optimal for stomping lantern flies. Still, I managed to kill a couple dozen across the street from my building this morning.
Likes For indyfabz:
#6024
Liked 9,456 Times
The cables should only be visible where they come out of the frame, right next to the derailleurs. The front should all still be tidy and cable-free.
#6025
Mostly Harmless
Liked 4,531 Times
