1950s Mercian - Help Needed
It is possible that a number of the braze-on fittings were made by Roy Mitchell as they look similar to the ones on my EA Boult of 1952.
David Orr has described this and the Pennine CO2 pump at https://www.classiclightweights.co.u...may-june-2009/ and scroll halfway down.
Dave also wrote about his bike and the fittings in the thread I did when I became the custodian of his EA Boult.
https://www.bicycles.net.au/forums/v...rt=25#p1365638
As it was from the same period as your father's bike purchase, it might help you better appreciate that period.
and like your frame, the braze-on for the CO2 pump needed the Terry pump clip.
So I made some https://www.bicycles.net.au/forums/v...rt=50#p1383821
Let me know if you want one posted.
Likes For Big Block:
Thank you for the info. Much appreciated. I may get back to you on the clip but I need to have a good root in my dad's loft first to see if they are any other parts up there.
Likes For Aintright:
Quoted: 3824 Post(s)
Liked 3,374 Times
Likes For juvela:
He has another frame up there, a Dawes, and it has some parts on it. Not sure what they are yet. His house is up in the North East and I'm in Lancashire. I'm next up ther in a couple of weeks. In the meantime, I'm just giving the frame a good clean and a light wire-wooling for now. Once I know what bits I've got, I'm going to speak to Mercian and come up with a plan.
Liked 3,374 Times
"light wire wooling" :
Quoted: 981 Post(s)
Liked 1,844 Times
Wire wool will strip the old clear coat (and eventually the actual paint and transfers) right off of a frame that old. You may have to barely touch it in some places to damage the finish. Anything that can come off that isn't paint should come off with regular cleaning materials suitable for automotive paint cleaning. Would you ever wire wool your car?
-Gregory
-Gregory
Likes For Kilroy1988:
Hi. Honestly, I am being really careful. I'm not going near the decals or badges or anywhere where the paint is in decent nick, which is most of the bike. I'm using 0000 grade really gently and just where there is some corrosion and flaking paint where the inside of the rear forks meet the bottom bracket and on the underside of the bottom bracket itself. A lot of the original clear coat is already missing on the underside of the bike and on the lower half of the down tube so I may get it redone. Not sure yet. Other folk are suggesting I just Owltrol it or get it treated with something similar. I'm going to take it to Mercian as soon as I get a chance and maybe just hand it over to them as it needs a new headset and I don't want to try removing the bit still attached to the frame. It also needs a bottom bracket refurb. The outer faces are in excellent nick but the axle grates in the bearings a bit.
Liked 3,374 Times
"eetsa you bici"
"finish only original once"
"eetsa you bici"
