Training Status??? (IV)
#4476
Yeah, I hit a roofing nail once. That was... dramatic.
#4477
Quoted: 17 Post(s)
1.5 hrs with 30' SST
question for the bike fitters: if I move my saddle forward, how much should i (or maybe I don't) raise the saddle? I've been experimenting with my hip angle and read that one way to open up your hip angle (while still keeping low) is to move the saddle forward and lower your handlebars similiar to a TT setup.
#4478
Bikes: Tarmac SL4
Trainerroad Bondcliff which is 4 15minutes intervals @ 88% with a 30 second hard start at the beginning. Before the kickr I would have never finished this workout.
#4479
Did 4x10' at 100% (2 min RI). It hurt, I need to get a lot better at these longer sustained intervals (greater than 5-7 min).
#4480
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
#4481
You can actually accomplish a lot if you are consistent and put some intent into your rides. Due to a move east from NorCal and a the demands of my new job, I've had to adjust my training a lot. I've had surprisingly good results from using TrainerRoad and my kicker for the vast majority of my workouts this winter. The weekday workouts are only 60-75 min for the most part with longer on the weekends yet I've managed to get my FTP back to pretty much where it was before my life took a left turn.
#4482
Quoted: 79 Post(s)
Liked 153 Times
Just curious, did you use a particular canned plan from trainerroad or just picked from whatever shorter intensity sessions they have? i'm also considering doing a 6 week ftp plan on zwift, as all those workouts are short duration. if i can get back to where I was ftp wise i'd be pretty happy, and then I could use the summer to just do more volume.
#4484
Did some sprints yesterday. Finally got my 5 sec W/kg above the 'untrained' category.
I still feel like my (poor) technique is holding me up more than my strength.
#4486
Quoted: 17 Post(s)
Before you move your seat forward measure from the tip of the saddle to the center of the bb. Do it twice. Three times. Record this number. That is the distance you need saddle to bb, to achieve your current leg extension. When transferring my saddle height measurements from my old bike I used one of those ID badge metal bead lanyards and measured length to the closest bead. I found it easier to use than a tape measure because you can hook the beads onto ridges on the bottom bracket and the seat. This worked perfectly even though my setup has me much farther behind the bottom bracket than I was on my old frame.
#4487
1:55 on the rollers with 3*20' (271w, 256w, 261w). legs were pretty tired going into it and are now more tired.
if 4*10' at 100% is that hard wouldn't that indicate your ftp is too high?
#4488
Only if you fail to hit the zone. The first two shouldn't be hard, but it's 40 minutes at threshold. Not easy. I've been stepping up this block, 4x10 the first week, 4x12 the next, now staring down the barrel of 4x15. It was hard at every length so far. 4x15 is gonna be rough as hell.
#4489
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
I've made a couple of very small changes to my fit that seem to have at least made riding a little more comfortable.
Last week I did like one interval the whole 5 day rest period but it was the type that has you sitting on the nose of the saddle, and I hit a bump while doing 40ish and the bolt decided that its written torque settings were incorrect and so the saddle pointed itself at the bottom bracket. I didn't have seat angle recorded anywhere so I wound up playing around with it for a couple of days until I hit what felt right. What felt right is actually almost perfectly level, before that my saddle was angled slightly more downward, but I'm definitely producing more power on flat ground and it seems easier to remain in the saddle and produce power uphill.
I also had to change my cleats so I put a small shim underneath my left cleat (I've been ignoring a very very small leg length difference) and it *seems* to have flattened out my power production. As in, instead of 3s avg reading 230 / 250 / 230 / 250 it's more along the lines of 250 across the board.
Of course this may just be the results of having come off a rest week after putting in a **** ton of build work. I'll see how it holds up in the next few weeks.
#4490
getting back to basics, did a 2x8 minute test on trainerroad, avg 271 for both, so ftp is 244 (I had guesstimated 240 based on recent performances). probably going to stick with the sweet spot base mid volume (6hr/week) program for now. only goal is to get back to 260, the bar is low for me lol
#4491
Quoted: 417 Post(s)
"Race ride" last night. Surprisingly huge group last night (50-60?). Fun ride. Good workout.
I your ride on the strava ... do you just end up staying way late at work to get a ride like this in or just take a shorter day?
#4492
Normally I wouldn't get to work so late after 3.5 hours (working by 10), but I started a bit late and stopped for coffee. Oh well, I worked late the day before. I like working 10 to 6 give or take. I want to move to the city so I can work past six without getting home crazy late. But $3000 is a lot of money for a studio apartment!
#4493
Quoted: 417 Post(s)
The SF housing market is absurdly steep. That rent is more than 2x my mortgage, but I pay for it with ridiculously hot summers. I'm not too tuned into the bay area market anymore, but I assume south bay is pretty pricey as well?
#4494
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
Gotcha. That's a pretty nice route into the office.
#4496
decided to be a masochist today, after doing the trainerroad ftp test, i did a zwift race to test my newly set ftp. avg 232 (95%) over 50mins. seems about right...
#4498
#4500
I was right. Holy hell, that was grim. I was legit unsure I would even be able to do this in the trainer. As it was, I was at the very bottom of the zone. Assuming 10% power loss on the trainer, though... That's right on target. I really had to push through some serious RPE to close out that last interval. Was pretty proud of myself when I did, though. Thank goodness I can ride outside tomorrow.
