For the love of English 3 speeds...
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
The chain case for the 26 inch Sports-style frame was different from the 28 inch or DL-1 chain case. The DL-1 case was designed with removable seat stays in mind because the DL-1 seat stays can be unbolted.
The Dawn/Sports style chain case was designed with fixed/brazed seat stays in mind, and slipped over those stationary seat stays. If you need to buy a chain case, make sure you get the one that suits your frame.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Quoted: 478 Post(s)
Liked 634 Times
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Good Deal
Here's a bike on Toronto Kijiji. Raleigh Laurentian. Price, FREE!
It's in the east end of the city so I'll pass but looks to be the basis of a good project.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
If that Raleigh Laurentian was a 23in I would be begging you to try and facilitate it for me.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
That's not so nice!
Spent 2 hours pulling the 52 apart. A real mess. Salient points. It has a braze on pulley mount even though it used a band clamp. First time I've actually seen a bolt in the full chainguard mount. CPSC should have implemented the Raleigh wheel retention system if any. I like it. Everything came apart (except fixed cup of course) but it all needs a good bath in OA. The rims may not be salvageable. Oh yes, under artificial basement light, it really looks green, in the daylight it's sea-blue. I've had two Humbers that never had this hue.
Liked 443 Times
That's not so nice!
doesn't locate properly. I suspect that there's a special nut required with a male spigot that should be used. Anyone have any info?
On the road
Quoted: 373 Post(s)
Liked 857 Times
The recessed fork was dropped at some point in the 1960s. I have a '58 with the recessed fork and original wheel with original front nuts. The correct front nuts for that are shouldered rather than plain. The shoulder slips into drop-out and the nut itself goes into the recess. One of clubman's photos shows the shouldered nuts.
Liked 443 Times
Phyllo-buster
Liked 2,055 Times
gster, I'm quite sure I have a pair of those nuts. I had a look but my shop is a mess but if I find them I'll let you know. In addition to Mikes info, an important part of the retention is the large washers that also slip over the shoulder. The depth of these washers is critical to a tight fit.
Question for y'all. There's another shouldered front axle setup where the lip/shoulder is on the cone and the recess is on the inside of the forks. When was that in use?
Liked 443 Times
[QUOTE=clubman;19298415]
I would certainly appreciate that and could offer something in trade. Most of my bikes have the inner recess.
Quoted: 3811 Post(s)
Liked 6,713 Times
I don't usually post CL ads here, but this later model 23" Sports in white for $100 seems like a good find:
Raleigh bicycle
00I0I_5NMYoVBZGNP_1200x900
Raleigh bicycle
Quoted: 1299 Post(s)
Liked 103 Times
Raleigh bicycle
Raleigh bicycle
Inflate Hard
Inflate Hard
Liked 103 Times
I brought the roadster with me to southern Florida instead of my Sprite this year. This bike just works for me somehow. Very fun on the unpaved, hilly roads up north, but geared a bit low for the flat paved roads here. My Sports bikes all have the earlier 48T chainwheels. This 72 roadster has a 46T, so it's 46x22. If I lived here I'd use a 19T or 20T cog. I do miss the medium ratio spread of the S5, but I'm still having fun with my latest project.
Inflate Hard
Inflate Hard
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
My Humber Sports are early 50s and not set up that way. My '62 Raleigh is. My '72 Superbe is not and its a lot harder to remove the wheel.
Phyllo-buster
Liked 2,055 Times
Thanks, gotta check my 57.
Liked 103 Times
The later Raleighs went way overboard with wheel retention. The forks can be so tight that you need either three hands, a fork spreader or a mallet to hit the axle to get the wheel off. Plenty of bikes have forks that clear the front hub OLD without fork spreading and I've never had the wheel fall off one yet. I would much rather snug the axle nuts from time to time than have a wheel that couldn't be removed on the road.
Inflate Hard
Inflate Hard
Quoted: 478 Post(s)
Liked 634 Times
Phyllo-buster
Liked 2,055 Times
Just thought I'd show the copper plating on the 52 SA trigger. I've seen brass before but this is new to me. The rust was hiding the patina.
Bike Doctor
Bikes: Norco Cape Cod tandem, KHS Tandemania Cross, 1952 Claud Butler ladyback tandem, 1971 & '73 Raleigh Suberbes, 1985 Gazelle Sport Solide, 1985 Rossi professional
Quoted: 58 Post(s)
Liked 52 Times
Then I'll mail em back to you when I'm done.
Liked 443 Times
Bring a pair of hex nuts to the Brantford bike show next month and I'll be happy to machine the shoulders if you can tell me the diameter and depth of the shoulder. Perhaps someone on here can measure factory nuts and forward the sizes to one of us.
Phyllo-buster
Liked 2,055 Times
Bike Doctor
Quoted: 58 Post(s)
Liked 52 Times
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Nonsense. While rusty it is not rusted away. Use OA to remove as much rust as you can, clearcoat whatever is left and put it back together. The bike has too much character, unless you just need the parts for a different bike. You've already done the hard work.
Quoted: 887 Post(s)
Liked 335 Times
A 1966 Raleigh Sports of some kind I guess. I've not seen this head badge style myself before. Overall it is in a bad way. I like the Raleigh motif on the frame tube ends and wheel and cotter pin nuts, grip-shift for the SA AW gears and dynamo with working lights. I've rebuilt the wheels and they've cleaned up surprising well and both are fully functional with Made in England Dunlop tubes and Michelin "Roadster" tyres. Sadly, I think the frame and most other parts are beyond repair, at least for me.
Quoted: 7349 Post(s)
Liked 2,474 Times
I always knew that this is possible, but I'd never seen it until now.
