Show us your Cinelli! Lots of pics! :)
#226
The paint appears to not be original, but not sure.
Bottom bracket with serial number.
Dropouts.
Rear brake bridge
Braze-on cable guide. Three dot painted lugs.
Three dot lugs.
Seat post clamp area.
Sticker head tube badge.
Hello, I need some help in identifying my frame. I was originally thinking that it was of unknown origins with a Cinelli bottom bracket, but I recently noticed that it has a Cinelli stamped brake bridge. Can someone help me with identifying the make, model, and approximate year of the frame? Any help is greatly appreciated.
Likes For Silver02M5:
#227
Quoted: 3513 Post(s)
Liked 2,927 Times
I don't know enough about earlier Cinellis but that second set of water bottle braze-ons seems highly unusual, and the braze-ons themselves look different. Early versions of my 1989 vintage didn't even have them. This might help explain the repaint. The "Flying C" logo is from 1979; New lugs without the holes were designed in 1982, the same year the sloping fork crown got the logo. I'm guessing that the serial number indicates it's from 1983, perhaps using up older lug stock.
Likes For smd4:
#228
Quoted: 3464 Post(s)
Liked 2,831 Times
#229
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Dropouts.
Rear brake bridge
Three dot lugs.
Here is a prior BF discussion of Cinelli serial numbers, which has a bunch of good info. In post #2, iab lists the two best resources for dating Cinellis, especially the link to Velo Retro's Cinelli timeline. These resources will tell you a lot.
If yours is a 1983 Cinelli, that would be about five years after Cino Cinelli sold the company and about three years after master builder Luigi Valsasina retired. That also appears to be the yeat they went from a 26.2mm seat post diameter to 27.2mm
Here is what Sheldon Brown had to say about this era of Cinellis:
Around 1978 Cinelli was sold to the Columbo family. There are bikes with either the new or old logo's from this period. Until about 1980, while the graphics could go either way, the brake bridges and bottom bracket shells had new Cinelli logs making these bikes recognizable. Headbadge examples are worth more, perhaps $1,600, although modern logo bikes from the same period are just as good. From around 1980 until perhaps 1981 or 1982, Cinelli bikes with the new logo using a 26.2 seatpost and the lugs with 3 holes in each were very nice. Many do not consider these to be "real" Cinelli bikes, but they are at least as good as many of the earlier ones. Apparently either some very good builders from the previous period continued on, or work was contracted to outside builders of considerable talent. These bikes from this period deserve to be classics in their own right. Their geometry is upright, yet the ride is comfortable. These are bikes designed for the fast short distance riding so common in the United States. They, nonetheless, will handle mountain descents with ease as well! These bikes are worth perhaps $1,500 and are worth every penny and then some.
Sometime around 1983 it all ended. The 26.2 sleeved seat lug was replaced wit a different cast model that used a 27.2 post. The familiar 3 hole lugs were gone as well. Quality during the following years took a pretty heavy hit as well. Many examples didn't even have chrome lugs. These examples in S.R. are worth about $800. By the late 80's quality improved and chrome lugs returned. It just, however, isn't the same.
Here's the link to St. Sheldon's Cinelli comments. The article is at least 20 years old, so take the dollar figures with a grain of salt, but the general comments are still valid. Yes, it's one man's opinion, but it is one the most well-informed opinions you will find. Beware - even though he died - what is it? 10 years ago? 15? - his website is still a fantastic reference for all manner of bike info and it is easy to spend an hour or six rummaging through it.Welcome to the Cinelli
Likes For bikingshearer:
#230
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
it is a Cinelli, built in the Columbo shop, serial number dates it to 1983. Unusual color.
The lack of chrome points to a possible repaint.
/markp
/markp
Likes For mpetry912:
#231
It's as pointed out above, a 1983 Cinelli, certainly repainted and second, non matching, water bottle bosses added. Wong decals applied for for 1983, but it's a real Cinelli.
#232
Liked 2,927 Times
#233
Liked 2,531 Times
Here is the same silver 1965ish 64cm Cinelli from Post #143, with the new Ed Litton fork. I also changed the wheels from Chorus to Record 10sp hubs (still on Mavic Open Pro rims, but all-silver in a nod to repechage's sensibilities and, truth be told, my preference), the cassette and chain, the headset, the brakes (same mismatched Tektros, just newer and shinier), and the left ergo shifter because the old one decided it would shift onto the big chainwheel but not stay there. Except for the left ergos shifter, none of the swaps were strictly necessary and did not effect much if any change to the bike, but since I had to strip it down to frame and fork anyway and I had the parts, what the heck. There isn't a single original part on it with the possible exception of the seat post bolt and precious few period-correct parts. But it rode great on the shake-down cruise, and I have no doubt it is back to being the bike I reach for a significant majority of the time.
#234
Quoted: 3015 Post(s)
Liked 3,804 Times
Likes For iab:
#235
Quoted: 554 Post(s)
Liked 3,794 Times
#236
Liked 3,804 Times
Generic. I use a forum guy, Psimet Wheels. My ask was silver, 32 holes, 3 cross and Ekar compatible. He sources everything. They ain't light like my off-topic carbon wheels, but they ain't bad either. I wanted a silver build and it is not easy. I ditched the Ekar crank for eeWings from Cane Creek. I know a guy there and got them on the cheap. Got an Ekar-compatible ring out of the UK. Had to strip the black anodizing. Ritchey for the rest.
The color is called Sugar Paper. "Semi-custom". I thought it was the prettiest one Cinelli offered.
Likes For iab:
#237
Liked 3,804 Times
It is taking the place of Pinky. I call it New Pinky. Pinky will be at the Madison swap for those interested.
Umberto Dei 01 by iabisdb, on Flickr
Likes For iab:
#238
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 166 Post(s)
Liked 348 Times
Likes For Rooney:
Spaghetti Legs
Classic and Vintage Sales
3
01-05-18 06:43 PM
Andy_K
Classic & Vintage
57
10-03-17 11:08 PM
