Addiction 2022.3
#7051
If making the do-up tight as possible is a solution, but hard to get undone, think about getting a piece of plastic plumbing tubing about six inches in length that will fit over the lever. Carry it in whatever bag you use with your other repair kit.
And yes, I have had one or two problems, the most memorable on my old Fuji Touring that was steel framed and broke the right-hand drop-out on the rear when blown over before the start of a 400km event. It made the event through to the end without me really knowing, except some strange gear shifting issues. I welded it back together, not perfectly, but well enough to have lasted a decade since. A few little issues rose, one of them requiring the horizontal drop-out slot (almost unheard of these days) to be bent back carefully to have parallel status again the one of the left.
So, if your bike has fallen over for some reason, have the parallel nature of the drop-outs been checked?
#7052
Quoted: 10238 Post(s)
Liked 5,185 Times
So I think I figured out the chain skipping problem on the ritchey . Primov (probably spelt wrong) guessed right with the stuck link.
Re waxed the chain tonight, and when I put the chain back on I noticed it was doing the dance on all the cogs. I took the chain back off and broke the links in more no more chain dance pedaling back wards.
Likes For bampilot06:
#7053
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3205 Post(s)
Liked 1,845 Times
As luck would have it, there is an on/off switch on the headlight, that I had forgotten about. Works fine now,.
#7054
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,872 Times
Could be the smoothness or lack of on the drop-out on one side or the other. Could even be an angle problem on one side -- as in a slope that isn't part of the flat. And then again, there might be a circular depression where the retainers engage which actually allow tightness unless there is perfect line-up. And look on both sides each of the drop-outs to find the problem.
#7055
Quoted: 18424 Post(s)
Liked 15,579 Times
I almost never have any issue with Look Delta pedals, but Keos are different. They don't seem to be weighted on the back side as heavily so when you push off they often spin rather than hanging in the right orientation for the front of the cleat to catch them, like the Deltas.
#7056
Quoted: 3361 Post(s)
Liked 3,638 Times
#7057
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,531 Times
#7058
Quoted: 8286 Post(s)
Liked 9,055 Times
The Superbowl champion Rams look amazingly incompetent.
#7059
Liked 9,055 Times
Since I use pedal extenders I need pedals with wrench flats. None of the higher end pedals have wrench flats anymore.
#7060
Now you have indicated the bike in question is Ti, it might be worth checking the bits of the QR that have slots machined into them and face on to the drop outs. If they are worn, which is highly likely as alloy or steel facing on to Ti, new ones or whole QR might be a solution.
#7061
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12780 Post(s)
Liked 7,695 Times
#7062
Quoted: 1401 Post(s)
Liked 1,886 Times
830 grams - yikes !
Is that a Maxxis MTB tire - or Metzler motorcycle tire ? lol
A pair of MTB tires I typically ran BITD weigh less than one Maxxis 2.8
just dug out some old 26" MTB tires - including a Kenda Klimax Lite 1.95 @ 345g per tire ...
just sayin
just sayin
#7063
Liked 1,886 Times
Finally got around to making a map of my actual tour route up to the point where I broke my seat post collar bolt.
Ride with GPS | Bike Route Planner and Cycling Navigation App
That odd "loopage" around the Bellfonte/Bald Eagle area represents some shopping. etc., mileage I did after going to the park office to register, riding to the primitive camping area, which is miles from the park office and then heading into town for groceries, all before my rest day the next day. Odometer read 502 miles at time of bolt breakage. The discrepancy can be explained by, among other things, the mileage I put in during my day off, which included a ride back to the main part of Bald Eagle State Park for a shower and lunch down by the beach while I charged the phone and external battery.
If not - interested in how this ride compared to any previous similar rides etc ... bike, supplies and equipment ... etc
#7064
Liked 1,886 Times
Likes For t2p:
#7065
Liked 1,886 Times
#7066
Liked 15,579 Times
Hadn’t had one of these days in a long time.
Wordle 472 5/6
Wordle 472 5/6
#7067
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
#7068
Liked 8,928 Times
#7069
Liked 8,928 Times
#7070
Bikes: Shmikes
Liked 5,872 Times
Interesting. The favourite bikes for Machka and me are our Ti Hasa road bikes. Mine is coming up to 15,000km (I think about 9,000 miles) and also with Al wheels on each. Considering they were bought as just frames and built up by me from those, they have been beaut bikes. Originally meant for long-distance Audax rides, and I think several 400km ones are on the list of what they have done. Another 400 was planned for the weekend that was coming up when the workplace accident happened 4-1/2 years ago.
#7071
Liked 1,845 Times
#7072
Liked 1,845 Times
Wordle 472 6/6
#7073
Liked 9,055 Times
The tires are heavy, I could put smaller, lighter tires on but these things are amazing. I've gone through piles of sharp rocks and the bike just cruises through. Descending a rough sandstone hill which was a nightmare on my old hardtail 26er is nothing for this set-up.
The tires downhill racers and pro enduro racers use are in the range of 1200 grams. I'm sure the body armor, full face helmet e-bike warriors I see are running downhill tires.
Likes For big john:
#7074
Mostly Harmless
Liked 4,531 Times
That same car after a major rebuild and update carried out in the 1970s.
It spent the offseason on the show circuit.
#7075
Liked 1,886 Times
Rowan's mention of slots or machined surface on a QR do not apply in your case (if the bike has thru axles)
the threads on your thru axles and/or the dropouts on the commuter bike might just be a tad 'loose' ... might be more common on thru axles with a 1.5 thread pitch (compared to a 1.0 thread pitch) ?
thru axle obviously has merit - but threads in the dropouts ... I dunno ...
