What brake does your 1x speed have,?
Old 12-20-21, 06:24 PM
takenreasy
takenreasy's Avatar
Bikes: ’83 Bianchi Special ’96 Specialized Stump Jumper Comp ’09 Gary Fisher Paragon ’09 Surly Cross Check ’11 Surly Long Haul Trucker
Quoted: 71 Post(s)
Liked 76 Times in 50 Posts
Originally Posted by caloso
Tektro 720 cantis on the SSCX. Took some time to get the setup just right, but it's worth it when you do.
This is what I have. They are a little fickle but necessary IMO to run some good size tires.
takenreasy is offline
Likes For takenreasy:
Old 12-21-21, 07:29 AM
Speedway2
Speedway2's Avatar
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times in 246 Posts
My 2009 Langster came with dual pivot brakes/Tektro short reach lever combo on the drops. It never felt like it had enough stopping power. A set of Koolstop Salmon pads probably would have made a difference with the oem setup.
When I converted the drops to bullhorns and installed a set of Tektro RX 4.1 levers the stopping power greatly imporved.
Leverage makes a difference along with proper adjustment.....
Speedway2 is offline
Old 12-21-21, 11:21 AM
EnzoRWD
enginerd
Bikes: officially too many now...
Quoted: 90 Post(s)
Liked 127 Times in 42 Posts
TRP EuroX cantis. You don't need a bell when you have cantis.
<HOOONK> on your left!
EnzoRWD is offline
Old 12-22-21, 11:23 AM
thehammerdog
thehammerdog's Avatar
Quoted: 722 Post(s)
Liked 353 Times in 226 Posts
love this bike heavy beast
thehammerdog is offline
Old 12-25-21, 10:35 PM
GhenghisKahn
OwainGyndwr
GhenghisKahn's Avatar
Bikes: 90 Fisher 3x7 hardtail, 2016 Reid 1x7 commuter, 2017 Viva 46x18 fixed gear, 93 2x8 Avanti Kona
Quoted: 34 Post(s)
Liked 67 Times in 43 Posts
Originally Posted by Senrab62
Get an Ultegra or dura ace front caliper. I'm a big dood, and have had no issues with tektro personally. Uneven pad wear could be pads, or installation error.
Those would be best, but any dual-pivot caliper in the Shimano line would be fine. Tektros fall somewhere between sora and tiagra in terms of quality. I scavenged an old RSX long-reach frt caliper to use on a fg conversion and with new pads it worked a bomb.
GhenghisKahn is offline
Old 01-03-22, 01:28 PM
thehammerdog
Quoted: 722 Post(s)
Originally Posted by AJW2W11E
I have a $20 Tektro R315 or something like that. World just fine but after a while I find that one side is doing all the work or something like that. The pads dont wear even
Any suggestions for a V brake or linear pull for my Pista?
I have something cheap like that but went for all white calipers to match the frame.
the pads suck but it does stop and looks cool.
Old 01-12-22, 04:38 PM
Mikefule
Quoted: 99 Post(s)
Liked 115 Times in 78 Posts
I have some Tektros front and rear on my Pearson. They're the brakes they fitted as standard. I can ride all day without touching them, or I might need them at any moment in an emergency, especially on my short commute. They do the job.
I recently picked up a second hand Langdale 2 x 10 road bike with some very nice Shimano brakes which are much more rigid and work better.
Mikefule is offline
Likes For Mikefule:
Old 01-14-22, 05:49 AM
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 886 Post(s)
Liked 998 Times in 525 Posts
Ultrgras with diacomp flat bar levers on my Pure Fix Cleveland, rear coaster brake on my 29rBigBMX, rear coaster brake\from Winemann center pull on my Bridgestone.
to the op, tighten the center pivot attach bolt as much as you can.
bwilli88 is offline
Old 01-14-22, 07:27 AM
joesch
joesch's Avatar
Quoted: 601 Post(s)
Liked 781 Times in 498 Posts
Dura Ace and Tektro on diff SS bikes, they both work good.
I prefer drops with standard pull levers
Also prefer longer break pads, make sure to match pads for rim type
Cool or Swiss stop pads work great
joesch is offline
Old 01-28-22, 01:36 AM
Jax Rhapsody
Rhapsodic Laviathan
Jax Rhapsody's Avatar
Bikes: Rideable; 83 Schwinn High Sierra. Two cruiser, bmx bike, one other mtb, three road frames, one citybike.
Quoted: 222 Post(s)
Liked 123 Times in 91 Posts
I've got a Shimano Sora on the front, and a Tiagra on the rear of mine.
Jax Rhapsody is offline
Old 01-29-22, 04:59 PM
Dylansbob
2k miles from the midwest
Dylansbob's Avatar
Quoted: 525 Post(s)
Liked 931 Times in 446 Posts
DiaCompe 980 canti, koolstop salmon pads.
Dylansbob is offline
