Interesting finds around the web
#1703
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Dixie Flyer also sells chainrings up to 64t.
#1704
I was a little surprised to read this on the British Cycling web site https://www.britishcycling.org.uk/kn...Cooling-Down-0
A good rule of thumb is that the shorter and more explosive an event is, the longer a warm-up needs to be. Before an all-out effort such as track sprint, riders may spend more than an hour building up to the race.
What warm up period do people on this forum use for 500m?
Thanks.
Thanks.
#1705
Asian track championships results:
https://atresults.wixsite.com/attiming/acct2018
Japanese elite men taking the kilo, sprints, team sprint, team pursuit, and individual pursuit; Japanese elite women taking team pursuit and omnium so far.
#1706
Thanks.
Thanks.
#1707
Lapped 3x
Thanks.
Thanks.
Basically for me, my body needs to be moving for quite a while before I can optimally max out. Can't quite explain it, but it's sort of like some people's brains are only 100% fully awake 2-3 hours after they wake up. My body is the same way, so basically, I would just ride the rollers real easy on and off for the first 2 hours, for 5-10 minutes at a time, and get a light sweat going early on. It also helps to get one's head in the right mind set. My real warm-up to the event was actually started about an hour out.
Basically for an intense event, you want to warm up longer to space out any efforts you do. An explosive event requires that you "wake-up" the nervous system so that you can literally fire all of your muscles at once. Spacing out these efforts allows one to properly recover and not tax themselves too much before the actual event.
#1708
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
What about training? I've seen people just resting over soft eiderdowns for 10, 15 min, then roll lazy for a lap or two and.. jump for a very fast lap from stand.. roll down for two laps, stop, and get back to the blankets for 10, 15 min.... not my old fashion way of doing things..
#1710
Quoted: 1851 Post(s)
Liked 679 Times
I got some Gr8 rings a few weeks ago. I haven't used them by they seem nice. A buddy was putting in an order, and he asked me if I wanted to order some too, to split shipping. I wasn't planning to get rings then, but I figured what the heck.
#1711
It's a joke. People usually fall into one of two camps, with 1/8 being the much larger group as far as I can tell, and it's often harder to find 3/32 in the the sizes you want. Sugino Zen is only 1/8, but my friend put together a special order/ request to have a run of large 3/32 rings. Endurance racers have often tended to favor 3/32. Morelock, who is looking for every last drop of wattage, would probably be better off on a 3/32. I have actually been using an 11 speed chain -- gasp!
#1712
I saw Colby Pearce picked up some Zen's in 3/32 the other day (from his instagram)
I'm not hip though... I like my big bulky 1/8 stuff Although If I find the "perfect" gear in time I might still end up going to 3/32... (and send it off to Atomic for some coating...)
#1713
Elitist
Liked 92 Times
Going 3/32" isn't the end of the world. You just have to buy all of your own stuff new up front (used 3/32" is rare) and you probably won't be able to borrow anything in a pinch. But, borrowing should be rare.
With the chainrings being so big now, the weight savings could be significant.
#1714
58/15 is what I'm thinking... but I need to ride it (and make sure it clears my track elite) a good bit to be sure. So currently just need a cheap 1/8 58t
#1716
Quoted: 40 Post(s)
#1718
Elitist
Liked 92 Times
There was talk of 3/32" providing better feel based on the chain chosen. 3/32" might be more elastic.
This is stuff that I'm recalling from Fixed Gear Fever when it came up. I have no experience with 3/32".
There are some prominent riders (enduros) that use 3/32". I raced with a guy that used 3/32". Strong enduro type, but could also lay down a mean 500M.
It not any worse than 1/8"...just different. A side-grade, I guess.
#1719
Quoted: 17 Post(s)
Elitist
Liked 92 Times
It does offer left and right power measurement, which isn't a big deal. The biggest plus is the user-replaceable battery. The biggest downside seems to be the "< 5s" startup time (per official documentation).
The price is $300 less than SRM.
It seems to use the type of strain gauge that is plopped in the middle of the crank arm. I wonder if this hole in the crank arm affects how much torque the arm can handle before breaking. This might be a concern for the huge sprinters.
I love to see new Track Power Meters on the market.
#1723
Quoted: 17 Post(s)
Yeah way too rich for me but I thought it was an interesting product non the less after reading your comments ref missing data from standing starts, seems they’ve tried to address this and also recognise that torque is also an important metric to be able to see/record.
Aye the always bang on about accuracy, it’s just something they have to mention to keep people interested.
#1724
Elitist
Liked 92 Times
The last power meter that was able to pick up early standing start data was the SRM Wired Track Cranks with PowerControl 5 head unit, using 2 reed switches.
Standing start pickup time has less to do with a head unit "waking up" and more to do with the cranks rotating 2 full rotations (using 1 reed switch). That's how long it takes for a crank to calculate your cadence (time between each rotation). If you can complete 2 full rotations in 1 second, the head unit will start recording then.
2 reed switches helps because instead of 2 rotations being needed, you only need 2 HALF rotations...or 1 rotation
But, this doubles your cadence readings which in turn doubles your power readings. So, the head unit has to be smart enough to halve the cadence data THEN calculate the power. SRM used to have a "2 reed switch" check box in its software, but to be compatible with others, it removed this.
So, basically, SRM dummed-down the product to be more compatible
#1725
Elitist
Liked 92 Times
This is also the result of the road-focus of the power meter products. "Who needs the first 5 seconds of a crit? I'm not even in my other pedal by then! lol..."
If the infocrank were truly making a track PM from the ground up, they would have taken this into consideration. More than half of the track events begin with a standing start.
